[TESTING] Bluetooth audio streaming (A2DP)
#781
I’m having issues with connecting to the headphones from a Vero4K.
From the bluetooth discovery menu when I choose the headphones the pairing fails with no useful message.
This some system information (which should probably also be in the grab-logs script, but couldn’t find):
Linux osmc 3.14.29-51-osmc #1 SMP Tue Jan 2 09:35:33 UTC 2018 aarch64 GNU/Linux
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
osmc@osmc:~$ cat /etc/os-release
PRETTY_NAME="Open Source Media Center"
NAME="OSMC"
VERSION="December 2017"
VERSION_ID="2017.12-1"
ID=osmc
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.osmc.tv"
SUPPORT_URL="http://www.osmc.tv"
BUG_REPORT_URL="http://www.osmc.tv"
How should I proceed?
#782
Ok i am getting a little bit further by starting pulseaudio i now do get connected. But there is still no audio coming through my headset but my nexus 4 can stream audio to osmc.
Still need to understand how to get osmc stream to my headphones.
#783
OK i am getting there, my headset is not set to a a2dp profile what ever i am trying it fails
pacmd set-card-profile 1 a2dp_sink
Failed to set card profile to ‘a2dp_sink’
This is the profile of my headset
       index: 1
driver: <module-bluez5-device.c>
owner module: 24
properties:
	device.description = "MDR-ZX770BN"
	device.string = "04:5D:4B:A5:9C:E4"
	device.api = "bluez"
	device.class = "sound"
	device.bus = "bluetooth"
	device.form_factor = "headset"
	bluez.path = "/org/bluez/hci0/dev_04_5D_4B_A5_9C_E4"
	bluez.class = "0x240404"
	bluez.alias = "MDR-ZX770BN"
	device.icon_name = "audio-headset-bluetooth"
	device.intended_roles = "phone"
profiles:
	headset_head_unit: Headset Head Unit (HSP/HFP) (priority 20, available: unknown)
	a2dp_sink: High Fidelity Playback (A2DP Sink) (priority 10, available: no)
	off: Off (priority 0, available: yes)
active profile: <off>
ports:
	headset-output: Headset (priority 0, latency offset 0 usec, available: unknown)
		properties:
	headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
		properties:
#784
Ok i have managed to get my a2dp headset working once and do not manage to get it workin again. Looks like i am not the only one having a problem
https://bugs.freedesktop.org/show_bug.cgi?id=92102
The solution seems to download the python script but unfortunately is python3.5
#785
Hi.
I have the same problem too After dicember update. Bluetooth headphones pair up but I can not hear any audio.
#786
Also appears to be broken since the December update, using the Pi as a Bluetooth speaker. When pairing with my phone it just appears as a generic Bluetooth device so there’s no option to stream to it. Hasn’t worked on the 2 Pis I’ve tested it on but it worked on both before the update.
#787
I have RPI3 and bluetooth headset JBL e25bt. My device after few attempts connect but one seconds after id disconnects :frowning:
I use this command to disable internal bluetooth module:
I use dtoverlay=pi3-disable-bt
I use this adapter:
http://www.delock.com/produkt/61889/pdf.html?sprache=en
#788
I think it is still working it’s pulseaudio which does not start.
You could try launching it by putting pulseaudio --start in osmc
#789
Where do I put that line of code?
in this article it say that on stretch pusleaudio is not installed.
quote:
we are using the bluez-alsa package to make Bluetooth audio work with ALSA itself.
#790
It is not installed by default. The a2dp-app-osmc package installs it.
#791
Can you give me instructions how to do that please?
#792
All the instructions in this thread are outdated. In theory, all you need to do is
sudo apt-get update
sudo apt-get install a2dp-app-osmc
However since the update to stretch/17.6 at the beginning of this month, bluetooth audio is not working as it used to. The exact reason is still being looked into.
Streaming audio to BT speaker
#793
Bluetooth audio output
#794
The thread is now closed until we have a new solution
Cannot make ALSA + SoundWire to work
#795
I’m re-opening this – as we resolved the issues here some time ago.
After Kodi v18 is released, we will likely integrate this so no additional steps are needed.
#797
I have installed this a2dp solution and it works almost great. The only problem is after I reboot OSMC sounds of GUI are very high pitched and loud. I have to change audio settings in Kodi from “AML-M8AUDIO,HDMI” to default PulseAudio and again to “AML-M8AUDIO,HDMI” to get rid of these strange sounds.
My configuration is: PulseAudio connected to BT audio receiver is default and I’m using it for Raspotify to stream my music wirelessly. Still I want Kodi to send audio through HDMI and not default PulseAudio and it works… until I reboot when it gets distorted.
Any idea how to resolve this issue? Maybe by changing default audio device from PulseAudio to HDMI? But I don’t know how to do it. And even if I do I guess I will not know what to put in raspotify as the “–device ???” (now it’s “–device default”).
#798
Hey Sam, that’s great news to read! Thanks, waiting impatiently for it :slight_smile:
#799
Can you post a log when the audio is distorted?
Of course: https://paste.osmc.tv/eqalamuxos
