[TESTING] Kodi 17 (Krypton) builds for Raspberry Pi (continued)
Thanks @ActionA.
For the addons/skins, sorry my question was poorly written. As the version will be 16.8 and not 17.0, will addons/skins recognized a Krypton build and propose the correct version? For the proper run/execution of each, I completely understand that I have to check for each important addon before upgrading.
M.
Yes
16.8 is just an internal versioning scheme
Thanks.
Great Support as usual. Thanks everyone. I will think about testing that after checking the very few addons I can’t live without :slight_smile:
M.
16.8-044, 21 March 2016: Based off OSMC commit (7d2f65c) and newclock5 commit (70bc4bc0)
newclock5
New commits in this build:
VideoPlayer: do not disable stream at processing stage (d8e10527)
[pvr] drop PVRFile (70bc4bc0)
Updated commits in this build:
Revert ā€œ[mmalrenderer] Wait for vsync before submitting to mmal when display sync is disabledā€ (9aa99151)
rbp: Support zero copy interface with hevc acceleration (d90887dc)
Commits no longer in build:
build: Add vcsm lib (42262dd1)
rbp: Expose gpu memory allocation functions (f2943014)
[mmalcodec] Avoid double rate deinterlace when not fullscreen or with OSD (13a59e84)
Revert ā€œ[mmalcodec] Avoid double rate deinterlace when not fullscreen or with OSDā€ (9d94cbdc)
ffmpeg: test: increase number of threads (70e191e0)
[3d] Automatically enable 3D for ssif (19e6cd95)
mmalrender: Remove control port (b32ac26e)
MMAL: Remove support for YUV and make the MMAL format more general (8e0173e5)
MMAL: Add zero copy accelerated interface to ffmpeg (93de83e1)
MMALFFPEG: Avoid crash with 10-bit video (1ccd8a35)
16.8-045, 22 March 2016: Based off OSMC commit (7d2f65c) and newclock5 commit (92c4b245)
Highlights
  • Bump version of libcec to 3.1 This should fix the issue with missing libcec files.
  • NOTE: DVD playback remains temporarily disabled
  • Add ServiceManager and ServiceBroker
  • ā€œSync playback to displayā€ now disabled by default
newclock5
Revert ā€œ[rbp] Make sync playback to display the default optionā€ (d915faf4)
rbp: Use common function with lock for gencmds (3504816f)
ProcessInfo: Move AllowDTSHDDecode into Processinfo (d9b4477f)
stereoscopicmanager: Don’t treat mono as stereoscopic (00508d03)
VideoPlayer: inputstream changes, bump to 1.0.2 (92c4b245)
Revert ā€œ[mmalrenderer] Wait for vsync before submitting to mmal when display sync is disabledā€ (acd6071f)
Revert ā€œ[rbp] Refactor the vsync handle to support multiple callersā€ (02017364)
[pvr] drop PVRFile (e1144fc9)
Ok added advancedsettings.xml + updated today RPI1 still sad face in loop
Try starting with a clean .kodi folder by renaming /home/osmc/.kodi to .kodi.bak
16.8-046, 23 March 2016: Based off OSMC commit (7d2f65c) and newclock5 commit (6c187f4)
Highlights
newclock5
Yatse recently stopped working for me, anyone else has that issue with v17?
Hello gmc,
nothing, I’ve reinstalled everything and now it works; just a guess: in the previous installation I had set Confluence skin, perhaps that setting broke somehow the system once upgraded; keeping OSMC skin and upgrade to 17 went fine.
Aside: addons menu on system is not responding here, is this normal?
den
If you use Estuary skin do you still have the same issue?
Yes; I’ve managed the add-ons installation using the right top icon in add-on menu
I’ve tested it on my installation and it works fine. Can you enable debug logs, replicate the issue and upload the logs.
16.8-047, 23 March 2016: Based off OSMC commit (7d2f65c) and newclock5 commit (6c187f4)
Highlights
  • python: use kodi provided cert if available
newclock5
python: use kodi provided cert if available (cbdddad9)
Hiya,
Im still using yatze remote without problems, it could be because im using to beta version of yatze.
join the beta program here.
Yatze Beta Program
Thanks will check again, have also a strange CEC issue in the moment
What version of libcec do you have installed?
Hi GMC,
will need to check detail later but something 3.1xxx
Wrote the error message to you yesterday.
@gmc,
just checked
osmc@osmc.my.hk:~$ dpkg -l | grep cec
ii rbp2-libcec-osmc 3.1.0-1
And error message is popup ā€œPulse-Eight CEC adapter Detected Version of libCEC interface (30001) is lower than the supā€¦ā€
Logfile shows
22:28:33 174.216034 T:1800401904 DEBUG: script.module.osmcsetting.updates : - blurp 445 - SettingsCategory.xml
22:28:34 175.748062 T:1958478384 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
22:28:35 175.969208 T:1833956336 DEBUG: GetMappingForDevice - device (2708:1001) mapped to CEC Adapter (type = cec)
22:28:35 175.971405 T:1833956336 ERROR: Detected version of libCEC interface (30001) is lower than the supported version 30100.
22:28:35 175.977005 T:1958478384 DEBUG: ------ Window Init (DialogNotification.xml) ------
22:28:35 176.471558 T:1833956336 DEBUG: CreatePeripheral - failed to initialise peripheral on ā€˜RPI’
And under Input Devices I don’t find anymore the option to disable CEC. Did it move somewhere else?
@gmc
You need to purge your builder’s toolchain.
