Just connect via ssh and grab-logs -A
add-on crash log, hope its of use.
One thing Iâve notice is its random, I can click on addon sometimes and the add-on works, but more than often it will crash.
http://paste.osmc.io/ovitafolet
Also IMDb issue seems fixed
Commandline: apt-get upgrade
Upgrade: wireless-firmware-osmc:armhf (1.1.1, 1.1.2), rbp-bootloader-osmc:armhf (1.2.8-1, 1.2.9-1), mediacenter-addon-osmc:armhf (3.0.614, 3.0.617), base-files-osmc:armhf (1.9.3, 1.9.4), armv7-remote-osmc:armhf (1.2.0, 1.2.1), rbp-userland-osmc:armhf (1.2.0-1, 1.2.0-4), perftune-osmc:armhf (1.1.8, 1.2.0), armv7-eventlircd-osmc:armhf (1.1.9, 1.2.0), diskmount-osmc:armhf (1.4.3, 1.4.4)
End-Date: 2016-06-19 22:30:56
Why do you continue running apt-get upgrade?! Weâve stated hundreds of times that one should ONLY use dist-upgrade with OSMC.
Also, itâs unlikely weâll be able to provide support with the sheer amount of 3rd party glut that youâve installed. Youâll first have to prove that this issue exists on a clean install without all the rest which we will not provide support for.
No problem, I appreciate that I have a lot of 3rd party addons, and have everything backed up so will do a clean install.
Regards apt-get, it does both, dist and normal, just hadnât updated my script, it will only do dist-upgrade now.
Perhaps it makes sense to modify apt so that upgrade works as dist-upgrade if apt-get upgrade is so wrong.
Sounds good â but we havenât got a good solution for that yet. If you have one I am happy to accept a PR on this.
16.8-104, 23 June 2016: Based off OSMC commit (8a564100) and newclock5 (2474eeec)
Build Highlights
newclock5
New commits in this build:
squash: mmalcodec: Improve stalls with EOS handling with dvd menus (2474eeec)
16.8-105, 26 June 2016: Based off OSMC commit (1fbf4ac) and newclock5 (8488513)
Build Highlights
OSMC
Use OSMC mirror system for Kodi addon repository (1fbf4ace)
newclock5
VideoPlayer: expose stream player info to GUI (d2165e95)
remove DataCacheCore from systemGlobals (e12400a5)
squash me (84bb6072)
VideoPlayer: Initialise datacache codec info (bcd8fb95)
rbp: Update to use new processInfo data cache (5bc92c98)
Updated commits in this build: ()
codecoverlay: Include codec name in overlay (77da5a79)
Commits no longer in build:
squash: mmalcodec: Improve stalls with EOS handling with dvd menus (c7be9ac6)
Was about to start a clean install,but quickly checked out the latest build before doing so.
Great news, all my addons are working again, save a lot of hassle.
Regards bm
Great news - thanks for the feedback. Lets hope they stay working
16.8-106, 27 June 2016: Based off OSMC commit (1fbf4ac) and newclock5 (5d5a067)
Build Highlights
newclock5
fixup! rbp: Update to use new processInfo data cache (b0da4dff)
fixup! codecoverlay: Include codec name in overlay (6ed458bc)
16.8-107, 28 June 2016: Based off OSMC commit (1fbf4ac) and newclock5 (0d58585)
Build Highlights
newclock5
ffmpeg: Bump to v3.1 (0d58585e)
16.8-108, 01 July 2016: Based off OSMC commit (1fbf4ac) and newclock5 (6910a17)
Build Highlights
newclock5
ffmpeg: hacky fix for files with GMC (ce0970ba)
mmalcodec: Clear flags before returning picture (e8583ac9)
mmalrenderer: Execute callbacks from main thread (e678bd25)
mmalcodec: Add interlace state to mmal video buffer (2ea8de97)
mmalrender: Improve logging for pool creation (a0e8061b)
mmalrender: Switch to user flag 3 for submitted pictures (6910a17e)
16.8-109, 02 July 2016: Based off OSMC commit (1fbf4ac) and newclock5 (6910a17)
Build Highlights
mmalffmpeg: Move gpu image pool into a separate class (8801d8ec)
fixup! mmalrenderer: Execute callbacks from main thread (bc482f41)
16.8-110, 03 July 2016: Based off OSMC commit (1fbf4ac) and newclock5 (cfaaa84)
Build Highlights
UNSTABLE: This is a placeholder. Commits after this point are considered experimental. (2be4a48f)
mmalcodec: Remove deinterlace support (cfaaa84e)
- added setting for allowing to hide watched movies/episodes/musicvideos in the recently added lists of the home screen (5a17c2b9)
- evaluate the setting for hiding watched movies/episodes/musicvideos in recently added job (should influence homescreen of skins only) (dfd94334) (- evaluate the setting for hiding watched movies/episodes/musicvideos⌠¡ popcornmix/xbmc@dfd9433 ¡ GitHub) (should)
VideoPlayer: expose stream player info to GUI (8f308653)
remove DataCacheCore from systemGlobals (4ff45b99)
rbp: Update to use new processInfo data cache (69807329)
Hi everyoneâŚi am new user here. I have few queries that way to check that update is correct is to check the
mediacenter version versus 16.8, is there any impact on addon/skins? I am using the Aeon Nox 5 Silvo and there is a Jarvis and a Krypton version. with the 16.8 and not 17.0, will all addon be able to update/run as intended?
You will want to install the Krypton version.
16.8-111, 05 July 2016: Based off OSMC commit (1fbf4ac) and newclock5 (3cfdcaf)
Build Highlights
rbp: Update transposed video scaling to match other platforms (c3d89555)
mmalcodec: Add another buffer when deinterlacing (26a4c6d9)
16.8-112, 09 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (0c917bac)
Build Highlights
ffmpeg: bump 3.1.1
osmc
Fix: Use OSMC mirror system for Kodi addon repository
Bootloader: Version Bump
Userland: Version Bump
newclock5
rbp: Update the GL libs to new naming scheme (4a82137c)
omxvideo: Remove call to AutoInterlaceMethod. Treat auto as advanced (a05eac75)
mmal_codec: Use EOS through codec to determine drain is complete (3676c884)
16.8-113, 10 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (0a4b593)
Build Highlights
newclock5
[librtmp] Update to 15-Dec-2015 from Audio/video stream recording forums (1775c609)
mmaldec: Enable zero copy on decoder input buffers (35a89069)
