Synology NAS - smb password change
I need some help on that matter:
Synology told me to change my login account (from the default admin to another username with Admin rights)
I changed the password in the passwords.xml file found in the userdata folder. (on a Vero 4k)
old :
smb://192.168.2.108/video
smb://admin:YXZYXZXYZ@192.168.2.108/video/
new:
smb://newuser:YXZYXZXYZ@192.168.2.108/video/
I did edit it on my Mac , after transferring it with ftp with BBEdit. Deleted the old file in the userdata folder, and transferred the new one.
After reboot, I found that in the setttings > edit network location , the smb connection works still with the old “admin” acoount .
What could I do ?
Andi
I’d suggest that you SSH to the V4K and edit the file using nano.
Before you edit the file, run this command:
systemctl stop mediacenter
After you’ve edited the file, run this command:
systemctl start mediacenter.
Then check if the new password is now being used.
Thank you for your answer.
I found another file with the name mediasources.xml where the old password was stored as well.
After I changed that and a restart it worked again !
Andi
