I was very happy to finally have support for my TechnoTrend S2-4600 in OSMC 2017.05-1.
Although scanning for channels and tuning did not work, at least when I plugged the device in, the driver was automatically loaded and TVHeadend found the device.
However, after the update to OSMC 2017.05-2, all I get in dmesg after plugging the device in is:
[ 3057.362813] usb 1-2.4: new high-speed USB device number 7 using xhci-hcd
[ 3057.463175] usb 1-2.4: New USB device found, idVendor=0b48, idProduct=3011
[ 3057.463187] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3057.463192] usb 1-2.4: Product: TechnoTrend USB2.0
[ 3057.463197] usb 1-2.4: Manufacturer: Jactek
[ 3057.463202] usb 1-2.4: SerialNumber: 000000031
Comparing the output of lsmod before and after plugging the device in shows exactly no difference.
Hence, it seems to me that the driver just isn’t loaded automatically. I can load it manually with
sudo modprobe m88ds3103
sudo modprobe ts2020
sudo modprobe rc_tt_1500
The loaded modules related to the device are then:
osmc@osmc-Aloysius:~$ lsmod | grep dvb
dvb_core 88550 1 m88ds3103
media 20743 2 videodev,dvb_core
and
osmc@osmc-Aloysius:~$ lsmod | grep m88
m88ds3103 11660 0
But when I re-plug the device, that doesn’t make any difference on the dmesg output above. I also don’t know if I need to load any additional modules.
Unfortunately, I didn’t keep the dmesg output from OSMC 2017.05-1, but I can provide it from my Ubuntu 16.10 laptop, where the device works just fine.
Is there any advice you can give me on loading the driver properly?
Device info:
https://www.linuxtv.org/wiki/index.php/TechnoTrend_TT-connect_S2-4600
lsusb:
Bus 001 Device 007: ID 0b48:3011 TechnoTrend AG
