They use .exe for whatever reason (I also thought it odd).
Since the executable itself is fine when I run it through the mono command I figured their system is working as intended and thought it was more of a problem with how systemd is working. But I don’t know much of anything about Linux, so its all greek to me.
Like I said, take it up with the jackett developer. (Just a hint however, I suspect that the error snippet had a little more info, like to run journaltcl to see more information about the error)
If the developer is using .exe on a file targeted for Linux, I’d be cautious…
Excellent! Thanks for telling me about Journalctl. Ran that command (then realized running it -r was a much better plan…), it said “no file or directory”. Looked back and realized that I forgot to capitalize the J in the directory. Sheesh.
Also, regarding the .exe thing. I read that you have to use mono because they are coding in .net or something like that. Maybe that’s why its a .exe by default, because that is how that framework works?
No idea, but either way its working. Thank you much for your assistance!
