16.8-134, 02 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (e36cf0dd)
Build Details
libcec
added: cec_command::Size() and missing const for cec_command::PushArray() (dd71529e)
fixed: refresh the locally cached physical address in CCECClient::SetPhysicalAddress() in all situations (f32bcb65)
fixed: don’t block on a poll in CCECProcessor::Transmit() when m_bStallCommunication is flagged (e9556174)
fixed: refresh the cached physical address before assigning a logical address to libCEC in CCECProcessor::AllocateLogicalAddresses() (1e3fe62d)
fixed: reset the TV state when CCECProcessor::HandleLogicalAddressLost() is called and don’t update the physical address while communication is stalled in CCECProcessor (6366b42e)
changed: removed unused method from the internal adapter api (ab6e97fb)
Constant bootloops after todays upgrade, cant even ssh into my system, it wont load that far.
Basically ended up doing a clean install, and as soon as i upgrade, i get the bootloop again.
Tried clean installing an older version 133, and still get stuck in a bootloop which is strange as that version was working fine.
I’m thinking it may be something to do with the other files that upgraded today cec something, sorry didnt make a note.
Anyway Im stuck as cant go back to v16, library is to committed to v17 now…
Is there anyway i can install v17 without the other files? maybe version 133?
I tried again this morning with a new sd card 8gig sandisk, installed version 16 thru installer with no problems, all working fine.
Updated my sources.list file, and ran apt-get update; apt-get dist-upgrade, after upgrade i rebooted.
Starts to load, splash screen appears for about 2sec, and then sad face and reboot, and this just loops continuously.
Aug 05 20:06:32 BedRoom mediacenter[373]: Starting Kodi...
Aug 05 20:06:32 BedRoom sudo[501]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
Aug 05 20:06:32 BedRoom sudo[501]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
Aug 05 20:06:32 BedRoom mediacenter[373]: Unable to find path to Kodi data files!
I had a look through the threat and could see anything mentioned about profiles either. If I try and log off or log in with enable login page Kodi completely hangs. I have included logs. It seems osmc.settings causes the issue
