Latest solved the Sad Face loop for me too.
Spart
Spart
Thanks for your hints. The installation is now working after new update :).
Quick question, Iāve upgraded my OSMC to the latest Krypton test build 16.8-136, but one thing I canāt quite tell:
is there support for RetroPlayer in this build?
Otherwise itās looking great so far
RetroPlayer is expected to come in v18, there will be nightlies with it after Krypton.
Thanks @sam_nazarko. I was hoping the Krypton test build had somehow incorporated some of the RetroPlayer builds (which you understandably put on pause). Iām not sure why I thought that, given that RetroPlayer is currently another branch of Kodi and hasnāt been merged with the main branch.
Looking forward to seeing all of it (Krypton, RetroPlayer, etc.) come together! Thanks for your hard work ![]()
16.8-136, 09 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (41d57db1)
Build Details
Estuary skin sync
Fix āroute addā error with OpenVPN
Stop enabling peripheral.* addons at startup
VideoPlayer sync fix
newclock
New commits in this build:
RenderSystemGLES: Remove unused abs64 function (f75fd8bb)
Commits no longer in build:
VideoPlayer: remove some dead code (fb24e79b)
AE: change definition of AEStream::GetCacheTime (2d56cfa9)
VideoPlayer: fix early stall of audio stream, sync is now in AE (92fd0c79)
Adapt build files (TODO: changes for XCode) (ac082929)
inputstream.mpd:
fix entry position into livestreams for dynamic templates (41d9351a)
Merge branch āmasterā of https://github.com/mapfau/inputstream.mpd (b0b23302)
zattoo like stream support (ccd5b255)
Merge branch āmasterā of https://github.com/mapfau/inputstream.mpd (cbc51c15)
16.8-137, 13 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (9aad736)
Build Details
LibCEC bump to 3.1.1-2
inputstream.mpd:
Use 64-bit integer for timestamp (aba30506)
fixed some mpd situations (c69be0b2)
Merge branch āfixesā (73b9836c)
Merge branch āmasterā of https://github.com/mapfau/inputstream.mpd (7898a672)
peripheral.joystick:
Rumble and controller power off (PR:43, 3 commits, 13 files changed)
newclock5:
rbp: Fix up settings group for supportmvc (a37610e8)
RenderSystemGLES: Remove unused abs64 function (a18a952e)
16.8-138, 14 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (9aad736)
Build Details
XBMC:
player: fix action controlled ff/rw for the case tempo is active (PR:10276, 1 commit, 1 file changed)
paplayer: interims fix for speed while paused (PR:10277, 1 commit, 1 file changed)
Add USB ID for WeTek Core remote (PR:10279, 1 commit, 1 file changed)
[xinput] Move motor definitions to xml file (37c1a28c)
[storage] Move refresh callback out of storage system (75966fa3)
BTW, just noticed, there is no My OSMC addon in the krypton build. Or am I missing something? Browsed the Programs add-ons and didnāt find itā¦
Iāll update to the latest builds, to see if itās there
It only works on the Raspberry or on the Vero too?
Regards
This thread is for Raspberry Pi.
We will produce nightlies for other platforms when Krypton progresses a little more.
16.8-139, 15 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (e2de38)
Build Details
XBMC:
[epg] CEpg::UpdateEntry: Remove wrong error log. Not finding an epg e⦠(PR:10282, 1 commit, 1 file changed)
OpenGL texture mipmapping (PR:8409, 1 commit, 13 files changed)
[DVDVideoCodecIMX] - New implementation (PR:9253, 20 commits, 14 files changed)
[guiinfo] Fix fullscreen osd for non-PVR content. (PR:10281, 1 commit, 1 file changed)
[PVR] Fix PVR channels not working as Kodi startup window (PR:10280, 7 commits, 19 files changed)
[upnp] startup honors user settings. (PR:10249, 1 commit, 1 file changed)
Application: Fix coverity CID 142068 (PR:10290, 1 commit, 1 file changed)
VideoPlayer: clock fixes (PR:10278, 2 commits, 4 files changed)
VideoPlayer: fix a/v sync correction for clock feedback mode (PR:10289, 1 commit, 1 file changed)
[processInfo] reset audio/video codec info (PR:10283, 1 commit, 1 file changed)
[OSX/CoreAudioDevice] - use the alternate method for retrieving the a⦠(PR:10287, 1 commit, 1 file changed)
[osx] media key: send also SDL_KEYUP (PR:10275, 1 commit, 1 file changed)
Fix joystick input while app is in background (PR:10261, 4 commits, 8 files changed)
Iāve seen this before. Try going to addons/addon browser/my addons/all and check that My OSMC is enabled.
16.8-139, 15 August 2016: Based off OSMC commit (6fb6f6e) and newclock5 (b4add8e6)
Build Details
XBMC:
[PVR] Fix home screen channel widget context menu. (PR:10286, 1 commit, 1 file changed)
paplayer: another fix for pause and speed (PR:10291, 1 commit, 1 file changed)
VideoPlayer: fix false positive drop detection for ffmpeg decoder (PR:10284, 1 commit, 2 files changed)
respect start_pts for omx_pts (32-bit) handling in aml (PR:10260, 2 commits, 3 files changed)
settings: Add settings option to control atempo resampling (PR:10234, 1 commit, 10 files changed)
[osx/XBMCHelper] - some fixes (PR:10285, 8 commits, 6 files changed)
[iOS/XMemUtils] - fix pagesize retrieval once and for all for all ios⦠(PR:10294, 1 commit, 1 file changed)
Disable Travis autotools testing and addons. (PR:10292, 2 commits, 1 file changed)
add backward compatibility for AppearanceSettings (PR:10265, 1 commit, 1 file changed)
newclock5:
settings: Add settings option to control atempo resampling (37397b0e)
paplayer: another fix for pause and speed (7ff57aba)
VideoPlayer: fix false positive drop detection for ffmpeg decoder (e2de38e2)
Is it possible to get back to the release version of OSMC for example by editing out the addition to the file /etc/apt/sources.list and then doing a dist-upgrade?
Or is there an apt-get command that can undo my recent dist-upgrade?
I saw mention of commands like this a way up:
sudo apt-get install rbp2-mediacenter-osmc=16.8-134
Is there a number one can plug it that brings back the release version?
sudo apt-cache show rbp2-mediacenter-osmc to determine the v16 versionsudo apt-get install rbp2-mediacenter-osmc=16<version you determined>Been covered plenty of times
Thanks!
When I execute this command I get two separate Version: lines:
Version: 16.8-141
and later:
Version: 16.1.0-16
I assume that I should use the first version code in the install command?
Like:
sudo apt-get install rbp2-mediacenter-osmc=16.8-141
No, 16.8 is the āfakeā number that is used for v17 to make it work with the normal upgrade process.
if you want to go back to v16 the current version is 16.1.0-16
16.8 is used so when I release 17.0 proper, I will supersede gmcās builds and anyone that was on one of his builds will be updated.
