Well, the error itself suggests a path to follow.
You have assigned the same IP address, 192.168.1.9, to both the ethernet and WiFi interfaces:
Jun 01 11:55:26 osmc avahi-daemon[292]: Registering new address record for 192.168.1.9 on eth0.IPv4.
Jun 01 11:55:28 osmc avahi-daemon[292]: Withdrawing address record for 192.168.1.9 on eth0.
Jun 01 11:55:28 osmc avahi-daemon[292]: Registering new address record for 192.168.1.9 on wlan0.IPv4.
Jun 01 11:55:30 osmc avahi-daemon[292]: Registering new address record for 192.168.1.9 on eth0.IPv4.
etc, etc.
You need to assign a different IP address to each interface.
One extra minor issue is that your advancedsettings.xml contains the line:
sudo nano ~/.kodi/userdata/advancedsettings.xml
which needs to be removed.
I thought that as only one interface was active at a time that would be ok. Now changed.
but will that screw my other config files up which refer to the server being on 192.168.1.9 (or 17 if going other way?)
Re advanced settings.xml file, I think I must have screwed up while cutting and pasting.
it now has
<?xml version="1.0" encoding="utf-8"?> <videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
<videodatabase>
<name>MyVideos</name>
<host>192.168.1.09</host>
<user>osmc</user>
<pass>osmc</pass>
<type>mysql</type>
<port>3306</port>
</videodatabase>
but without the big spaces.
The log shows that IP address 192.168.1.9 was used simultaneously on both interfaces:
Jun 01 11:55:26 osmc connmand[388]: eth0 {add} address 192.168.1.9/24 label eth0 family 2
Jun 01 11:55:28 osmc connmand[388]: eth0 {del} address 192.168.1.9/24 label eth0
Jun 01 11:55:28 osmc connmand[388]: wlan0 {add} address 192.168.1.9/24 label wlan0 family 2
Jun 01 11:55:30 osmc connmand[388]: eth0 {add} address 192.168.1.9/24 label eth0 family 2
Jun 03 10:37:18 osmc http-time[412]: Updated time from Tue Jun 1 10:55:31 UTC 2021 to Thu Jun 3 09:37:18 UTC 2021 using HTTP query to www.google.com
Jun 03 10:42:18 osmc connmand[388]: eth0 {del} address 192.168.1.9/24 label eth0
Jun 03 10:43:13 osmc connmand[388]: wlan0 {del} address 192.168.1.9/24 label wlan0
Jun 03 10:47:25 osmc connmand[388]: wlan0 {add} address 192.168.1.9/24 label wlan0 family 2
Jun 03 10:49:19 osmc connmand[388]: wlan0 {del} address 192.168.1.9/24 label wlan0
Jun 03 10:49:19 osmc connmand[388]: wlan0 {add} address 192.168.1.9/24 label wlan0 family 2
Jun 03 10:49:23 osmc connmand[388]: wlan0 {del} address 192.168.1.9/24 label wlan0
Jun 03 10:49:23 osmc connmand[388]: wlan0 {add} address 192.168.1.9/24 label wlan0 family 2
Note that the OpenVPN errors started at 10:37:45 when wlan0 and eth0 were both up and sharing the same IP address.
The WiFi link also seems to be unstable and seems to have been down between 10:43:13 and 10:47:25. The log shows that it tried to associate with three separate SSIDs, so it looks like they could be interfering with each other. Best to choose just one and leave it at that.
Jun 01 11:55:28 osmc wpa_supplicant[291]: wlan0: Trying to associate with 3c:37:86:fc:2c:58 (SSID='secure-2' freq=2437 MHz)
Jun 03 10:44:09 osmc wpa_supplicant[291]: wlan0: Trying to associate with 3c:37:86:fc:2c:59 (SSID='secure-2-5G-2' freq=5500 MHz)
Jun 03 10:46:50 osmc wpa_supplicant[291]: wlan0: Trying to associate with 3c:37:86:fc:2c:57 (SSID='secure-2-5G-1' freq=5180 MHz)
Jun 03 10:49:19 osmc wpa_supplicant[291]: wlan0: Trying to associate with 3c:37:86:fc:2c:58 (SSID='secure-2' freq=2437 MHz)
Jun 03 10:49:23 osmc wpa_supplicant[291]: wlan0: Trying to associate with 3c:37:86:fc:2c:58 (SSID='secure-2' freq=2437 MHz)
That is partly correct (I also have the same IP). But this only works if the Ethernet interface is connected at boot time and remains connected. If you change between them at run time you might get a situation where both become active.
I have re installed OSMC on both vero’s and they are both much faster (50mb’s on speed test). However on one of them I can’t ssh into it.
I get
Davids-MacBook-Pro:~ Dave$ ssh osmc@192.168.1.09
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:aT31EyzIFj6Ao2Vs6Exfdm/7RkFkVTrlmpLRkSGWrEY.
Please contact your system administrator.
Add correct host key in /Users/Dave/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/Dave/.ssh/known_hosts:7
ECDSA host key for 192.168.1.9 has changed and you have requested strict checking.
Host key verification failed.
I used
Davids-MacBook-Pro:~ Dave$ ssh-keygen -R 192.168.1.09
and get
Host 192.168.1.09 not found in /Users/Dave/.ssh/known_hosts
How can I get to ssh in?
FTP, ssh, Samba and transmittion client are all running and I have checked the ip address.
Totally normal after reinstall of OSMC as new SSH keys are created.
Try ssh-keygen -R 192.168.1.9
Adding a leading 0 to an IP is not normal.
That sorted it. Thanks.
now cant get file sharing working.
get path found or invalid on both machines.
Have reloaded config files that were not installed .
logs are
https://paste.osmc.tv/ocaguwiwug
is there something I’ve not enabled?
Got it to work from the slave to the master vero, so I can see the files on the main vero but not the other way round.
Also back to slow speed on both, so it must be the connection between the 2 that is causing the slow data transfer.
Is there a better way to do file sharing?
How are they now connected? What iperf3 speed do you get between them?
Assuming you are using samba? If so did you enable Samba Server on both of them?
haven’t tested iperf speed yet, and yes did install samba on both, do I need to do anything else to enable it?
perf test gives
Connecting to host 192.168.1.9, port 5201
Reverse mode, remote host 192.168.1.9 is sending
[ 5] local 192.168.1.17 port 45439 connected to 192.168.1.9 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 5.64 MBytes 47.3 Mbits/sec
[ 5] 1.00-2.00 sec 6.13 MBytes 51.4 Mbits/sec
[ 5] 2.00-3.00 sec 5.70 MBytes 47.8 Mbits/sec
[ 5] 3.00-4.00 sec 5.68 MBytes 47.7 Mbits/sec
[ 5] 4.00-5.00 sec 3.44 MBytes 28.8 Mbits/sec
[ 5] 5.00-6.00 sec 2.43 MBytes 20.4 Mbits/sec
[ 5] 6.00-7.00 sec 3.29 MBytes 27.6 Mbits/sec
[ 5] 7.00-8.00 sec 4.24 MBytes 35.5 Mbits/sec
[ 5] 8.00-9.00 sec 4.20 MBytes 35.3 Mbits/sec
[ 5] 9.00-10.00 sec 5.49 MBytes 46.1 Mbits/sec
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-10.22 sec 46.9 MBytes 38.5 Mbits/sec 22 sender
[ 5] 0.00-10.00 sec 46.2 MBytes 38.8 Mbits/sec receiver
iperf Done
These speeds aren’t ideal – they also fluctuate a lot which will cause buffering issues.
is there a way I can improve the speed, or is there better way to file share, also still cant get the server to see the slave files.
Are you now connected to the 5GHz SSID?
No, that should be enough to make them reachable via SMB
Just checked and they are back on LAN. will change to wireless, although the connected speed was 50 Mbs before I enabled file smb.
both back on 5 Ghz
iperf
[ 5] local 192.168.1.17 port 45740 connected to 192.168.1.9 port 5201
[ 5] 0.00-1.00 sec 2.52 MBytes 21.1 Mbits/sec
[ 5] 1.00-2.00 sec 2.30 MBytes 19.3 Mbits/sec
[ 5] 2.00-3.00 sec 3.07 MBytes 25.8 Mbits/sec
[ 5] 3.00-4.00 sec 2.38 MBytes 20.0 Mbits/sec
[ 5] 4.00-5.00 sec 2.66 MBytes 22.3 Mbits/sec
[ 5] 5.00-6.00 sec 2.87 MBytes 24.0 Mbits/sec
[ 5] 6.00-7.00 sec 3.20 MBytes 26.8 Mbits/sec
[ 5] 7.00-8.00 sec 3.86 MBytes 32.4 Mbits/sec
[ 5] 8.00-9.00 sec 3.25 MBytes 27.2 Mbits/sec
[ 5] 9.00-10.00 sec 3.63 MBytes 30.5 Mbits/sec
[ 5] 0.00-10.02 sec 30.2 MBytes 25.3 Mbits/sec 35 sender
[ 5] 0.00-10.00 sec 29.7 MBytes 24.9 Mbits/sec receiver
iperf Done.
Did you disable/disconnect Ethernet? Numbers are still not convincing but at least stable. But sure for 4k playback you need higher numbers.
Had it disabled. Now disconnected
[ 5] local 192.168.1.17 port 45385 connected to 192.168.1.9 port 5201
[ 5] 0.00-1.00 sec 3.83 MBytes 32.1 Mbits/sec
[ 5] 1.00-2.00 sec 4.19 MBytes 35.1 Mbits/sec
[ 5] 2.00-3.00 sec 3.74 MBytes 31.3 Mbits/sec
[ 5] 3.00-4.00 sec 4.18 MBytes 35.0 Mbits/sec
[ 5] 4.00-5.00 sec 4.00 MBytes 33.6 Mbits/sec
[ 5] 5.00-6.00 sec 3.28 MBytes 27.5 Mbits/sec
[ 5] 6.00-7.00 sec 3.52 MBytes 29.5 Mbits/sec
[ 5] 7.00-8.00 sec 4.19 MBytes 35.1 Mbits/sec
[ 5] 8.00-9.00 sec 3.26 MBytes 27.3 Mbits/sec
[ 5] 9.00-10.00 sec 4.20 MBytes 35.2 Mbits/sec
[ 5] 0.00-10.03 sec 40.0 MBytes 33.5 Mbits/sec 2 sender
[ 5] 0.00-10.00 sec 38.4 MBytes 32.2 Mbits/sec receiver
iperf Done.
