Sry, that was a misunderstanding then. I was referring to the stable kernel
The issue is gone in the test kernel.
That is good to hear
@Sam:
i can not edit the rc.local (for 10 bit display), because āpermission deniedā. I was connected by sftp via Filezillaā¦
Any idea?
Many thanks!
BR Peter
Suggest you use SSH to access the box. Youāll also need to use sudo to get elevated privilege when editing rc.local.
Thanks for reply! I was connected via SSH, but donāt know how to edit the rc.local⦠For this i try to use filezilla. Could you give me a further hint?
BR Peter
Use sudo nano /etc/rc.local
Many thanks for helping out! After procedure OSMC shows update available, will this overwrite the test build again?
BR
Peter
Iām pretty new to the Vero 4k, but I have tried one 10bit 4k movie which is looking much better with this build. Canāt really say anything about the banding issue. I do however experience occasional blackouts. Full debug log here: https://paste.osmc.tv/qapopigapi
@Sam:
10bit Picture-depth is working well with this build; But there is no switching between 8 and 10 bit, right? It stays at 10 bit also for 8 bit content. Was this your intention?
Great work + hope to see this āfeatureā official!
BR
Peter
Yes ā this is expected.
This functionality will be implemented in the next update. Thanks to everyone in this thread for testing and helping us prepare it for OSMC ![]()
Closing this thread as the above improvements are now in OSMCās July update
