@sam_nazarko Ok. Don’t I need an antenna for DVB-T (or T2) to work?
Anyway, tried to scan DVB-T with w_scan, and this is what I got (removed the “blank” scanning lines):
osmc@osmc:~$ w_scan -f -t -c DK
w_scan -f -t -c DK
w_scan version 20161022 (compiled for DVB API 5.10)
using settings for DENMARK
DVB aerial
DVB-T Europe
scan type TERRESTRIAL, channellist 4
output format vdr-2.0
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
/dev/dvb/adapter0/frontend0 -> TERRESTRIAL "Realtek RTL2832 (DVB-T)": good :-)
/dev/dvb/adapter0/frontend1 -> TERRESTRIAL "Panasonic MN88473": very good :-))
Using TERRESTRIAL frontend (adapter /dev/dvb/adapter0/frontend1)
-_-_-_-_ Getting frontend capabilities-_-_-_-_
Using DVB API 5.10
frontend 'Panasonic MN88473' supports
DVB-T2
INVERSION_AUTO
QAM_AUTO
TRANSMISSION_MODE_AUTO
GUARD_INTERVAL_AUTO
HIERARCHY_AUTO
FEC_AUTO
BANDWIDTH_AUTO not supported, trying 6/7/8 MHz.
FREQ (42.00MHz ... 1002.00MHz)
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
Scanning DVB-T...
Scanning 8MHz frequencies...
474000: (time: 00:01.300) signal ok: QAM_AUTO f = 474000 kHz I999B8C999D999T999G999Y999 (0:0:0)
Info: no data from PAT after 2 seconds
deleting (QAM_AUTO f = 474000 kHz I999B8C999D999T999G999Y999 (0:0:0))
482000: (time: 00:04.740)
554000: (time: 00:22.990) signal ok: QAM_AUTO f = 554000 kHz I999B8C999D999T999G999Y999 (0:0:0)
deleting (QAM_AUTO f = 554000 kHz I999B8C999D999T999G999Y999 (0:0:0))
562000: (time: 00:26.730)
714000: (time: 01:08.150) signal ok: QAM_AUTO f = 714000 kHz I999B8C999D999T999G999Y999 (0:0:0)
deleting (QAM_AUTO f = 714000 kHz I999B8C999D999T999G999Y999 (0:0:0))
722000: (time: 01:11.730)
Scanning DVB-T2...
474000: (time: 01:49.000)
ERROR: Sorry - i couldn't get any working frequency/transponder
Nothing to scan!!
Anything else I can do or try?
