The original thread has now been updated to Kodi Jarvis RC3: Kodi 16 (Jarvis) RC3 released - OSMC
May be just something at my end but when trying to update to RC3 I’m getting the following:
W: Failed to fetch http://apt.osmc.tv/dists/jessie/main/binary-armhf/PackagesIndex Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
Try again in a few minutes. This is just a temporary problem that sometimes occurs when we push new packages to the mirror. We’re hoping to have it addressed when the next version of Mirrorbits is released.
I tried my ATV 1 on Kodi 16 RC3 upgrade, that did not work…
My putty output, previous reports were normal.:
Reading package lists... Done
Building dependency tree
atv-mediacenter-osmc
1 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
Need to get 31.0 MB of archives.
After this operation, 7168 B of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
E: There are problems and -y was used without --force-yes
Updating the OSMC skin
mediacenter-skin-osmc is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
Reverting to stable channel
Restarting system
What can I try to fix it or that a general issue?
No fix needed, most probably the used apt-mirrors are still updating, so just try again in an hour or so.
I had to try several times since yesterday for myself, and just 5 min. ago it worked.
Hi Fry7,
now it worked, thx
Here everything is working apart from popcornmix addon for the visualisation for music.
i just have a black screen.
I’ve just installed RC3 on my Rpi2 and it works great. However, I have spotted that AirPlay from iPhone6 running latest iOS9 is not working despite of having disabled the option (‘Enable Airplay Videos and Pictures Support’). I have switched on log debugging and tailed the logs but surprisingly nothing gets logged when I send audio from my iPhone via Music App. . Also I have tried airplay from my mac (running latest El Captitan) and it throws the following An error occurred while connecting to the AirPlay device “osmc”. An unknown error occurred (-15000). Hopefully this can be troubleshooted.
Thanks,
Marcos
I don’t think it’s meant to work on iOS 9 now.
Playing from your Mac won’t work and isn’t expected to.
Hi Sam. I read a user reported it was working. see at the bottom end
http://forum.kodi.tv/showthread.php?tid=238523&page=13
Upgrade to the latest iOS
Execute the following command for Pi 2, Vero 1 or Vero 2:
wget http://paste.osmc.io/raw/vekoqepiqe -O- | sudo bash
Execute the following command for Pi 1:
wget http://paste.osmc.io/raw/alatijuhom -O- | sudo bash
Didnt work on my RPI 2 with latest 15.2 update from feb.
I ran the command with Putty and got this result:
login as: osmc
osmc@192.168.1.37’s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
osmc@osmc:~$ wget http://paste.osmc.io/raw/vekoqepiqe -O- | sudo bash
converted ‘http://paste.osmc.io/raw/vekoqepiqe’ (ANSI_X3.4-1968) → ‘http://paste.osmc.io/raw/vekoqepiqe’ (UTF-8)
–2016-02-09 10:33:08-- http://paste.osmc.io/raw/vekoqepiqe
Resolving paste.osmc.io (paste.osmc.io)… 159.253.212.250
Connecting to paste.osmc.io (paste.osmc.io)|159.253.212.250|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: unspecified [text/plain]
Saving to: ‘STDOUT’
[ <=> ] 330 --.-KB/s in 0s
2016-02-09 10:33:08 (4.25 MB/s) - written to stdout [330]
Moving to staging channel
Hit http://security.debian.org jessie/updates InRelease
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://ftp.debian.org jessie Release.gpg
Hit http://apt.osmc.tv jessie InRelease
Hit http://apt.osmc.tv jessie-devel InRelease
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Get:1 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [367 B]
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://ftp.debian.org jessie-updates/non-free armhf Packages
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:2 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie-updates/main Translation-en
Hit http://ftp.debian.org jessie-updates/non-free Translation-en
Get:3 http://apt.osmc.tv jessie-devel/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Ign http://apt.osmc.tv jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Ign http://apt.osmc.tv jessie-devel/main Translation-en
Fetched 4413 B in 17s (253 B/s)
E: dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’ to correct the problem.
Updating libshairplay
Restarting system
Your system did not update properly. You can only try the new libshairplay with the Jarvis beta
Nonetheless, I’m not particularly convinced this will resolve iOS AirPlay streaming. That’s part of the reason why we are working on more open technologies like A2DP
Hi, i’m trying the jarvis RC3 build on a RPi2, and it seems to be all working for my needs, except for non-linear stretch (i checked with a square grid video and there is no difference between non-linear stretch and force 16:9 aspect ratio).
This option is working on official jarvis build for ubuntu (checked with the same square grid video).
Just to clarify, i’m talking about the option under settings -> video -> playback -> display 4:3 video as…
This worked. Now ios9 audio is running smoothly on rc3. Thanks
Thanks for confirming.
Thanks! This works perfectly now for audio borhon my iphone6 running latest ios9 and also on my mac running latest el Capitan.
I waited a long time (because I’m such a nitwit
No explosions, so far I can see everything works well. I’m really very happy with the Rpi and OSMC.
A big Thanks to the Team!
Just tried to install RC3 again after my issues the other day and I’m now getting the following:
rbp2-mediacenter-osmc
I’m thinking this might be a problem my end as others seem to be ok but are there any suggestions as to what I can try to fix this?
Just wait a few minutes. As said before, this happens when we push new packages to the repository. We only do this for a few minutes each day, but it’s certainly possible you keep trying to update during one of these times.
We will address this in the near future.
