17.8-090, 05 Aug 2017: Based off OSMC commit (4bfe43d4) and newclock5 (018879)
Build Highlights
newclock5: ffmpeg fixes (including fix for RPi1 build)
newclock5: GoPro fix
ffmpeg: hevc: Initial 10-bit support
newclock5: more hevc/hi10 tweaks
OSMC:
Temp remove audio decoders due to build errors: audiodecoder.modplug audiodecoder.sidplay audiodecoder.nosefart audiodecoder.snesapu
Temp remove pvr addons due to build errors: pvr.vdr.vnsi pvr.hts pvr.hdhomerun pvr.octonet pvr.dvbviewer pvr.demo pvr.dvblink pvr.filmon pvr.hts pvr.nextpvr pvr.njoy pvr.vbox pvr.vuplus pvr.wmc
Temp remove peripheral.joystick due to build errors
Treat rbpi as linux not a separate platform
SMB fixes for OSMC and Windows systems in 2017
Deprecate weaker share connectivity patch
XBMC:
changed some wordings and punctuations (PR:12567, 1 commit, 1 file changed)
[video] Readd mark watched / unwatched to video folderās context menu (PR:12464, 1 commit, 2 files changed)
[win32] re-work WinSystemWin32 + RenderSystemDX (PR:12377, 4 commits, 25 files changed)
VideoPlayer: vdpau - fix black screen after change of refresh rate (PR:12570, 1 commit, 5 files changed)
[buildsteps] Windows: re-work building mingw libs. (PR:12542, 2 commits, 32 files changed)
[pydocs] Add missing content type āgamesā (PR:12554, 1 commit, 1 file changed)
[cmake] FindBluray.cmake: fix version check (PR:12562, 1 commit, 1 file changed)
[depends] bump openssl to 1.0.2l (PR:12569, 1 commit, 1 file changed)
smbclient: cleanup smbclient configuration (PR:12110, 1 commit, 6 files changed)
[depends] bump automake to 1.15.1 (PR:12613, 1 commit, 1 file changed)
CHG: simplify emu_msvcrt FILE* handling (PR:12528, 1 commit, 4 files changed)
[PVR] Guide window: Fix initialization after skin reload (trac#17546). (PR:12615, 1 commit, 3 files changed)
[PVR] Always check whether a timer has an associated channel. It might be null. (PR:12614, 3 commits, 20 files changed)
[PVR] Cleanup PVR Managerās āupdate current fileā logics (PR:12621, 4 commits, 8 files changed)
Fix peripherals started before strings are loaded (PR:12518, 1 commit, 1 file changed)
[Win32 BufferPool] Remove decoder locks (PR:12551, 1 commit, 1 file changed)
[addons] show update all entry also if only one addon update is available (PR:12531, 1 commit, 1 file changed)
[info] check if m_refreshCounter is zero (PR:12519, 1 commit, 1 file changed)
[pydocs] add missing content type āvideosā (PR:11064, 1 commit, 1 file changed)
VideoPlayer, PVR: remove deprecated streamURL related functions (PR:12550, 1 commit, 3 files changed)
ADD: Implement ZeroConf via Android API (PR:12533, 1 commit, 23 files changed)
Controller window: Bug fixes (PR:12547, 5 commits, 20 files changed)
[VideoPlayer] Windows: fix few code issues (PR:12553, 4 commits, 4 files changed)
FIXUP: [upnp] inverted conditions (PR:12557, 1 commit, 2 files changed)
RetroPlayer: Fix black screen on playback (PR:12546, 3 commits, 6 files changed)
[settings] introduce new setting āStartup actionā and add āPlay TV/Radioā (PR:12548, 5 commits, 15 files changed)
newclock5:
New commits in this build:
ffmpeg: hevc: update to alpha2 (8b14092a)
Revert āfollow ffmpeg docs for avio_alloc_contextā (582f9d50)
core, fixed video playback from GoPro cameras (2c7eaab6)
inputstream.adaptive:
Solve compiler warnings (d8daef42)
Includes latest addons: inputstream.adaptive (1b8ce2ef, +23), inputstream.rtmp (476bde07, +3), peripheral.joystick (1815c0fb, +1), pvr.argustv (4e8c838b), pvr.demo (16469011, +1), pvr.dvblink (729fce75, +1), pvr.dvbviewer (9faf2413), pvr.filmon (1c9d2ebe), pvr.hdhomerun (48868e44), pvr.hts (878757a9, +3), pvr.iptvsimple (8ccf85cc), pvr.mediaportal.tvserver (d7a9acdb, +1), pvr.mythtv (4704f721, +5), pvr.nextpvr (03a3b714), pvr.njoy (79e8e653), pvr.octonet (a77cf111), pvr.pctv (00b76689), pvr.stalker (9e28f125), pvr.vbox (44f3d04e, +9), pvr.vdr.vnsi (9268f008, +1), pvr.vuplus (69f54a00, +1), pvr.wmc (1d655540)
