Temporary CEC problems with Krypton Beta
I have problems with CEC, my tv remote don’t respond
Which TV?
Are you on Krypton or Jarvis?
Did you powerdown (unplug from wall the TV and the OSMC device for more than 2 minutes?
If the powerdown didn’t help provide Debug Logs!
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
You are running a Krypton test build, it would seem, so libCEC would be updated via this channel and this wouldn’t be related to the October update.
libCEC was updated in the Krypton branch; this is now incompatible with b3. You will need to wait for b5 update (coming in a few hours), or downgrade back to the stable version of OSMC.
Ok, thanks.
08:34:08 13.807016 T:1958244352 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
08:34:08 13.807112 T:1958244352 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture
GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuff
er GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
08:34:10 16.291489 T:1958244352 ERROR: Unable to load libcec.so.3, reason: libcec.so.3: cannot open shared object file: No su
ch file or directory
08:34:10 16.488831 T:1958244352 NOTICE: Running database version Addons26
08:34:10 16.499214 T:1958244352 NOTICE: Running database version ViewModes6
08:34:10 16.505484 T:1958244352 NOTICE: Running database version Textures13
08:34:10 16.525520 T:1958244352 NOTICE: Running database version MyMusic60
08:34:10 16.555542 T:1958244352 NOTICE: Running database version MyVideos107
08:34:10 16.562460 T:1958244352 NOTICE: Running database version TV29
08:34:10 16.569866 T:1958244352 NOTICE: Running database version Epg11
08:34:10 16.577560 T:1958244352 NOTICE: start dvd mediatype detection
08:
I’ve covered this above – it’s not related to the October update, it’s related to the fact that you are running experimental Kodi Krypton builds. New builds will be available in a few hours that will work with this new version of CEC.
Moved this to a new thread as it is not related to the October release but to Krypton Beta.
As it will be solved in a few hours (when you upgrade after Sam releases the new version) please mark it as solved by that time.
Perfect. Everything it’s ok like always.
18:31:16 14.605485 T:1959089072 NOTICE: GL_VENDOR = Broadcom
18:31:16 14.605669 T:1959089072 NOTICE: GL_RENDERER = VideoCore IV HW
18:31:16 14.605752 T:1959089072 NOTICE: GL_VERSION = OpenGL ES 2.0
18:31:16 14.605822 T:1959089072 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:31:16 14.605920 T:1959089072 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_text
ure_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_
18:31:19 17.316910 T:1831859184 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:31:19 17.340937 T:1938813936 NOTICE: Running database version Addons26
18:31:19 17.350349 T:1938813936 NOTICE: Running database version ViewModes6
18:31:19 17.360626 T:1938813936 NOTICE: Running database version Textures13
18:31:19 17.381556 T:1938813936 NOTICE: Running database version MyMusic60
18:31:19 17.414762 T:1938813936 NOTICE: Running database version MyVideos107
18:31:19 17.421867 T:1938813936 NOTICE: Running database version TV29
18:31:19 17.430254 T:1938813936 NOTICE: Running database version Epg11
18:31:19 17.437582 T:1959089072 NOTICE: start dvd mediatype detection
many Thanks
Hello again,
My system hangs in the time, I think that is for this message,
OnTvStandby - Unexpected [standby_pc_on_tv_standby] setting value
leave here my logs
http://paste.osmc.io/itagofafef
it happens when I switch off my tv
Edited: hangs CEC
Sorry,
I think that I have a correct log now, excuse me please.
http://paste.osmc.io/otuwonepot
thanks for your help
