[TESTING] Kodi 17 (Krypton) builds for Raspberry Pi (continued)
16.8-180, 2 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (c57fdc4d)
OSMC
Bump skin to 4.3.0-1 (8d8e4e31169d)
XBMC:
AudioTrack: Workarounds (PR:10809, 2 commits, 3 files changed)
[AMLUtils] Update aml_permissions() to check for RW access to more paths (PR:10822, 1 commit, 1 file changed)
[cmake] 2 small fixes related to binary-addon build (PR:10825, 2 commits, 2 files changed)
fixed: used av_free when av_freep was intended in f5f9b8d and aadfc21d (PR:10828, 2 commits, 2 files changed)
[cmake/android] Attempt to fix binary-addon packaging (PR:10827, 1 commit, 1 file changed)
Hide passwords from advancedsettings log (PR:10790, 1 commit, 1 file changed)
[PVR] Guide window: Fix responsiveness on first open. (PR:10814, 2 commits, 1 file changed)
FIX: [amcs] get proper VideoView size (fixes #17032) (PR:10818, 1 commit, 9 files changed)
[xbmc][fix] Make CDirectory::Create create all the needed folders (PR:10811, 1 commit, 6 files changed)
16.8-181, 3 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (3a433a85)
XBMC:
ListItem.Year - prefer to use the year value from the firstaired date (PR:10770, 1 commit, 2 files changed)
[python] add xbmcgui.ListItem.setCast() (PR:10619, 1 commit, 2 files changed)
[python] add xbmcgui.Dialog().videoinfo() and .musicinfo() (PR:10616, 1 commit, 2 files changed)
[python] fix pydocs after Commit:a2f675e (PR:10833, 1 commit, 1 file changed)
[PVR] Fix local art lookup log spam. pvr recordings never have local art. (PR:10832, 1 commit, 1 file changed)
[xbmc][fix] Don’t try to index outside our lookup table and crash (PR:10831, 1 commit, 2 files changed)
Subtitles: allow self-closing br and html escape characters (PR:10813, 2 commits, 1 file changed)
slideshow: only stop video player, keep background music playing (PR:10835, 1 commit, 1 file changed)
Fixed OnPlayBackResumed not getting fired anymore. (PR:10739, 1 commit, 1 file changed)
DVDDemuxFFmpeg: Fix whitespace (PR:10821, 1 commit, 1 file changed)
VideoPlayer: hls, select best resolution closest to desired bandwidth (PR:10801, 1 commit, 2 files changed)
VideoPlayer: add user name and password back to url after testing for… (PR:10799, 1 commit, 1 file changed)
fix streaminfo set by python (PR:10824, 1 commit, 1 file changed)
[cmake] add our own FindLibXml2.cmake, needed for static libs (PR:10829, 1 commit, 1 file changed)
pvr.vbox:
Genre mapping for programs, using mapping XML (PR:146, 8 commits, 7 files changed)
Added version check for VBox databases (channels & EPG) before fetch (a34454c4)
Added version check for VBox databases (channels & EPG) before fetch (8e496578)
newclock5:
Commits no longer in build:
VideoPlayer: cleanup VideoCodec interface, SetDropState (fac2d4f4)
MMAL: Update to new dropping scheme (181f3058)
VideoPlayer: hls, select best resolution closest to desired bandwidth (c57fdc4d)
16.8-182, 6 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (a333a28a3)
XBMC:
FFmpegImage: free avpacket side data (PR:10844, 1 commit, 1 file changed)
more verbose help for --enable-optimizations (PR:10839, 1 commit, 1 file changed)
[strings] Clarify it’s system memory/cpu usage (PR:10802, 1 commit, 3 files changed)
Temporarily removed audiodecoder.ncsf due to build errors
pvr.mythtv:
4.8.0 (PR:74, 3 commits, 9 files changed)
4.9.0 (PR:75, 3 commits, 11 files changed)
I downgraded from krypton to the stable build, but i am not able to use cec because it is still at libcec 3.1 and i cant downgrade it to 3.0, it always shows ‘Reinstallation of rbp2-libcec-osmc is not possible, it cannot be downloaded.’
My sources list has the main repo, still i cabt reinstall libcec, anybody knows any way?
You would need to put apt-get install rbp2-libcec-osmc=VERSION where the version can be determined from apt-cache.
On my side, I have had trouble with new libcec 4.0 so I did try to revert to latest version before 4.0 was introduced using :
apt-get install rbp2-libcec-osmc=16.8-175
but then I had no way to configure it inside Kodi’s interface since it was greyout and so my TV remote was completely ignored.
So I did upgrade again to 16.8-181 where libcec 4.0 seems to be broken but at least recognized my TV remote.
What troubles did you have? OSMC will be using libCEC 4.0.0 as standard with the next Kodi update so it’s good to get these issues solved.
This version # is incorrect. It should be 3.xxxxxx.
I probably did issue the correct command on the PI and just retype it here wrongly :slight_smile:
The issue I face is that the TV remote shut down correctly the TV, the AVR, and successfully stop PVR live TV stream (that wasnt possible in previous version).
Then I power on with the TV remote, the TV turn ON, the AVR too BUT Kodi output a black screen.
I think there is a signal but it renders black.
When the screen is black the remote is working and I can here the Kodi’s “click” interface sound so the AVR is receiving HDMI sound.
After a feew blind clicks it randomly finally bring Kodi’s interface back on the screen.
Edit : I would probably try a clean install and upgrade to latest beta in order to start clean.
You will need to post a log.
The issue doesn’t sound CEC related however. Do you have a screensaver enabled?
I also thought it could be the screen saver and disabled it : same black screen.
Regarding the log, do you need me to do a special sequence on the remote?
I don’t think it’s remote related. It sounds like the system becomes responsive after a period of inactivity. You could try waking with a smartphone app and seeing if it works.
I need a debug log exhibiting the problem.
16.8-183, 7 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (3b611c4)
XBMC:
[MMALRender] Report deinterlace method in codec info (PR:10854, 4 commits, 6 files changed)
test fixes (PR:10817, 2 commits, 2 files changed)
[deps][fix][win32] Fix embedded fonts in libass (PR:10784, 3 commits, 1 file changed)
[xbmc] Ignore some items that’s been bugging me for a while (PR:10869, 1 commit, 1 file changed)
newclock5:
New commits in this build:
GUIFontTTFGL: Fix texture leak in subtitles (3b611c4b)
MMAL: Move pool into base class (aeabc8d6)
MMAL: Make setting the decoder more consistent between MMALCodec and MMALFFMpeg (7c180a4f)
MMAL: Set processInfo in pool (d35ef2de)
MMAL: Report deinterlace method to processinfo overlay (7a4c03e2)
skip existence check for plugin and http urls when cleaning (d5538755)
Revert “skip existence check for plugin and http urls when cleaning” (1f73cd4e)
Thanks! I was using the reinstall command and not install
16.8-184, 8 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (94e4015a)
OSMC
Updated OSMC Skin (4.4.0-1)
XBMC:
[PVR] Guide window: Fix another deadlock. (PR:10855, 1 commit, 1 file changed)
Extract digits also from the new ratings’ vote tag (PR:10860, 1 commit, 1 file changed)
Fix conversion of POPM tag values to the new 0 to 10 user rating for songs (PR:10866, 1 commit, 1 file changed)
paplayer: add processInfo, fixes wrong seeking state (PR:10862, 1 commit, 2 files changed)
[xbmc][fix][tests] Remove unnecessary test that causes crashing (PR:10868, 1 commit, 1 file changed)
FIX: [amc] revert most of drain stuff (PR:10853, 2 commits, 2 files changed)
[depends] always use our own zlib (PR:10852, 1 commit, 1 file changed)
fix hash checking in addon installer (PR:10819, 2 commits, 10 files changed)
[cmake] Add doc target that builds the doxygen documentation (PR:10849, 1 commit, 2 files changed)
SubtitleDialog, remember last service/search. (PR:9660, 1 commit, 2 files changed)
Code cleanup for GUIDialogVideoInfo (PR:10859, 1 commit, 2 files changed)
[videoplayer] reset VideoCodecInfo in CProcessInfo constructor (PR:10876, 1 commit, 1 file changed)
newclock5:
DVDOverlaySSA: Fix Leak with SSA subtitles (94e4015a)
16.8-185, 9 Nov 2016: Based off OSMC commit (b9120ae19) and newclock5 (90691818)
XBMC:
Move peripherals to shared_ptr (PR:10740, 3 commits, 17 files changed)
[gui] - add playcount infolabel for pvr recordings (PR:10880, 1 commit, 1 file changed)
GUIFontTTFGL: Fix texture leak in subtitles (PR:10874, 1 commit, 1 file changed)
DVDOverlaySSA: Fix Leak with SSA subtitles (PR:10873, 1 commit, 1 file changed)
add privacy policy (PR:10785, 5 commits, 17 files changed)
[travis] Remove autotools options (PR:10871, 1 commit, 1 file changed)
[listproviders] directory list provider: fix updates for favourites folders not processed. (PR:10879, 1 commit, 2 files changed)
[PAPlayer] - use SetSpeed for the Pause method and fire callbacks in SetSpeed (PR:10886, 1 commit, 1 file changed)
peripheral.joystick:
[buttonmaps/android] Update NVidia controller for all profiles (PR:60, 1 commit, 1 file changed)
[directinput] Defer joystick acquisition to initialization (PR:62, 1 commit, 2 files changed)
[appveyor] add appveyor.yml for automated testing (PR:63, 1 commit, 1 file changed)
Fix controller translation (PR:61, 1 commit, 9 files changed)
[travis] Add .travis.yml file for automated testing (35b5ef27)
Optimize case when button map is empty (bc4a182e)
Fix deserializing joystick families (every joystick name was “joystick”) (8364b65a)
newclock5:
advancedsettings: Add option to set cache size on libass (90691818)
GUIFontTTFGL: Fix texture leak in subtitles (a5a5989a)
Sorry I didn’t catched log because various things were working wrongly, I did a clean intall.
Sadly it doesnt solved the CEC issue nor it did fixed the interface to be reseted.
For example, I remove “Radio” from the home interface in the settings, reboot and radio is back :frowning:(
For libcec settings there is also a strange behavior in the interface : if I ask it to be reseted to its default then I can see the parameter “connected to” “TV” or “AVR”, I then set it to AVR, click OK, re-enter the cec parameters and then the “connected to” isn’t here anymore.
Now it seems that libcec settings have no effect at all, it doesnt auto start or stop my AVR when I turn off my TV (Samsung 2012 serie).
Sorry – without any logs I don’t think anyone can help.
@propergol post logs of your issue… its been said over and over in this thread if there arent any logs we cant help you.
we cant see whats going on in your system without your logs and a description of the problem isnt good enough.
I have 5 people watching the TV for now, so I can only grab the logs via putty, I don’t know if it could help.
Anyway :slight_smile: odi.log http://paste.osmc.io/yofefosiwa.vhdl
kodi.old.log : http://paste.osmc.io/olawewefuv.coffee
Which indicates a SD card issue
