16.8-033, 21 Feb 2016: Based off OSMC commit 72f88bb and newclock5 commit (047b4a7)
newclock5
New commits in this build:
SinkPi: Correct setting of passthrough flag (c9f99e25)
VideoPlayer: drop useless interface ISeekable (3b519e98)
VideoPlayer: rename DVDInputStream::ISeekTime to DVDInputStream::IPosTime (e43ba20f)
VideoPlayer: use function to get interfaces of inputstreams (400ba351)
mmal: move towards common class (ac05199a)
Revert “mmal: move towards common class” (047b4a70)
mmal: Include mmal renderer logging in video category (adcff19c)
mmal: increase decode buffering a little to help harder MVC files (125bb30d)
mmal: Use correct pool destroy functions (459a3949)
16.8-035, 23 Feb 2016: Based off OSMC commit e8c4355 and newclock5 commit (dd5573)
newclock5
VideoPlayer: some cleanup in audio player (212fb7d1)
VideoPlayer: fix comskip (58c8615c)
mmal: Handle software and hardware decode with common renderer code (dd55734d)
Commits no longer in build:
fixup: disable thread_safe_callbacks (98c26f9c)
VideoPlayer: drop useless interface ISeekable (ed0bce2b)
VideoPlayer: rename DVDInputStream::ISeekTime to DVDInputStream::IPosTime (b4198f78)
VideoPlayer: use function to get interfaces of inputstreams (c706e03b)
AE: fix re-mappng issue (e487a1aa)
16.8-036, 24 Feb 2016: Based off OSMC commit 6f9a73a and newclock5 commit (dd5573)
newclock5
16.8-038, 29 Feb 2016: Based off OSMC commit c193405 and newclock5 commit (61a2053)
newclock5
squash dropping (c928cc53)
MMAL: Remove support for YUV and make the MMAL format more general (a24e2bf2)
MMAL: Add zero copy accelerated interface to ffmpeg (1065f701)
[network] Fix CZeroconfBrowserAvahi::doRemoveServiceType map iterator usage (8be2af26)
[cmake] fix libdvd after move to depends (824ca7e0)
[cmake] openssl is an optional dep (089fdd37)
[cmake] fix mmal (b7331487)
[gui] change CGUIEditControl to use CVariant (2ab4fad6)
[addons] remove ‘visualization-library’. unused (0a1fc480)
[addons] remove ‘userdirs’ feature. unused (181d1ce5)
[addons] remove repository plugin hooks. unused and broken (7fd6454b)
VideoPlayer: drop incorrect error message (e5c9194a)
VideoPlayer: make video abort faster on flush (b37c6e41)
VideoPlayer: some cleanup in audio player (91499d8b)
VideoPlayer: fix comskip (7a1636d2)
OMXVideoPlayer: make video abort faster on flush (479b92ad)
[PVR] PVRManager::Cleanup - do not destruct addons with pvr manager mutex locked (ac0640b2)
[python] - fix WindowXML().setProperty() (4bbc6550)
[cmake] Drop unused FindMpeg2 module (5d9fa5c5)
[cmake] Build kodi.bin for android (b3e3a643)
move jsonrpc code out of AddonProps (abc71dfe)
[addons] don’t return empty repository on failure. regression from 78096f42db (73cf7ed9)
cleanup CScraper constructors (26f42f66)
[addons] remove unnecessary database access on opening info dialog (0756e1a8)
[addons] cleanup and cosmetics (e50cdd8b)
[database] dont attempt to drop automatically created indices when clearing analytics (2578bab1)
rbp: Add zero copy interface to ffmpeg for software decode (1a57190d)
ATTN @gmc i installed that service addon and so far it seems to work crude workround as i dont see why is should need it but if this helps anyone else im glad i tried
p.s i disabled it from doing any version checking under configuration.
Very odd. I’ve deleted and recreated the Addons22.db and don’t see the service being added.
The addon-manifest.xml contains service.xbmc.versioncheck so I’m not 100%.
hi mates. i installed the versione of the 28th on the official one: everything is working and channel zapping on iptv is a lot faster. then i try to install later versions but both the one of the 29th and the one of the 1st goes on bootloop showing the screen with sad emoticon.
have i to do some kind of cleanings before install a new alpha on an older one?
