got my Yatse problem solved. Stupid mistake, got a new Pi3 and for whatever reason had the IP address instead of the device name in Yatse. Updated my DHCP records with the new MAC and all is back in shape.
Hi, I installed version 16.8-046 to see if the a/v sync issue with live TV on Jarvis was still present in Krypton and was quite pleased when it appeared to be fixed, but Iāve updated to the latest build (16.8-048) and the sync issue is back. Testing 16.8-047 now, will get logs later. Any ideas?
running latest build, trying Airplay from IOS 9.2/9.3 but canāt get either audio/video, nothing to be noticed onscreen.
Which logs can I check?
options are correclty set to allow Video & photos under Services/Airplay
tx
migube
@sam_nazarko @fzinken Iāve purged the toolchain and started off a new build. Thought I could get it completed today but ran into other build issues.
Running another build now which should hopefully fix the libcec issue once and for all.
Iām off on holiday tomorrow morning to Lanzarote
and back the following week so builds might have to wait to then
Build take 10 hours or so.
@Migu_Be @Quonith If you enable debug mode you can check out the kodi.log file for any errors.
Thanks @gmc, enjoy the holidays (I am officially jealous)
Well, I enabled debug logging and got the sync issue to happen, I donāt really know what Iām looking at but i canāt see anything in kodi.log that looks bad to me, I know itās OMXPlayer related but other than thatā¦
I will continue looking into this issue Here as this issue isnāt exclusive to Krypton and first appeared in Jarvis.
Just confused that 16.8-046 doesnāt have the problem, has something been changed in OMXPlayer from Jarvis that was reverted in 16.8-047?
For iOS 9 and up, I think you need to disable āvideo and picturesā under AirPlay for audio to start working: http://kodi.wiki/view/AirPlay
Just had my first sad face in OSMC, 16.8-048 ![]()
Linux osmc-Pi3 4.4.3-3-osmc #1 SMP PREEMPT Tue Mar 1 15:51:08 UTC 2016 armv7l GNU/Linux
Using the default Kodi skin:
- select TV Shows
- select the first āIn progress TV showsā and open so it shows the episode list
- Open the Options menu
- Move the selection to āFilterā and try to toggle it
- Instant sad faceā¦
Just flashed latest version, 047 i think it was called.
Anyways, a Tv Show froze all of a sudden during playback. First time after 5-10 min. Second time after 20 min.
Had to pull the power cord to restart the Pi2.
I have some videos that donāt play well on OSMC, unwatchable due to frame drops. This is a problem with these builds since the same file works great on OpenELEC. With OE it starts with 9 dropped but then plays flawlessly and on these test builds it just constantly drops frames counting up to over 300 in the 1 minute playtime.
Device is a Raspberry Pi 3
Here is a sample and its media info
sample http://s000.tinyupload.com/?file_id=9703...6597011541
media info http://pastebin.com/G1D2tqtB
I have the latest version (16.8-048, 25 March 2016) installed and all is good so far.
The only thing is my remote. I use a Logitech Harmony 300 with a Philips TV over CEC to control OSMC. Each button press leads to a double action in OSMC. I have installed the latest libcec 3.1 vie apt-get. Iāve also played with the button repeat settings in Kodi, but nothing helps.
On the stable Jarvis version with libcec 3.0.1 i have no trouble.
Does somebody has any idea?
My device is a raspi 2.
Edit: I have solved my Problem. The Logitech Support had reduce the repeat rate and all is good.
argh, I canāt read, indeed
it works! tx !
@gmc build issues again ?
Version: 16.8-031 Works well
Version: 16.8-032
Version: 16.8-033
Version: 16.8-034
Version: 16.8-035 Works well
Version: 16.8-036
Version: 16.8-037 Works well
Version: 16.8-038 Crashes (sad face on the screen) on Kodi load with next last lines in kodi.log:
00:13:08 76.289505 T:1958339120 FATAL: addon āservice.xbmc.versioncheckā is missing.
00:13:08 76.289680 T:1958339120 FATAL: CApplication::Create: Unable to start CAddonMgr
Version: 16.8-039 Crashes on Kodi load. I didnāt look in log.
Version: 16.8-041 Works well
Version: 16.8-042 Crashes on YouTube addon with next last lines in kodi.log:
00:54:32 71.767540 T:1729487856 ERROR: EXCEPTION: Unknown addon id āscript.module.osmcsetting.apfstoreā.
00:54:34 73.510681 T:1729487856 WARNING: CSkinInfo: failed to load skin settings
00:54:36 75.756142 T:1448080368 ERROR: GetDirectory - Error getting
Version: 16.8-043 Crashes on YouTube addon with next last lines in kodi.log:
00:45:57 437.064911 T:1659716592 ERROR: GetDirectory - Error getting
00:45:57 437.070740 T:1958023728 ERROR: Previous line repeats 1 times.
00:45:57 437.070953 T:1958023728 ERROR: streamin_bufferwrap: canāt stream in: requested 16777216 bytes, was read 4446 bytes
00:45:57 437.182861 T:1958023728 ERROR: exception in CApplication::FrameMove()
Version: 16.8-044
Version: 16.8-045
Version: 16.8-046
Version: 16.8-047 Crashes on YouTube addon. I didnāt look in log.
Version: 16.8-048 Crashes on YouTube addon. I didnāt look in log.
Device: RPi2.
He is on holiday
4 posts were split to a new topic: Broken addon
PLEASE donāt threadjack unrelated topics!
@sam_nazarko fzinken told me
Sam ,
In your instructions, for the commands, where in osmc do you issue the commands to request the repository for the update(s).
Mike
Well not 100% sure about your question but I assume the answer is āthe command lineā.
Details regarding how to access the command line interface can be found here on our Wiki: Accessing the command line - General - OSMC
thanks, sorry if I was not clear.
