My audio is out of sync and I have to change audio to ahead 100 ms every time I start a video. Is there a global setting, like on my bluray player so that I don’t have to change this on every movie?
I have resolution set to 2160p, but I often get a black screen when the Vero4k is connected to my LG TV directly. Connecting it to my receiver solves the problem. If I change frame rate to 30 Hz and turn on Force 422 color sub sampling it works with it connected to the TV. Is there any drawbacks of enabling Force 422 color sub sampling. Any loss of quality? Also, setting the menu to 1080p solves the problem, but then the Vero4k doesn’t upscale the videos to 4k.
Playing 2160p H.264 videos encoded in 60 fps result in the video lagging behind the audio. Looks like it can’t handle the high framerate. Is there support for 60 fps 2160p H.264 videos? My TV supports 2160p 60 fps H.265 video, but not H.264. My bluray-player supports both though.
60 fps 1080p video works but plays at 30 fps if the menu is set to 2160p 60hz. Setting the menu to 1080p 60hz plays the videos at 60 fps.
My settings are:
sync playback to display: off
adjust display refresh rate: always
I tested a 1080p 60 fps clip again, and now it worked with the menu at 2160p. I might have been wrong when I said I tested with the new version.
I will upload the logs when playing a h.264 2160p clip at 60 fps. h.265 2160p at 60 fps plays fine but h.264 clips are very slow.
I followed this guide to mount a NFS share, but I noticed that when my NAS is turned off the vero4k hangs when accessing movies. Sometimes my NAS is turned off and I want to be able to watch videos from a USB. Is this possible?
I’m just not sure that I want to share my logs with everyone since I read that it can contain passwords and other personal information. That is why I sent the logs directly to a mod.
