Device: (Rasp Pi 2)
Installation media: (SDcard)
Connection: (Wifi)
Power Supply Type: 220V/2A
Power specs: ?
Peripherals: PAL Monitor / rapoo 3600 touchpad keyboard
Storage Device USB3 HDD 2TB
OSMC version: July 2015 2015.07-1
XBMC version: ?
Codecs: mpeg2
Audio/Video Output: (hdmi / analogue auto)
Overclocked: no
Config.txt Extras: no
LINK to uploaded logs in pastebin (kicanexewi)
simple problem: I don’t know how to switch back to OSMC skin. Yesterday I switched from OSMC to Confluence (because I read that Confluence supports mouse.
Today I want to switch back to OSMC - and I don’t find a way!
Please help
thank you
I know your problem, I am in the same boat.
It seems that in the new OSMC image containing Kodi 15.0 has a problem with the Confluence Image.
In the Options section you find “MyOSMC” instead of “Settings”. Therefore you do not have access to all important settings including the skins.
@sam_nazarko Is there a way via the shell to restore the Options Tab of the confluence skin to remove “MyOSMC” and to replace it withe the original link to the settings?
Hello - and thanks for your reply!
But I do not find “System”. Underneath “Options” I find “My OSMC” and this offers Updates, Services, Overclock, App Store, Network, Remotes, Pi Config and Log Uploader, (listed Clockwise) but nothing called “System” (or offering a skin change)
Unfortunately
Ben
Thanks for your assistance,
I seem not to find the solution offered by sam_nazarko.
Probably an update problem? In the morning my system was updated.
Thanks for your help
Ben
