New commits in this build:
Define RPI=1 so we can use VPU/QPU acceleration patches when building ffmpeg via autobuild.sh (920f2965)
VideoPlayer: fix CDVDMessageQueue::WaitUntilEmpty (d4d42fad)
VideoPlayer: make sure first frame of a new stream is displayed without delay, signal started when frame is picked for render (8dd11f53)
squash: VideoPlayer: fix CDVDMessageQueue::WaitUntilEmpty (d1c1e64f)
Commits no longer in build:
VideoPlayer: pass parameters for seek mode in a structure (1fed6b70)
VideoPlayer: do not block caller on relative seeks (e3407e95)
squash: VideoPlayer: pass parameters for seek mode in a structure (459aebfc)
16.8-170, 15 Oct 2016: Based off OSMC commit (7369d1aa6) and newclock5 (68bb1092)
XBMC:
[cmake] Fix building main executable (PR:10694, 2 commits, 2 files changed)
[video] fix NFO parsing of 's (PR:10641, 1 commit, 1 file changed)
VideoPlayer: make sure first frame of a new stream is displayed witho… (PR:10696, 1 commit, 4 files changed)
added: include watched status for movies in actor search dialog (PR:10688, 1 commit, 1 file changed)
newclock5: New commits in this build:
MMALRender: Switch to deinterlace mode where frame flags are exclusively used (68bb1092)
Sad face crash after installing latest 171 build. It boots, I see the OSMC logo, but right when you expect to see KODI, a giant sad face appears instead.
Then screen goes black after a few seconds, and then sadface comes back. And it keeps on and off for all eternity.
Also noticed some other bug, after every update the past 5-10 updates, my background pic is reset to default, and all the main menu items that I had deselected (Videos, Music, Pictures, TV, Radio) are re-enabled again. Why is that?
I had the problem also. It seems to be due to an addon. If you rename or delete
the Addons26.db Kodi start normally. I have downgraded to version 170 and taken the Addons26.db from my backup last night. And everything is as before.
16.8-171, 18 Oct 2016: Based off OSMC commit (7369d1aa6) and newclock5 (24f1b53)
XBMC:
[dxva] fix hw decoding on some mpeg2 files and DVDs (PR:10644, 3 commits, 2 files changed)
Export max value in ratings by default (PR:10627, 1 commit, 4 files changed)
VideoPlayer: fix CDVDMessageQueue::WaitUntilEmpty (PR:10697, 1 commit, 2 files changed)
Fix joysticks not being detected on android startup (PR:10689, 1 commit, 2 files changed)
peripheral.joystick:
[FIX] Don’t mark callback as __cdecl when (PR:57, 1 commit, 3 files changed)
newclock5:
MMALFFMpeg: Report as SW decode in codec overlay info (24f1b532)
[dvdmessage] Increase timeout on CDVDMsgGeneralSynchronize (fc81f34a)
Revert “[dvdmessage] Increase timeout on CDVDMsgGeneralSynchronize” (e6c6a38b)
Define RPI=1 so we can use VPU/QPU acceleration patches when building ffmpeg via autobuild.sh (3ba5b179)
VideoPlayer: fix CDVDMessageQueue::WaitUntilEmpty (b6ad29f0)
Yepp! 161 is a no-go. Only 160 is working. I even tried the 172 today but same crash.
Im not sure how to get a debug file, trying to figure it out now. Should I just turn on debug in Kodi and flash update? How do I retreive it with a crashed Kodi?
i tried to upgrade from OSCM: 2016.09-1 to 16.8-172 (Krypton) with no luck.
i deleted Addons26.db from /Database directory but the RPi3 is still crashing at boot.
I will post my log file… that i’m trying to grab.
171 to 172 = restart loop
“sudo mv /usr/share/kodi/addons/skin.osmc/ ~/skin.osmc.bak/” = working w/ no osmc skin
Once working, exit and
“sudo mv ~/skin.osmc.bak/ /usr/share/kodi/addons/skin.osmc/” or “sudo apt-get --reinstall install mediacenter-skin-osmc”
resulted in either the restart loop , or ‘The following add-ons are incompatible with this version of Kodi and have been automatically disabled: OSMC’
172 to 161 = restart loop
same as above worked
161 to 172 with skin.osmc moved/not installed = no restart loop and 0 sad face restarts
172 to 161 with skin.osmc moved/not installed = no restart loop and 0 sad face restarts
I use confluence myself and only looked at skin.osmc because I had ‘The following add-ons are incompatible with this version of Kodi and have been automatically disabled: OSMC’ pop-up after removing the Addons26.db during 171 to 172.
I understand the value of the debug logs, debugging is always enabled + some component specific for debugging add-ons but this has been a case where the kodi logs have been completely useless so I kept none.
Hope this feedback is of more use than the logs/lack of have been.
The current OSMC skin is not compatible with Kodi Krypton. I recently added a patch will ensure the skin is enabled (Kodi will disable all non-essential add-ons between versions). This is likely causing the problem here.
@gmc Might be worth pushing the new skin for some feedback.
