Sorry for this, i totally missed the first post. Just moved here since the old thread was closed.
I’ve updated to 16.8-051 using the methods described there and the HDMI-CEC issues have disappeared.
I do still have the undervoltage icon pesent, so i guess i need a better power supply.
Tnx for the pointers, sorry for the lack of reading
16.8-051, 08 April 2016: Based off OSMC commit (d388397) and newclock5 commit b2653c8)
Highlights
NOTE: DVD playback remains temporarily disabled
libcec updated so hopefully this solves the previous libcec errors
sudo apt-get install rbp1-libcec-osmc=3.1.0-2
sudo apt-get install rbp2-libcec-osmc=3.1.0-2
newclock5
New commits in this build:
rendering: skipping gui rednering should be independent from dirty (60fbf12e)
VideoPlayer: move setting videoDelay from player to renderer (0d1b2eba)
VideoPlayer: only check skipping if we render a frame, saves CPU (72d0c45c)
squash skip (b2653c8b)
16.8-053, 10 April 2016: Based off OSMC commit (d388397) and newclock5 (bdb5c94)
Highlights
libcec 3.1.0-2 added as a dependency
newclock5
Revert “VideoPlayer: fix mem leak in subtitle processing” (8b24590e)
VideoPlayer: make videoRefClock an object of DVDClock’ (3695e8a7)
OMXPlayer: use SystemClock instead of DVDClock for a simple timer (ccaaa4d4)
fixup! VideoPlayer: move setting videoDelay from player to renderer (bdb5c941)
Commits no longer in build:
squash: fix build after WaitPresentTime (f33fcfc7)
squash skip (076fb357)
I use your nightly builds with my RPi 2 and for now it is stable for me.
I also use the Amazon Prime addon from Sandmann79 from the kodinerds Forum.
For now i have copie the inputstream.mpd addon from the openelec nightly. This works great and i can watch Amazon Prime movies on my RPi2.
But from version 16.8-049 and higher the stream has no total duration. So i can’t fast forward or rewind. And there is no resume point if i stop the playback.
If i downgrade to version 16.08-048 i have a total duration.
Other streaming services or other platforms like Windows or Ubuntu are not affected.
Have you an idea how i can solve this?
And are you plan to inegrate the inputstream.mpd addon to your builds?
Hi sam, thanks for all your hard work. I updated the repository URL as top of the page, and I’m getting further into the install, but its still not finding the files when i install it.
sure thing… I have first run sudo apt-get update, which runs without problem.
Then I used various commands which all have same results:
sudo apt-get install rbp2-mediacenter-osmc
sudo apt-get install rbp2-mediacenter-osmc=16.8-053
Get these errors after sudo apt-get update and sudo apt-get dist-upgrade:
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:3 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [1228 B]
Get:4 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Hit http://apt.osmc.tv jessie InRelease
Get:5 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Hit http://download.osmc.tv Packages
Ign http://apt.osmc.tv jessie/main Translation-en
Fetched 6719 B in 21s (311 B/s)
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
armv7-libdvdcss-osmc armv7-libdvdnav-osmc armv7-libdvdread-osmc
1 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 29.5 MB of archives.
After this operation, 3370 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
armv7-libdvdnav-osmc armv7-libdvdread-osmc armv7-libdvdcss-osmc
Install these packages without verification? [y/N] y
Err Index of /osmc/osmc/download/dev/gmc armv7-libdvdnav-osmc 5.0.4-1
404 Not Found
Err Index of /osmc/osmc/download/dev/gmc armv7-libdvdread-osmc 6.0.0-1
404 Not Found
Err Index of /osmc/osmc/download/dev/gmc armv7-libdvdcss-osmc 1.4.0-1
404 Not Found
Err Index of /osmc/osmc/download/dev/gmc rbp2-mediacenter-osmc 16.8-054
404 Not Found
E: Failed to fetch http://download.osmc.tv/dev/gmc/./armv7-libdvdnav-osmc-5.0.4-1.deb 404 Not Found
Using this deb Index of /osmc/osmc/download/dev gmc/ as shown at the top, gives me these errors:
Err Index of /osmc/osmc/download/dev gmc/ armv7-libdvdnav-osmc 5.0.4-1
404 Not Found
Err Index of /osmc/osmc/download/dev gmc/ armv7-libdvdread-osmc 6.0.0-1
404 Not Found
Err Index of /osmc/osmc/download/dev gmc/ armv7-libdvdcss-osmc 1.4.0-1
404 Not Found
Err Index of /osmc/osmc/download/dev gmc/ rbp2-mediacenter-osmc 16.8-054
404 Not Found
E: Failed to fetch http://download.osmc.tv/dev/./armv7-libdvdnav-osmc-5.0.4-1.deb 404 Not Found
