Switching power supply? (EU Vero 4K+)
Purchased a Vero 4K+ from mainland Europe.
Can I use the EU two prong in Ireland with a ‘shaver adapter’ plug? …or do I need to purchase a three prong power supply for the Vero 4K+ to use it in Ireland.
Are power supply plug generics available for the Vero 4K+ or could I purchase one from the OSMC shop?
The Vero 4K+ was almost new with the TV tuner and hub, for less than the cost of just the player, that’s why I bought it…
Thanks for your time.
It’s best to buy a U.K. plug.
If you contact support@osmc.tv we can send you an invoice for one.
Sam, thanks for your reply. Will make contact. Thanks again.
