Thanks. Will look into it.
17.8-049, 31 March 2017: Based off OSMC commit (8d97983e) and newclock5 (ba4f130ad)
OSMC
Bump userland version (d96013ae)
XBMC:
changed: build the exif code in main library (PR:11907, 1 commit, 21 files changed)
pvr.dvblink:
pvr.dvblink (master) 4.1.3 (PR:83, 3 commits, 4 files changed)
newclock5:
New commits in this build:
Adds -DRPI=1 to the compiler flags so that ffmpeg can be compiled with RPI optimisations (2d0e6b51)
Texture: Fix constness of pixels (c5f2582d)
TextureCacheJob: Inline LoadImage (a4470730)
TextureCacheJob: Inline CBaseTexture::LoadFromFile (69ac873b)
OMXImage: Rearchitect to use file buffer (44e8fe54)
TextureCacheJob: Use common file buffer (7006b1c2)
OMXImage: Add back in some debug/error logging (ba4f130a)
Just updated and its shows 17.8-050
Alright just finish testing 17.8-50 same behavior.
Pi-2 using HDhomerun prime client Zoltan when watching live tv then click stop you get Blue Flash Screen reboot then start up with channels scanning back in.
When using the Back key watching Live TV to change channels everything works fine.
17.8-050 is the latest version. Its supposed to show that
I’ll run some tests and see If I have the issue here as well.
Not seeing much obvious from the logs.
I think the crash might be solved in this patch:
New nightly should be up shortly which contains the update.
17.8-050, 1 April 2017: Based off OSMC commit (a55912a2) and newclock5 (7797246)
XBMC:
[PVR] CPVRTimers fixes and optimization (PR:11920, 2 commits, 7 files changed)
[PVR] Rework CPVRActionListener and CPVRGUIActions lifecycle (PR:11919, 1 commit, 23 files changed)
newclock5:
readd GUIDialogAudioDSPManager and remove calls to the old AudioDSP manager object (561d8d51)
OMXImage: Skip out earlier when image is progressive (f4387b21)
Update DVDInputStreamBluray.cpp (7797246c)
Commits no longer in build:
adsp: fixup (936169fd)
Almost goofed ! I Clicked update and got 17.8-050 double checked and manually forced 17.8-051 !
Great NEWS its FIXED ! One less headache ! LOL
Great Work ! Im sorry for screwing up your weekend
Great stuff. No need to thank me though. Thank this guy
17.8-051, 3 April 2017: Based off OSMC commit (d147dab6) and newclock5 (f4e9941e)
XBMC:
More code modernization for dialogVideoInfo (PR:10889, 3 commits, 2 files changed)
[guilib] CGUIWindowManager: Fix destruction of windows on Kodi exit (PR:11918, 1 commit, 2 files changed)
CGUIWindowManager: Protect against null window access (PR:11927, 1 commit, 1 file changed)
17.8-052, 4 April 2017: Based off OSMC commit (73a86885) and newclock5 (1c73d3e9c)
XBMC:
newclock5:
CGUIWindowManager: Protect against null window access (f4e9941e)
17.8-053, 5 April 2017: Based off OSMC commit (8d8c5f22) and newclock5 (66be47)
XBMC:
Add browse for subtitle action (PR:11649, 2 commits, 5 files changed)
[windows] use wmic qfe instead of powershell to check if hotfix is installed (PR:11893, 1 commit, 1 file changed)
Copyright header update for games, joysticks and RetroPlayer (PR:11925, 3 commits, 186 files changed)
[rbpi] Make sure we strip binaries in Release build (PR:11923, 1 commit, 1 file changed)
[Clean up] Removing white space, unused variables and methods (PR:11926, 1 commit, 2 files changed)
[depends] Bump samba-gplv3 to version 4.0.26 (PR:9098, 1 commit, 5 files changed)
[droid] Add leanback recommendation and search (PR:11901, 10 commits, 50 files changed)
Fix syntax for links (PR:11928, 1 commit, 1 file changed)
estuary fix watched status for videos (PR:11921, 1 commit, 1 file changed)
17.8-054, 6 April 2017: Based off OSMC commit (fb308fd2) and newclock5 (d0aa862)
XBMC:
Align play button in context menu to behavior in library (PR:10857, 1 commit, 1 file changed)
Input improvements (PR:11914, 5 commits, 14 files changed)
[filesystem][dialogs] Add context menus for favourites home screen widget (PR:11929, 1 commit, 7 files changed)
Small gui code cleanup (PR:10861, 1 commit, 9 files changed)
Moved party mode, set default and clear default to new contextmenu (PR:10892, 1 commit, 6 files changed)
inputstream.adaptive:
SmoothStream repeat_count / attribute order (c69f1344)
Merge branch ‘master’ of GitHub - xbmc/inputstream.adaptive: kodi inputstream addon for several manifest types (f23ba39c)
peripheral.joystick:
Update copyright headers to 2017 (PR:96, 1 commit, 115 files changed)
pvr.vuplus:
Streaming always use anonymous http connection (PR:57, 1 commit, 3 files changed)
Im BACK ! LOL This has been happening since 051 When watching Live TV on Hdhomerun app while the channel is playing using the back key and scrolling the Channel guide it reboots it was random but after the latest update I can now reproduce it. And it will reboot even if live tv isn’t playing in the back ground just scrolling the guide alone.
Pi-2
Still no closer to find out what’s causing this. Might be worth querying the issue in the hdhomerun forum.
17.8-055, 7 April 2017: Based off OSMC commit (f9104f8a) and newclock5 (3ad051)
XBMC:
[pvr] no need to run a job to announce channel switch (PR:11895, 1 commit, 3 files changed)
[depends] use ccache for binary add-ons (PR:11930, 2 commits, 3 files changed)
newclock5:
Fix compilling with latest ffmpeg patches which depends on newer RPi firmware. (842259eb)
MMALCodec: Add an extra buffer to picture pool (20d3d91d)
MMALCodec: Promote GetPicture timeout message to warning level (3ad05101)
17.8-056, 11 April 2017: Based off OSMC commit (43b4a46d) and newclock5 (a0cc219)
XBMC:
[depends] samba-gplv3: add patch to remove deprecated define in perl generator script (PR:11945, 1 commit, 2 files changed)
FIXUP: [AT] blocking writes (PR:11949, 1 commit, 1 file changed)
ADD: [xsp] filter by originaltitle (PR:11948, 1 commit, 3 files changed)
[windows] installer: call findstr with full path (PR:11940, 1 commit, 1 file changed)
cleanup internal rar vfs in favour of vfs.rar (PR:11912, 4 commits, 142 files changed)
Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (0baf85af, +3), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
17.8-057, 13 April 2017: Based off OSMC commit (b720dfe0) and newclock5 (a9c9a357)
Build Highlights:
ffmpeg: update to ffmpeg-3.3
newclock5 rebased on ffmpeg-3.3
MVC fix (reported by @-DH-)
Build Details:
XBMC:
[cmake] Spring cleanup aka OCD (PR:11834, 4 commits, 6 files changed)
CHG: [droid] use native interface for mediacodec (PR:11931, 2 commits, 3 files changed)
newclock5:
ffmpeg: hevc: rebase to ffmpeg 3.3 (8b5997e9)
fixup: MVC: Use correct codecpar->codec_tag (a9c9a357)
17.8-058, 16 April 2017: Based off OSMC commit (b720dfe0) and newclock5 (8ea9fb)
Build Highlights:
XBMC:
newclock5:
VideoPlayer: Change codec->codecpar (8ea9fb5f)
OMXImage: fixup: Protect against empty buffer (49abaf8a)
Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (3c7ea594, +4), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
17.8-059, 18 April 2017: Based off OSMC commit (463be769) and newclock5 (bcbbc14d)
Build Highlights:
logging: always log skin name and version when loading
paplayer: restore option for replaygain reduction as clipping protection
Build Details:
XBMC:
[windows] DownloadBuildDeps: add parameters for target & native platform (PR:11966, 2 commits, 4 files changed)
FIX: [droid;leanback] Various fixes (PR:11970, 1 commit, 2 files changed)
logging: always log skin name and version when loading (PR:11973, 1 commit, 1 file changed)
paplayer: restore option for replaygain reduction as clipping protection (PR:11865, 2 commits, 8 files changed)
