16.8-114, 11 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (2e0b2fa60)
Build Highlights
newclock5
New commits in this build:
mmalrender: Use flag in omvb structure for detecting submitted pictures (14d9fa1e)
mmalrender: Use quit packet to stop render thread (592724d3)
mmalrender: Reduce number of opaque pool elements (f9ff3f99)
mmalrender: Add lock around UnInit function (2e0b2fa6)
Commits no longer in build:
mmalrender: Switch to user flag 3 for submitted pictures (9f6909b5)
16.8-116, 14 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (3ef2af1)
Build Highlights
newclock5
mmal: Move decoded picture pool from renderer to decoder (e3f14217)
MMAL: Remove renderer pointer from codecs (c87ad6dd)
mmal: Move pool creation to open (1d48967b)
mmal: Keep references to pools to ensure they are lazily destroyed (a5cc4539)
mmal: Include buffer encoding in buffer objects (8ef538ae)
MMALRender: Configure mmal lazily as packets are received (3ef2af1b)
Hey guys! I installed the test build last night. Everything seems to be working great except the ability to install addons. It caches the repos fine but when I go to install, I just get 404 errors. I set a static DNS and afaik all other features using Internet are functioning fine.
Edit: when I click install on an addon , nothing happens. The 404 errors I’m seeing are from the log.
Do you know if any work is being done to the libraries at the moment, since last update all the wrong artwork is being pulled for thumbs and posters, etc.
I can post some logs, but doubt they’ll be of any use.
Also struggling to download from the kodi repo at the moment, I can enter it, but nothing will download, other repos seem ok. do you know anything about this?
Other than that its been really stable for a couple of week now.
16.8-117, 15 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (4b67854)
Build Highlights
newclock5
mmalrenderer: Execute callbacks from dedicated thread (9c7a46ab)
mmal: Remove renderer pointer from codecs (4b60091c)
mmalrender: Configure mmal lazily as packets are received (ca7d9d10)
mmalrender: Include dimensions in init_vout (4b67854f)
VideoPlayer: continue normal playback if seek fails (2ab6be44)
mmalrenderer: Execute callbacks from main thread (54f7015e)
mmalcodec: Add interlace state to mmal video buffer (e3361c56)
I’ve checked the official Kodi mirrors and the md5’s don’t exist there either. Can’t find any recent patches which could have caused this so its really odd.
I did manage to find a workaround - probaly not recommended for everyone until I work out where the issues comes from, but if you want to:
16.8-118, 16 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (fad1bc8)
Build Highlights
newclock5
Updated commits in this build:
mmalrender: Configure mmal lazily as packets are received ca7d9d10 => (fad1bc8b)
mmalrender: Move change of configuration check to new function (42db655c)
mmalrender: Use quit packet to stop render thread (1b3d02a3)
mmalrender: Add lock around UnInit function (5e1c69e5)
16.8-118, 17 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (50103c4)
Build Highlights
newclock5
mmalrender: More verbose logging (d61115c0)
mmalcodec: Remove deinterlace support (e869d12c)
mmalrender: Add deinterlace support (138692f4)
mmalrender: Avoid accessing port that may have been destroyed (50103c46)
Updated commits in this build: ()
mmalrenderer: Execute callbacks from dedicated thread (5c3a7299)
mmal: Move pool creation to open (2a731519)
