delete your .kodi folder in your home directory… seems like you all missed that comment too
What and wait for days for it to resync artwork etc. for over 2000 films and 10000 tv episodes I think not! maybe you can shed some light on what specifically in the .kodi folder is at issue.
Spart
Settings.
Help needed:
I updated the default OSMC with the commands in first posting. All works fine with no errors. But restarting the system. I get now first the OSMC start screen and than a sad smily. I checked the version with the command mentioned - and it’s the latest.
What can I do to find the error? Where can I find additional infos for you to inspect?
BTW. I also wanted to check if with OSMC and Kodi17 Amazon prime will work. Does I need additional installations like the ibssd_wv-lib or is it now integrated in OSMC as I read in an earlier post? Or do you suggest to use the ready to use LIBREelec from @Milhouse?
Busy running a new build now - will be uploaded tomorrow.
I’m not sure what the problem is for the issues above but hopefully the new build sorts it out.
We need a log to know what’s going on. This is covered in the Wiki.
inputstream is included, so if you install the Widevine libs and one of the Prime add-ons, you should see success.
So is it just the libs in or is there any guides on installing widevine etc?
16.8-135, 04 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (7d73469)
Build Details
libcec:
added: enduring events (long press) in eventghost. fixes #188 (240b195c)
Merge branch ‘PR:192’ into v4 (44a3d14c)
added: TransmitSystemAudioModeRequest() (1157d109)
fixed: send a when an avr is found and the source is activated (73546ee1)
Merge branch ‘PR:208’ into v4 (4c75c4de)
Fix TDA995x check, part 2 (2bd62826)
TDA995x: Add missing std:: namespace (85709f47)
Merge branch ‘PR:214’ into v4 (511163e7)
Fall back to look for libudev.pc if udev.pc is not usable (298e62bd)
Merge branch ‘PR:231’ into v4 (66deb68d)
Merge branch ‘v4’ (0f2be44e)
added: EnableAudio() API command (f7551592)
added: udev rule to prevent modemmanager and mtp from probing the CEC adapter, which prevents it from working right after it gets plugged in (71dbfcdc)
fixed: missing param check in TransmitSystemAudioModeRequest() in Commit:1157d10 (62b8520c)
inputstream.mpd:
UTC->time_t conversion fix (241071c0)
compile fix timegm / transport library path to decrypters (e15a8fed)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (52011be4)
load wv from library path (63fca155)
version bumps (92a1cacf)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (cf0aed9c)
don’t use timegm as it is no std and fails for DROID_32 (ee05c4c3)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (64719729)
include fix (1a282a5c)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (e9f82b6a)
static expat binding (ed3eb821)
Merge branch ‘master’ of https://github.com/mapfau/inputstream.mpd (44447b07)
inputstream.smoothstream:
version bumps (8da4fa88)
expat static binding (b63ecbb4)
Please let us know if this resolves the issue with the crash on startup.
The crash on startup is fixed - at least at my fresh intallation. But I still have no luck on playing Amazon Prime videos.
Either I get the error “InputStream MPEG DASH: Could not open / parse mpdURL” when I don’t use the libssd_wv.so or I get the error “undefined symbol: EnableStreamAtPTS” when copying the library to ~/.kodi/cdm
It looks like you need libssd_wv.so and libwidevinecdm.so. This was taken from http://nmacleod.com/public/libreelec/getwidevine.sh (Milhouse’s website).
Do you have both libs?
If so – I’ll ping Milhouse and ask him what’s up.
Yes, Sam, I do have both libs. Looks like there is som API change somewhere.
Below the relevant logs - the first one with input stream mpd from kodi, the second onw with
inputstream.mpd-999.1.2.3.zip
Holger
Log 1
00:26:28 163.840363 T:1446179824 NOTICE: [Amazon] Args: asin="B00FN1XP44", mode="play", name="Forrest Gump", sitemode="PLAYVIDEO", adult="0", trailer="0", selbitrate="0" 00:26:29 164.122162 T:1446179824 NOTICE: [Amazon] getURL: https://www.amazon.de/gp/deal/ajax/getNotifierResources.html 00:26:29 164.483887 T:1446179824 NOTICE: [Amazon] getURL: https://www.amazon.de/gp/video/streaming/player-token.json?callback=onWebToken_364 00:26:29 164.914047 T:1446179824 NOTICE: [Amazon] getURL: https://atv-eu.amazon.com/cdp/catalog/GetPlaybackResources?asin=B00FN1XP44&deviceTypeID=AOAGZA014O5RE&firmware=1&deviceID=287c84469acd0252538a1062b69fb387d3abad81370cd53947a1331e&marketplaceID=A1PA6795UKMFR9&format=json&version=1&titleDecorationScheme=primary-content&resourceUsage=ImmediateConsumption&consumptionType=Streaming&deviceDrmOverride=CENC&deviceStreamingTechnologyOverride=DASH&deviceProtocolOverride=Http&audioTrackId=all&videoMaterialType=Feature&desiredResources=AudioVideoUrls%2CSubtitleUrls 00:26:30 165.571609 T:1446179824 NOTICE: [Amazon] Convert German Subtitle 00:26:30 165.573578 T:1446179824 NOTICE: [Amazon] getURL: http://dmqdd6hw24ucf.cloudfront.net/7185/a455/631f/4fbe-92c6-746bd584c2fd/56801dfd-45e1-4cc0-88be-6456696e4bbe.dfxp 00:26:33 168.919998 T:1446179824 NOTICE: [Amazon] Convert English Subtitle 00:26:33 168.921722 T:1446179824 NOTICE: [Amazon] getURL: http://dmqdd6hw24ucf.cloudfront.net/4fd5/a2c0/c933/4c44-a692-2ddb518fa241/76305e90-fec5-436f-9102-9d34736f447d.dfxp 00:26:39 174.200623 T:1446179824 NOTICE: [Amazon] Using Host: Level3 00:26:39 174.201569 T:1446179824 NOTICE: [Amazon] http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC807AF/videoquality$1080p/prod/18fe/5f85/c96a/4012-8979-3f0c91f7040c/36edb0f0-78dd-48ee-bd3a-b5e2eb97e312_corrected.mpd 00:26:39 174.846848 T:1958592512 NOTICE: VideoPlayer: Opening: http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC807AF/videoquality$1080p/prod/18fe/5f85/c96a/4012-8979-3f0c91f7040c/36edb0f0-78dd-48ee-bd3a-b5e2eb97e312_corrected.mpd 00:26:39 174.847443 T:1958592512 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 00:26:40 175.185455 T:1429402608 NOTICE: Creating InputStream 00:26:41 176.487030 T:1429402608 ERROR: AddOnLog: InputStream MPEG DASH: Could not open / parse mpdURL (http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC807AF/videoquality$1080p/prod/18fe/5f85/c96a/4012-8979-3f0c91f7040c/36edb0f0-78dd-48ee-bd3a-b5e2eb97e312_corrected.mpd) 00:26:41 176.488129 T:1429402608 ERROR: CVideoPlayer::OpenInputStream - error opening [http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC807AF/videoquality$1080p/prod/18fe/5f85/c96a/4012-8979-3f0c91f7040c/36edb0f0-78dd-48ee-bd3a-b5e2eb97e312_corrected.mpd] 00:26:41 176.488297 T:1429402608 NOTICE: CVideoPlayer::OnExit() 00:26:41 176.497803 T:1958592512 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.amazon/?asin=<B00FN1XP44>&mode=<play>&name=<Forrest+Gump>&sitemode=<PLAYVIDEO>&adult=<0>&trailer=<0>&selbitrate=<0>] 00:26:41 176.518478 T:1958592512 NOTICE: CVideoPlayer::CloseFile() 00:26:41 176.518738 T:1958592512 NOTICE: VideoPlayer: waiting for threads to exit 00:26:41 176.518845 T:1958592512 NOTICE: VideoPlayer: finished waiting 00:26:41 176.520462 T:1958592512 NOTICE: CVideoPlayer::CloseFile() 00:26:41 176.520676 T:1958592512 NOTICE: VideoPlayer: waiting for threads to exit 00:26:41 176.521118 T:1958592512 NOTICE: VideoPlayer: finished waiting
Log 2
22:18:14 1572.759644 T:1938813936 NOTICE: [Amazon] Args: asin="B00FN1XP44", mode="play", name="Forrest Gump", sitemode="PLAYVIDEO", adult="0", trailer="0", sel 22:18:15 1572.990967 T:1938813936 NOTICE: [Amazon] getURL: https://www.amazon.de/gp/deal/ajax/getNotifierResources.html 22:18:15 1573.371216 T:1938813936 NOTICE: [Amazon] getURL: https://www.amazon.de/gp/video/streaming/player-token.json?callback=onWebToken_329 22:18:16 1573.824097 T:1938813936 NOTICE: [Amazon] getURL: https://atv-eu.amazon.com/cdp/catalog/GetPlaybackResources?asin=B00FN1XP44&deviceTypeID=AOAGZA014O5R 22:18:16 1574.289673 T:1938813936 NOTICE: [Amazon] Convert German Subtitle 22:18:16 1574.291748 T:1938813936 NOTICE: [Amazon] getURL: http://dmqdd6hw24ucf.cloudfront.net/7185/a455/631f/4fbe-92c6-746bd584c2fd/56801dfd-45e1-4cc0-88be-64 22:18:20 1578.395874 T:1938813936 NOTICE: [Amazon] Convert English Subtitle 22:18:20 1578.398071 T:1938813936 NOTICE: [Amazon] getURL: http://dmqdd6hw24ucf.cloudfront.net/4fd5/a2c0/c933/4c44-a692-2ddb518fa241/76305e90-fec5-436f-9102-9d 22:18:27 1584.887573 T:1938813936 NOTICE: [Amazon] Using Host: Level3 22:18:27 1584.888306 T:1938813936 NOTICE: [Amazon] http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC86ED1/videoquality$1080p/prod/18fe/5f85/c96a/4012-89 22:18:27 1585.345215 T:1958850560 NOTICE: VideoPlayer: Opening: http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC86ED1/videoquality$1080p/prod/18fe/5f85 22:18:27 1585.345825 T:1958850560 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 22:18:27 1585.625854 T:1541403632 NOTICE: Creating InputStream 22:18:27 1585.636230 T:1541403632 NOTICE: ADDON: Loaded virtual child addon special://temp/inputstream.mpd-1.3 22:18:27 1585.643433 T:1541403632 ERROR: Unable to load /home/osmc/.kodi/temp/inputstream.mpd-1.3, reason: /home/osmc/.kodi/temp/inputstream.mpd-1.3: undefine 22:18:37 1595.532593 T:1541403632 NOTICE: Creating Demuxer 22:18:38 1596.631836 T:1541403632 ERROR: Open - error probing input format, http://s3.lvlt.dash.eu.aiv-cdn.net/d/1$AOAGZA014O5RE,5CC86ED1/videoquality$1080p/p 22:18:38 1596.633301 T:1541403632 ERROR: OpenDemuxStream - Error creating demuxer 22:18:38 1596.634155 T:1541403632 NOTICE: CVideoPlayer::OnExit() 22:18:38 1596.637573 T:1958850560 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.amazon/?asin=<B00FN1XP44>&mode=<play>&name= 22:18:38 1596.639282 T:1958850560 NOTICE: CVideoPlayer::CloseFile() 22:18:38 1596.639526 T:1958850560 NOTICE: VideoPlayer: waiting for threads to exit 22:18:38 1596.639771 T:1958850560 NOTICE: VideoPlayer: finished waiting 22:18:38 1596.644653 T:1958850560 NOTICE: CVideoPlayer::CloseFile() 22:18:38 1596.644897 T:1958850560 NOTICE: VideoPlayer: waiting for threads to exit 22:18:38 1596.645020 T:1958850560 NOTICE: VideoPlayer: finished waiting
Milhouse says:
Is he using the latest inputstream.mpd and Kodi? There have been a few API related changes to inputstream.mpd over the last few days
We may need to update inputstream.
I added some more info above, Sam.
Does… [quote=“sam_nazarko, post:443, topic:14628”]
[/quote]
… mean it should be done at your side?
Holger
I can confirm the latest build stops the crash on boot
Thanks!
I´ve been on LibreELEC since the boot loop crash on OSMC. LibreELEC is not as fast and smooth as OSMC is on RPI3.
I moved across as well…i’m impatient.
But Millhouse nightlies are awesome.
Chrikey, we only had broken builds for two days…
Anyway, glad to hear everything is resolved now.
There are a few more inputsteam updates which will be included in the next nightly.
Thanks, I will wait patiently;-)
Holger
