16.8-122, 20 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (752ee114)
16.8-123, 21 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (5eb4c1f)
newclock5
New commits in this build:
mmalffmpeg: Enable thread safe callbacks (503eaeb5)
mmal: Switch to a pool class attached to decoder output (0cf9bc86)
mmal: Fix some ugliness with acquire/release of video buffers (4ab31392)
mmalrender: Add sharpness control (5eb4c1fa)
Updated commits in this build:
mmalcodec: Remove deinterlace support (d63ad6be)
mmal: Remove renderer pointer from codecs (0c0a578d)
mmalrenderer: Execute callbacks from dedicated thread (d6b31e9a)
mmalrender: Add deinterlace support (54122fb1)
mmalrender: Allow a frame of slop when waiting for vsync (73faeea0)
mmalrender: Use computed framerate rather than version from configure (d89bf5c3)
Commits no longer in build:
mmalrender: Improve logging for pool creation (4e779a84)
mmal: Include state in CMMALBuffer (a363551f)
mmalrender: Use flag in omvb structure for detecting submitted pictures (8747f5b4)
mmalffmpeg: Move gpu image pool into a separate class (3aa899f1)
16.8-124, 22 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (e1254c45)
newclock5
mmalcodec: Use lock Leave rather than SingleExit (0afa7d8b)
rbp: Make debug message wrap safe (ea043e55)
mmalcodec: Clear flags before returning picture (b85906be)
16.8-125, 23 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (e1254c45)
inputstream.mpd and inputstream.smoothstream updates
16.8-126, 24 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (97b4cac)
Build Details
newclock5
VideoPlayer: drop deinterlace mode (4402163b)
rbp: drop deinterlace mode (97b4cace)
hey gmc got some logs for ya the latest revisions are pretty unstable
but thats what i expect
http://paste.osmc.io/kuxesabaru
http://paste.osmc.io/yuvebuzuva
What are the actual symptoms?
You also need to turn on debug logging.
17:20:17 116798.390625 T:1587540976 NOTICE: CVideoPlayerAudio::Process - stream stalled
17:20:17 116798.507812 T:1614803952 NOTICE: CVideoPlayer::OnExit()
Connection OK?
Symtoms are that when i press play on new vid it crashes and yes LAN is stable and working so its not that.
Gonna enable debugging later on tonight see if i cant recreate it
New version upped - maybe it magically fixes it
16.8-127, 25 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (e5354526)
Build Details
[WIP] Double the backslash in mysql in case weāre in āLIKEā)
hey guys,
I am having some troubles. I have a Pi 3 and trying to install new kodi v17. This is the error i get:
root@CarPi:~# sudo apt-get install rbp2-medicenter-osmc
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
rbp2-mediacentre-osmc : Depends: niceprioritypolicy-osmc but it is not installable
Depends: medicacenter-send-osmc but it is not installable
Depends: mediacenter-addon-osmc (>= 3.0.39) but it is not installable
Depends: medicenter-skin-osmc but it is not installable
Depends: diskmount-osmc (>= 1.2.9) but it is not installable
Depends: armv7-libnfs-osmc but it is not installable
Depends: armv7-librtmp-osmc but it is not installable
Depends: armv7-libshairplay-osmc but it is not installable
Depends: armv7-libsqlite-osmc but it is not installable
Depends: armv7-splash-osmc but it is not installable
Depends: armv7-libcrossguid-osmc but it is not installable
E: Unable to correct problems, you have help broken packages.
my /etc/apt/sources.list is as follows:
deb Index of /raspbian jessie main contrib non-free rpi
deb-src http://archive.raspbian.orb/raspbian/ jessie main contrib non-free rpi
deb Index of /pipplware/dists/jessie/main/binary /
deb Index of /osmc/osmc/download/dev/gmc /
I have tried deb Index of /osmc/osmc/download/dev/gmc ./ with the same result
I have also tried with the previous versions and the same result
I am not sure if i am doing something wrong or what. Can anyone please help?
Looks like you removed the official OSMC apt repo from sources.list. Add that and run apt-get update
thanks for that but what is the official osmc apt repo?
thanks Sam, i found it and it is now installing
deb http://apt.osmc.tv jessie main
for others that may need it
16.8-128, 26 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (2781aa6)
Build Details
newclock5
AE: change usage of swr_set_compensation (1267f20f)
AE: refactor resample buffers (0d0a6bb8)
AE: add ffmpeg atempo filter (9f8880dc)
VideoPlayer: improve rr related to clockspeed (19751dee)
squash atempo (d337b728)
squash: log atempo (7c53c790)
squash atempo (3e15691b)
mmalrender: Disable deinterlace when no interlaced frames seen (2781aa6d)
16.8-129, 27 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (2b61f97)
Build Details
newclock5
16.8-130, 28 July 2016: Based off OSMC commit (ef17c0ad) and newclock5 (9b3d30)
Build Details
newclock5
rbp: Ensure processinfo values are initialised (9b3d3050)
16.8-131, 29 July 2016: Based off OSMC commit (6fb6f6e) and newclock5 (ce09b96)
Build Details
([PVR] Fix recordings resume playback context menu handling; drop mmalrender commit)
newclock5
Revert āmmalrender: Disable deinterlace when no interlaced frames seenā (ce09b960)
16.8-132, 31 July 2016: Based off OSMC commit (6fb6f6e) and newclock5 (7c60f60)
Build Details
newclock5
AE: change usage of swr_set_compensation (fdbbe340)
AE: refactor resample buffers (9847f84f)
AE: add ffmpeg atempo filter (8a86319f)
VideoPlayer: improve rr related to clockspeed (ac7413ca)
squash atempo (afdaf706)
fixup! [ae] Add debug logging showing resamplerate (7c60f60d)
