Over the past few weeks there have been a few of you trying HDR and 10-bit content and reporting issues with colours or slight banding. Here are some experimental test builds that will hopefully improve this situation.
Please note that this is early days; and these builds are quite experimental. I would recommend that you take a backup before installing these builds.
In this build:
Colourspace should now be passed for content
Banding when playing with 8-bit output should now be fixed
AWESOME! This is working great for me. I can confirm that my receiver & TV are both receiving a 10bit signal from the Vero4k with no ill effects. I watched plenty of 10bit content and it looks considerably better now, and there isnāt any negative effect on 8bit content, although it does always seem to output a 10bit BT.2020 signal regardless of the bit-depth of the content (donāt see any problem here, just reporting everything Iāve noticed. It was always 8bit before regardless of whether it was 10bit content).
Actually I just noticed one thing - my harmony remote stopped working again. I didnāt change anything regarding that config. It was working fine as an Xbox 360 remote using lircd before the update.
There may be breakage, but that goes with the territory. Iād like to focus on the video improvements for now in this thread, but if you send me a PM we can debug this further. The latest SoC changes may have an impact on IR support.
I didnāt really see any issues with HDR but decided to try this anyway and it messed something up.
I had a pretty fresh install and updated with this. Now on boot it wonāt load the NFS shares setup in fstab (seems to try to mount them before wlan is finished), and OSMC crashes one time (Sad face but restarts again) and now when I try to watch one HDR10 clip that was previously okay it clips to black and resets the display a few times, and when thereās image there are red pixels scattered. Very strange.
osmc@osmc:~/temp$ sudo dpkg -i vero3-image.deb
(Reading database ā¦ 21343 files and directories currently installed.)
Preparing to unpack vero3-image.deb ā¦
Examining /etc/kernel/preinst.d/
Done.
Unpacking vero364-image-3.14.29-25-osmc (25) over (25) ā¦
Examining /etc/kernel/postrm.d .
Setting up vero364-image-3.14.29-25-osmc (25) ā¦
Hmm. There is a symbolic link /lib/modules/3.14.29-25-osmc/build
However, I can not read it: No such file or directory
Therefore, I am deleting /lib/modules/3.14.29-25-osmc/build
Hmm. The package shipped with a symbolic link /lib/modules/3.14.29-25-osmc/source
However, I can not read the target: No such file or directory
Therefore, I am deleting /lib/modules/3.14.29-25-osmc/source
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.14.29-25-osmc /boot/vmlinuz-3.14.29-25-osmc
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal-osmc 3.14.29-25-osmc /boot/vmlinuz-3.14.29-25-osmc
run-parts: executing /etc/kernel/postinst.d/inform-updater 3.14.29-25-osmc /boot/vmlinuz-3.14.29-25-osmc
run-parts: executing /etc/kernel/postinst.d/upload-to-emmc 3.14.29-25-osmc /boot/vmlinuz-3.14.29-25-osmc
7+1 records in
7+1 records out
8056832 bytes (8.1 MB) copied, 0.596019 s, 13.5 MB/s
0+1 records in
0+1 records out
40465 bytes (40 kB) copied, 0.0365343 s, 1.1 MB/s
osmc@osmc:~/temp$ sudo dpkg -i vero3-mediacenter-osmc.deb
(Reading database ā¦ 21677 files and directories currently installed.)
Preparing to unpack vero3-mediacenter-osmc.deb ā¦
Unpacking vero3-mediacenter-osmc (17.3.0-4) over (17.3.0-4) ā¦
Setting up vero3-mediacenter-osmc (17.3.0-4) ā¦
Processing triggers for mime-support (3.58) ā¦
osmc@osmc:~/temp$ ls -l /sys/class/amyhdmitx/amhdmitx0/attr
ls: cannot access /sys/class/amyhdmitx/amhdmitx0/attr: No such file or directory
osmc@osmc:~/temp$
I donāt remember it saying those āhmmā things the first time but perhaps somethingās messed up then, and there doesnāt seem to be an attr that I can list
Hi and thanks, that did the trick. X-systemd solved it.
Now the shares and boot looks fine, however hdr videos are still cutting/going blank and showing red pixels regular material works just fine
