Updates only work through the CLI due to this. Not sure how quickly/easily this can be fixed.
17.8-037, 12 March 2017: Based off OSMC commit (780ac44) and newclock5 (a6f4ae6)
OSMC
Remove dependency for dcadec
pvr.wmc:
Fix conflict with pvr-hts (PR:46, 1 commit, 1 file changed)
17.8-038, 13 March 2017: Based off OSMC commit (3356d4ea) and newclock5 (7d545586)
OSMC
Add in game.libretro.handy game.libretro.hatari
XBMC
[Cleanup] silent some warnings (PR:11817, 3 commits, 4 files changed)
language addons: remove kaitoast close hack (PR:11840, 2 commits, 1 file changed)
17.8-039, 14 March 2017: Based off OSMC commit (1eeb56f4b2) and newclock5 (8b9858)
XBMC
[contextmenu] make reloading fully async (PR:11841, 2 commits, 3 files changed)
17.8-040, 15 March 2017: Based off OSMC commit (042dd86f) and newclock5 (8b9858)
XBMC:
[jenkins][windows] donāt remove previous compiled version of ffmpeg & libdvd if nothing changed (PR:11835, 1 commit, 5 files changed)
[Fix] VideoPlayer: Donāt close any subtitle stream when switching audio tracks. (PR:11715, 1 commit, 2 files changed)
[pvr] refactor guide osd to be channel guide dialog and use it in guide info (PR:11554, 9 commits, 19 files changed)
[cmake] Add support for LCMS2 (PR:11072, 2 commits, 3 files changed)
[PVR] Trac 17372: Fix wrong initial channel focus with āContinue last channel on startupā setting. (PR:11843, 2 commits, 4 files changed)
Add some missing Lirc mappings for MCE-Remotes (#11828) (ce8274d4)
inputstream.rtmp:
fixed: null session on Open failure (6c1af46a)
17.8-041, 16 March 2017: Based off OSMC commit (dd190404) and newclock5 (26611de)
XBMC:
[settings] revert default of epg.selectaction back to show info (PR:11848, 1 commit, 1 file changed)
Adding keyboard layout: Thai Kedmanee (#11844) (85d866eb)
newclock5:
New commits in this build:
MMAL: Remove periodic prime calls and handle from buffer destructor (87083871)
MMALCodec: Include a timeout of GetPicture in default debug logging (26611de3)
17.8-042, 17 March 2017: Based off OSMC commit (ccb2d792) and newclock5 (26611de)
XBMC:
[PVR] Fix trac17374: Settings deinitialized too early on app exit. (PR:11849, 1 commit, 3 files changed)
newclock5:
RenderManager: Force frames to output when reconfiguring renderer (ccb2d792)
17.8-043, 19 March 2017: Based off OSMC commit (f737b2) and newclock5 (6d7646)
XBMC:
Use invoke-id instead addon-id for selecting the monitor for abortrequest (PR:11852, 1 commit, 7 files changed)
[bluray] allow do build without bluray support (PR:11862, 1 commit, 1 file changed)
[win] use users profile folder as home folder (PR:11857, 1 commit, 1 file changed)
drop support for āoldā static listitem format (PR:11756, 1 commit, 1 file changed)
[python] WindowXML - add param for mediawindow (PR:11766, 1 commit, 2 files changed)
pvr.dvblink:
pvr.dvblink (master) version 4.1.2 (PR:78, 1 commit, 3 files changed)
17.8-044, 20 March 2017: Based off OSMC commit (f737b2b) and newclock5 (6d7646)
XBMC:
Fix for YouTube Add-On Crash (PR:11860, 1 commit, 1 file changed)
17.8-045, 21 March 2017: Based off OSMC commit (e3e0cd9) and newclock5 (9083cb4)
XBMC:
[addons] Update Chorus (PR:11872, 1 commit, 6 files changed)
FIX: [droid] force PIC (text reloc denied as of API 23) (PR:11870, 1 commit, 2 files changed)
FIX: [depends;PIL] unzip with overwrite (PR:11876, 1 commit, 1 file changed)
17.8-046, 22 March 2017: Based off OSMC commit (0ac4ec57) and newclock5 (9083cb4)
XBMC:
[Fix]Default music artist separators remove colon and ā|ā (ticket 17401) (PR:11873, 1 commit, 1 file changed)
[Fix]paplayer: replaygain regression (PR:11868, 1 commit, 2 files changed)
[cmake] require libfmt min version (PR:11867, 1 commit, 1 file changed)
[PVR][Esturay] Channelgroup manager dialog: Add support for radio channel groups (PR:11877, 2 commits, 5 files changed)
[PVR] GUI Actions: Execute recordings actions async (PR:11863, 2 commits, 3 files changed)
[Droid] Move jni to depends (PR:11866, 5 commits, 202 files changed)
17.8-047, 24 March 2017: Based off OSMC commit (b6b02f7) and newclock5 (dcf10a2)
XBMC:
[guilib] add template for GetWindow() to enclose type cast (PR:11869, 4 commits, 92 files changed)
FIX: [cmake] use specific Android profile (so versions) (PR:11875, 2 commits, 11 files changed)
fixed: install into system-expected python library path (PR:11880, 1 commit, 1 file changed)
[gui] follow up for PR #11704 (PR:11847, 4 commits, 4 files changed)
FIX: [python] no abort + droid libs (PR:11885, 1 commit, 3 files changed)
pvr.vbox:
fix install path (PR:184, 1 commit, 1 file changed)
Forgot to take logs, but Sad-Face crash 1-2 seconds after pressing download subtitle button with 17.8-048.
Reverted back to 17.8-047. Working normally now.
Try the latest build, should be up shortly. If the issue persists please post debug logs.
17.8-048, 30 March 2017: Based off OSMC commit (/b6b02f72) and newclock5 (bb9cfeb3)
OSMC
Ensure that add-ons can run before shutdown / reboot.
Fix save skin setting changes immediately
XBMC:
[depends] bump rapidjson to 1.1.0 (PR:11909, 2 commits, 5 files changed)
[depends] bump crypto libs (PR:11902, 3 commits, 3 files changed)
[touchscreen/pictures] - allow to back out from fullscreen picture moā¦ (PR:11625, 1 commit, 1 file changed)
Fix crash due to exception when entering Games ā Keyboard settings (PR:11903, 1 commit, 1 file changed)
pvr.vuplus:
fix install path (PR:52, 1 commit, 1 file changed)
newclock5:
fix android build (08c42f23)
ios: adapt tu ae updates (72c55a1f)
fix unit tests (c0b112d9)
added todo comments (64839ca8)
Replace C-style casts to C++ casts (3b8b4a06)
remove AudioDSP settings (64b8e7a4)
remove AudioDSP from ServiceBroker and ServiceManager (a9aafcd3)
Disable AudioDSP (ca88ddf7)
pvr: include ServiecBroker, fixes compile error (bb4838d0)
adsp: silence warning (49ffbeca)
adsp: fixup (57ebf35a)
17.8-047 Crashing with Reboot after watching live tv using HDhomerun addon
http://paste.osmc.io/igafalikic
17.8-048 Updated to the latest version same thing on Pi-2
Watching TV channel click close then it reboots no sad face. http://paste.osmc.io/orofikotir
When did the problem start? With 047?
Not sureā¦ Give me some time and I will roll back to earlier versions to double check.
OK just confirmed 046 is working fine. When Stopping the Live TV show it doesnāt reboot. It allows to change channels.
So 047 and 048 Crashed when Stopping Live TV
