[TESTING] Kodi 17 (Krypton) Beta Builds for all platforms
OK debug info below, not much in the way of an error, i can see it is trying to cache online image when kodi restarts but don’t see anything after that in the log, it just stops writing. i checked the path in my browser and the image exists, i was following through the log as i was scrolling through my movie library, and it seems it doesn’t always crash in this scenario, sometimes where the fanart.jpg is missing it successfully grabs and caches the image from the net, perhaps the problematic ones are large images? (the example is, filled my screen hi-res in Firefox)
17:16:46.855 T:3000797056 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:16:46.858 T:3000797056 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
17:16:46.899 T:2990537536 DEBUG: CCurlFile::GetMimeType - http://image.tmdb.org/t/p/original/vdK1f9kpY5QEwrAiXs9R7PlerNC.jpg → image/jpeg
17:16:46.900 T:2990537536 DEBUG: CurlFile::Open(0xcd21f68) http://image.tmdb.org/t/p/original/vdK1f9kpY5QEwrAiXs9R7PlerNC.jpg
17:16:46.926 T:2694839104 DEBUG: CCurlFile::GetMimeType - http://image.tmdb.org/t/p/original/bGpguMT9LtJXFeSietuX40mjfuu.jpg → image/jpeg
17:16:46.927 T:2694839104 DEBUG: CurlFile::Open(0x111c4d30) http://image.tmdb.org/t/p/original/bGpguMT9LtJXFeSietuX40mjfuu.jpg
17:16:46.966 T:3000797056 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:16:47.070 T:3000797056 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
17:16:47.970 T:2990537536 DEBUG: Caching image ‘http://image.tmdb.org/t/p/original/vdK1f9kpY5QEwrAiXs9R7PlerNC.jpg’ to ‘4/4ac0eafe.jpg’:
UPDATE
it appears to be a combination of size of image and grabbing online, i manually saved the poster and fanart to the folder 3835x2160 and 2000x3000 respectively and didn’t get any issue when scrolling to it through my library, Kodi cached them and displayed poster and fanart without issue
There was such option in some version of libcec (newer or older than 4.0 I cant remember) but for me it wasn’t stopping live tv…
But anyway what I was reporting is that it is wierd that the same version of libcec is showing different option.
Hi Guys I have this problem… sometimes when I restart my rpi3 osmc reset the default skin and configuration. this is the kodi logs http://paste.osmc.io/hihekutiqo
Can u help me please?
complete logs is here http://paste.osmc.io/olilarajil
i have hifiberry dac+ too
Last thing… i edited the node’s movie like in this guide http://kodi.wiki/view/Music_concerts
Hi Sam,
did not works in my case. Clean install on RPI3; browsing the addons is slow as hell.
Steps to reproduce:
1, Install Youtube addon
2. Go in the section “Popular right now”
3. Go next page for a couple of pages
4. Going back (the system seems that re-query the previous page instead to have it in cache)
Very annoying compared with Kodi 16 that the browsing it is immediate in case of backward direction or in any cached situation.
Do someone else suffer this?
by
Den
This behavior is a “feature” introduced by Kodi itself for v17. You should address the issue with them.
http://forum.kodi.tv/showthread.php?tid=305757&pid=2516038#pid2516038
I have reported this issue serval times.
It happen even with an other SD card, other PI3, other power supply, fresh install each time.
Thx ActionA
applying the tweak indicated in your post it fix the browsing (somehow); still present however when a video is terminating from an addon (youtube in my test), the system still thinking a while instead to give immediately the last menu when the video was selected.
I’ve post my issue in Kodi forum of course; just post here to see if other folks have the same issue of me.
by,
den
ah ok… so i have to wait
Is there a way to enable debug mode from command line?
Just updated to krypton getting sad face loop need debug to find out which add-on is causing it.
Pass --debug in mediacenter watchdog
Thanks Sam I’ll try that
Hi !
Upgraded OSMC on RPI3 today everything seems to work, but the Picture Screensaver does not show pictures, just spinning wheel.
This is in the logs:
19:31:29.523 T:1866462192 ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_ErrorStreamCorrupt, Bitstream corrupt
19:31:29.523 T:1524626416 ERROR: COMXCoreTunel::Deestablish - Error WaitForCommand port 60 on component OMX.broadcom.image_decode omx_err(0x8000100b)
19:31:30.718 T:1866462192 ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_ErrorStreamCorrupt, Bitstream corrupt
19:31:30.718 T:1467479024 ERROR: COMXCoreTunel::Deestablish - Error WaitForCommand port 60 on component OMX.broadcom.image_decode omx_err(0x8000100b)
19:31:33.447 T:1524626416 ERROR: COMXCoreComponent::WaitForOutputDone OMX.broadcom.image_encode wait event timeout
19:31:33.447 T:1524626416 ERROR: COMXReEnc::ReEncode smb://MEDIASERVER/mediaserver/Bilder/Gemeinsame Bilder/2015-02/P1070461.JPG m_omx_encoder.WaitForOutputDone result(0x80001011)
19:31:35.563 T:1524626416 ERROR: COMXCoreComponent::WaitForInputDone OMX.broadcom.image_decode wait event timeout
19:31:38.352 T:1524626416 ERROR: COMXCoreComponent::WaitForOutputDone OMX.broadcom.image_encode wait event timeout
19:31:38.352 T:1524626416 ERROR: COMXReEnc::ReEncode smb://MEDIASERVER/mediaserver/Bilder/Gemeinsame Bilder/2015-02/P1070462.JPG m_omx_encoder.WaitForOutputDone result(0x80001011)
I can view these images directly from SMB in the Pictures section of KODI.
Same images worked fine in stable OSMC.
Anything I could do ?
You have thousands of these errors:
10:30:03.972 T:1432351728 ERROR: SQL: [Textures13.db] Attempt to write a readonly database
and
10:55:36.534 T:1749021680 ERROR: SQL: [Textures13.db] Undefined SQLite error
@Karl_K Do you have an example photo that I can reproduce this error with?
Dear popcornmix !
Image from the log is here:
http://kashofer.org/owncloud/index.php/s/NFpGL91anAxNtH9
There is a space character in the SMB folder path and the folder contains 1209 images.
Anything else i could do ?
Hi popcornmix !
After running for half a day it now works. Maybe it just needed some time to build an index or something like that.
Anyway, please consider solved !
Cheers,
Karl
Krypton Betas are now EOL.
This thread will be shortly closed.
Do I need to remove any repo from apt sources or will this work anyway to switch back to normal release line again?
You should remove the krypton repository.
As usual whenever there is a new update my Vero 1 automatic download and I just click Yes to update, i didn’t know that it will update to kodi 17. Kodi 17 is not stable for me, i have several crashed lately ( sad face ) . Is there a way to rolled back the updated?
