it is pretty clear cause if you dont know how to add repos etc then perhaps testing is not for you since you need some knowledge of checking logs etc for issues… so its not just running the latest Kodi version…
Back again and builds continuing. See first post for latest version.
16.8-048, 25 March 2016: Based off OSMC commit (7d2f65c) and newclock5 commit (bba4122)
Highlights
NOTE: DVD playback remains temporarily disabled
newclock5
New commits in this build:
[linux] Move hotplug checking into its own thread (58c3e8e2)
Revert “temp: Add lock around mmal and omx calls to avoid stalled audio issue” (a051a9d7)
Revert “rbp: Use common function with lock for gencmds” (bba4122a)
Commits no longer in build:
VideoPlayer: do not disable stream at processing stage (ae748c96)
I just tested the newest version with my previously provided sample and it is still unwatchable.
Here are some stats showing that how it’s handled has changed
Newest OSMC - 120 dropped and 220 skipped (over duration)
Last OSMC from before your vacation - 300 dropped and 14 skipped (over duration)
OE - 9 dropped and 2 skipped (at start, with perfect playback after)
@gmc mind giving the repo a key so that the packages are authenticated?
since its always good to have a test repo for kodi
rbp2-mediacenter-osmc
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 28.7 MB of archives.
After this operation, 1024 B of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
Install these packages without verification? [y/N] y
since this is a good way to catch bugs early making less work for Sam when the time comes around to actually upgrade to the next version, it would work better to have a alpha repository officially and permanently for those that are brave enough to try and hunt for bugs.
It is a technical limitation. It’s not easy to sign it and maintain multiple versions at this time. I will see what can be done in the future but want to fix DVD support first
I’ve been running the OSMC kodi17 test build on my rpi3 for quite some time now. I dont know which version i was running, but i can check. Today osmc prompted me to update to a newer build (it had never done this before). I am now running OSMC April 2016 2016.4-1 (i cant find a more detailed build number, is this correct?) And after the update was applied, i have 2 issues:
HDMI-CEC is not working anymore. I cant control koid with my tv remote, while this was working fine before the update. Also my tv doesn’t recognise my pi as a hdmi-cec capable device.
I have the undervoltage icon show up all the time. This was not the case before the update, and my power supply was not changed.
Im happy to provide more details when you need them.
Could you point me to how to do this? I’ve done apt-get dist-upgrade as stated here (How to update OSMC via command line (ssh)?) but i get a message saying: “0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.”
Ah, well then i can confirm this feature now works
