Yes, so now either downgrade skin too, or just tweak the dpkg status file to mark it as installed. The other option is to wait until a new version is published; probably in the morning.
The file is /var/lib/dpkg/status.
What do i need to change in that file?
Have a search (I think I covered it recently), you just need to mark the skin and dependencies as installed.
I would honestly just recommend waiting. My repo will update soon, so you can grab a fixed skin from there. I’ll let you know when.
I would definitely wait. However, I can’t boot into OSMC right now… It loops
That is an unfortunate consequence of trying pre-release software. I will let you know when a new version is ready.
You can now grab the updated skin from my repository. Use dpkg -i to install it and then apt-get -f install to resolve.
wget http://apt.osmc.tv/pool/main/m/mediacenter-skin-osmc/mediacenter-skin-osmc_4.1.1-1_all.deb -O mediacenter-skin-osmc.deb
sudo dpkg -i mediacenter-skin-osmc.deb
sudo apt-get -f install
I’m not sure what level of stability you need / are expecting with these builds but it may be a good idea to stick with the stable release in future.
I have not had a chance to test this myself yet. Please confirm the new skin works as expected.
Perfect. I’m not expecting much, just want to test the latest and greatest
You would probably be better off testing the official Krypton builds, instead of these. There are some differences, and the official builds are more of what will be included in the final version of Krypton. These builds have some more experimental changes that may take a longer time to get in to the next version of Kodi.
Skin 4.1.1-1 has been uploaded which fixes the issue.
Thanks @gmc
Hi All,
I’ve just tried the latest test build and noticed a problem using my USB RF Remote (August PCR450), for some reason I’m unable to get any of the buttons to respond, yet if I change it to “cursor” mode, I have a cursor on screen and it appears to be OK.
I’ve tried using the keymap add-on and that doesn’t detect any key presses.
I’ve reverted back to the stable build from an SD image, I’m happy to provide more information, although not sure what would be relevant in trying to figure out what is going wrong.
Many thanks
Hi thanks for that lovely description of what went wrong, but as we are not clairvoyant yet we are going to need debug logs to actually do something about it.
So i do really recommend you to actually read
Cheers Toast
I was a bit hasty in reverting back to the stable version, I’ll have a go at installing the update again and let you know the logs. I’m surprised no one else has experienced this issue, being as it’s simply a PnP remote; I thought it may have been a setting I’ve overlooked?
remember debug logs, normal logs is useless.
Here is the log file http://paste.osmc.io/fugarewiqi.vhdl
Just a quick summary off what I’ve performed: From restart, attempted to press numerous keys on remote, then switched to cursor mode, navigated through a couple menus, switched back, press some more buttons.
I’ve used Yatse to stop debug towards the end.
16.8-175, 23 Oct 2016: Based off OSMC commit (7369d1aa6) and newclock5 (89ece28)
OSMC:
Updated OSMC Skin (4.1.1-1)
XBMC:
Use new add-on hooks to enable/disable peripheral add-ons (PR:10734, 1 commit, 3 files changed)
[filesystem/nfs] - ensure that the last access time of a context is u… (PR:10737, 1 commit, 1 file changed)
disable debug in depends in Release builds (PR:10728, 2 commits, 9 files changed)
[skin.estuary] Fix mute icon (PR:10742, 1 commit, 1 file changed)
pvr.vdr.vnsi:
send wol on system resume (PR:92, 1 commit, 2 files changed)
16.8-176, 29 Oct 2016: Based off OSMC commit (7369d1aa6) and newclock5 (2a3e8807)
Build Highlights:
ffmpeg: update to 3.1.5-Krypton-Beta5-1 (AMD GPU initial i-frame fix)
libcec 4.0.0
OSMC:
Updated OSMC Skin (4.2.0-1)
XBMC:
FIX: [droid;apps] handles missing res icon (PR:10777, 1 commit, 3 files changed)
Fade the current controller while mapping its buttons (PR:10761, 1 commit, 4 files changed)
Backport Windowing stuff from SPMC (PR:10743, 6 commits, 11 files changed)
SeekHandler: handle the seeking with numeric input. (PR:10769, 4 commits, 6 files changed)
[skins] add seek label to video fullscreen (PR:10786, 1 commit, 2 files changed)
libdvd/Makefile: cross-compile, allow to specify the ar command (PR:10782, 0 commits, 0 files changed)
ActiveAEFilter: Add missing include for avcodec_fill_audio_frame (PR:10791, 1 commit, 1 file changed)
Change splash db upgrade logic (PR:10731, 1 commit, 8 files changed)
libcec:
fixed: removed debian Replaces/Provides/Conflicts (cf438566)
updated README.md to reflect the new repository changes (ff591877)
updated linux part in README.md (c7e56e4b)
fixed dead link in README.linux.md. cosmetics (575ac2d9)
fixed another dead link in README.linux.md (d34ea62f)
added logo and supported hardware list to README.md (f6fdd650)
pvr.vbox:
Fixed tabs, comments, redundant braces and method change (std::size()>0) to (!std::empty()) (PR:145, 1 commit, 6 files changed)
newclock5:
New commits in this build:
bump dep to 4.0.0 (5573282e)
fixed: wrong label used in Commit:41621bc (45fe2ca3)
bump dep to 4.0.0 (bad7bc5f)
squash: Restructure the pll adjust code to avoid adjustment when sync display is disabled (ccc01028)
MMAL: Avoid advanced deinterlace when using software decode and HD resolution (2a3e8807)
16.8-177, 30 Oct 2016: Based off OSMC commit (7369d1aa6) and newclock5 (ea92eac0)
Build Highlights:
Kodi 17 Beta6 development opens
bcm270x: Convert to ARCH_MULTIPLATFORM (see PR:1699)
Build Details:
XBMC:
[gui] dialogvideoinfo: show selectdialog for directorbutton if amount of directors > 1 (PR:10776, 1 commit, 1 file changed)
Parse the id tag only if the uniqueid tag is missing as fallback (PR:10774, 1 commit, 1 file changed)
[Fix] Fix two possible resource leaks (PR:10792, 2 commits, 2 files changed)
[linux] use appname instead of hardcoding kodi (PR:10796, 1 commit, 1 file changed)
[gui] - remove fallbacks for pvr next* infolabels (PR:10788, 1 commit, 1 file changed)
[addons] make sure temp dir exists before running CFileOperationJob (PR:10794, 1 commit, 1 file changed)
bump to v17.0 beta 6 (PR:10798, 1 commit, 2 files changed)
newclock5:
Updated commits in this build:
Revert “rbp: Use common function with lock for gencmds” (95d5981c => e89faffd)
Commits no longer in build:
[ae] Add debug logging showing resamplerate (eb9b1f1f)
16.8-178, 31 Oct 2016: Based off OSMC commit (7369d1aa6) and newclock5 (a5a0e5d)
XBMC:
[guiinfo] Coverity: Fix CID 151032 - 151035: Control flow issues (PR:10804, 1 commit, 1 file changed)
Fix 1 error and 5 compiler warnings (PR:10765, 7 commits, 7 files changed)
AE: Drop AEBuffer (PR:10806, 1 commit, 5 files changed)
newclock5:
VideoPlayer: hls, select best resolution closest to desired bandwidth (a5a0e5d0)
16.8-179, 1 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (6c5afa6b9)
XBMC:
FIX: [amc] Multiple fixes (PR:10779, 5 commits, 2 files changed)
Coverity: Initialize videoinfotag rating and uniqueid ids (PR:10812, 1 commit, 1 file changed)
[cmake] Debug binary-addon packaging issues on android (PR:10803, 2 commits, 2 files changed)
deprecate autotools (PR:10797, 1 commit, 1 file changed)
Bunch of SPMC jni backports (PR:10808, 26 commits, 76 files changed)
MemoryAlignment: Fixes (PR:10810, 4 commits, 5 files changed)
[skins] seeknumeric - use hh:mm:ss format (PR:10816, 1 commit, 2 files changed)
FFmpeg: Bump to 3.1.5-Krypton-Beta5-1 (PR:10746, 1 commit, 1 file changed)
allow settings.xml.in (PR:10815, 1 commit, 1 file changed)
Fixed: RTMP swfvfy also accepts 1 instead of just true (PR:10820, 1 commit, 1 file changed)
