[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
I updated to Stretch and I am now on OSMC 17.8-139. So far everything worked smooth, no playback issues or any other problems. I was on test builds before and started the upgrade from 17.8-136.
My Kodi library is on MySQL and that’s the thing that’s not working anymore.
Kodi Log says: “MySQL library requested but MySQL support is not compiled in. Falling back to sqlite3.”
So I currently have no access to my library. SMB shares work fine.
Am i missing a package? Tried installing mysql-client but that doesn’t help.
here are the logs
Do you have a local copy of MySQL server running on the Pi?
@gmc - did you depend on libmysqldev-compat? This will fix linking issues with applications that expect old sonames and headers.
You should find these changes in my build scripts
Thanks. Just kicked off another build to fix this.
17.8-140, 6 Dec 2017: Based off OSMC commit (4b90ca4dc) and newclock5 (00f4c69)
OSMC:
Add libmariadbclient-dev-compat to resolve MySQL problem
Add vfs.libarchive
​​​​​​​Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1a48789), pvr.demo (94c4817), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver(6c35e88), pvr.mythtv (8f214cd, +2), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive (a54fb5b, +3)
I updated to stretch and webstreams (youtube, etc.) work fine.
But pvr/tv doesn’t: I use a FRITZ!WLAN Repeater DVB‑C as source (local network streams) with iptv-simple. Before the update everything worked fine. With gmc-138 to 140 the streams won’t play. For 138 a few channels work, for others the stream won’t start (but kodi did not crash). For gmc-139 & 140 kodi crashes when starting such a stream.
I also tried to disable hardware acceleration for omxplayer / mmal, but without success…
Log for gmc-140:
12:53:31.225 T:1820582656  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:31
12:54:34.504 T:1924505600  NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.iptvsimple_1900876138.pvr
12:54:35.925 T:1311765248  NOTICE: Creating InputStream
12:54:35.930 T:1311765248  NOTICE: Creating Demuxer
12:54:36.453 T:1924505600  NOTICE: m_playbackStarting
12:54:36.453 T:1924505600  NOTICE: StereoscopicsManager::IsPlaying
12:55:05.597 T:1924505600  NOTICE: StereoscopicsManager::IsPlaying
12:55:05.979 T:1311765248 WARNING: could not find codec parameters for rtsp://192.168.2.2:554/?freq=434&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=1&pids=0,16,17,18,20,259,533,534,538,1591,1592,1593
12:55:05.980 T:1311765248   ERROR: OpenDemuxStream - Error creating demuxer
12:55:05.980 T:1311765248  NOTICE: CVideoPlayer::OnExit()
12:55:06.104 T:1924505600  NOTICE: m_playbackStarting
Log for gmc-138:
13:09:20.632 T:1204097792  NOTICE: Opening stream: 1 source: 256
13:09:20.632 T:1204097792   DEBUG: CVideoPlayer::HandleMessages - player 2 reported state: 0
13:09:20.634 T:1204097792   DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
13:09:20.634 T:1204097792   DEBUG: CDVDDemuxFFmpeg::AddStream ID: 2
13:09:20.634 T:1204097792   DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1
13:09:20.634 T:1204097792   DEBUG: CDVDDemuxFFmpeg::AddStream - discarding unknown stream with id: 3
13:09:20.634 T:1204097792   DEBUG: CDVDDemuxFFmpeg::AddStream - discarding unknown stream with id: 4
13:09:20.634 T:1204097792   DEBUG: CDVDDemuxFFmpeg::AddStream - discarding unknown stream with id: 5
13:09:20.637 T:1204097792  NOTICE: Opening stream: 0 source: 256
13:09:20.637 T:1204097792  NOTICE: Opening stream: 2 source: 256
13:09:20.638 T:1204097792  NOTICE: Opening stream: 1 source: 256
Thanks, works like a charm now.
17.8-140
https://paste.osmc.tv/ceturuboze
Just updated my system to stretch and the latest Kodi 18 build but now stuck in a sad face loop.
Error happened while upgrading (apt-get dist-upgrade). OSMC start screen (Kodi 18 … Migrating Add-ons) is shown but than sad face… restart.
Holen: 649 http://ftp.debian.org/debian/ stretch/main python-pkg-resources all 33.1.1-1 [166 kB]
osmc@osmc:~$ sudo apt --fix-broken install
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Abhängigkeiten werden korrigiert ... Fertig
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
  armv7-libcrossguid-osmc libavahi-client-dev libavahi-common-dev libavcodec56 libavformat56 libavresample2 libavutil54
  libbasicusageenvironment0 libbind9-90 libboost-chrono1.55.0 libboost-filesystem1.55.0 libboost-locale1.55.0
  libboost-serialization1.55.0 libboost-system1.55.0 libboost-thread1.55.0 libchromaprint0 libdbus-1-dev libdns100
  libdvbpsi9 libelfg0 libgroupsock1 libisc95 libisccc90 libisccfg90 libjson-c2 liblivemedia23 liblwres90
  libmicrohttpd10 libmodplug1 libmysqlclient18 libntdb1 liborc-0.4-0 libplist2 libpostproc52 libschroedinger-1.0-0
  libswscale3 libtimedate-perl libusageenvironment1 libvpx1 libwebp5 libwebpdemux1 libwebpmux1 libx264-142
Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
The following additional packages will be installed:
  libboost-filesystem-dev libboost-filesystem1.62-dev libboost-filesystem1.62.0 libboost-system-dev
  libboost-system1.62-dev
Die folgenden Pakete werden ENTFERNT:
  libboost-filesystem1.55-dev libboost-system1.55-dev rbp2-device-osmc
Die folgenden NEUEN Pakete werden installiert:
  libboost-filesystem1.62-dev libboost-filesystem1.62.0 libboost-system1.62-dev
Die folgenden Pakete werden aktualisiert (Upgrade):
  libboost-filesystem-dev libboost-system-dev
2 aktualisiert, 3 neu installiert, 3 zu entfernen und 155 nicht aktualisiert.
382 nicht vollständig installiert oder entfernt.
Es müssen noch 0 B von 169 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 465 kB Plattenplatz freigegeben.
Möchten Sie fortfahren? [J/n] j
apt (1.4.8) wird eingerichtet ...
Neue Version der Konfigurationsdatei /etc/apt/apt.conf.d/01autoremove wird installiert ...
Neue Version der Konfigurationsdatei /etc/kernel/postinst.d/apt-auto-removal wird installiert ...
usermod: Keine Änderungen
Created symlink /etc/systemd/system/timers.target.wants/apt-daily-upgrade.timer → /lib/systemd/system/apt-daily-upgrade.timer.
Created symlink /etc/systemd/system/timers.target.wants/apt-daily.timer → /lib/systemd/system/apt-daily.timer.
Removing obsolete conffile /etc/cron.daily/apt ...
Vormals nicht ausgewähltes Paket libboost-filesystem1.62.0:armhf wird gewählt.
(Lese Datenbank ... 56342 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../libboost-filesystem1.62.0_1.62.0+dfsg-4_armhf.deb ...
Entpacken von libboost-filesystem1.62.0:armhf (1.62.0+dfsg-4) ...
Vorbereitung zum Entpacken von .../libboost-system-dev_1.62.0.1_armhf.deb ...
Entpacken von libboost-system-dev:armhf (1.62.0.1) über (1.55.0.2) ...
Vorbereitung zum Entpacken von .../libboost-filesystem-dev_1.62.0.1_armhf.deb ...
Entpacken von libboost-filesystem-dev:armhf (1.62.0.1) über (1.55.0.2) ...
(Lese Datenbank ... 56347 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von libboost-filesystem1.55-dev:armhf (1.55.0+dfsg-3) ...
Entfernen von libboost-system1.55-dev:armhf (1.55.0+dfsg-3) ...
Vormals nicht ausgewähltes Paket libboost-system1.62-dev:armhf wird gewählt.
(Lese Datenbank ... 56337 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../libboost-system1.62-dev_1.62.0+dfsg-4_armhf.deb ...
Entpacken von libboost-system1.62-dev:armhf (1.62.0+dfsg-4) ...
Vormals nicht ausgewähltes Paket libboost-filesystem1.62-dev:armhf wird gewählt.
Vorbereitung zum Entpacken von .../libboost-filesystem1.62-dev_1.62.0+dfsg-4_armhf.deb ...
Entpacken von libboost-filesystem1.62-dev:armhf (1.62.0+dfsg-4) ...
Entfernen von rbp2-device-osmc (1.4.4) ...
WARNING: You have tried to remove a package that is essential to OSMC's operation.
To undo these changes, run 'sudo apt-get -f install'.
dpkg: Fehler beim Bearbeiten des Paketes rbp2-device-osmc (--remove):
 Unterprozess installiertes pre-removal-Skript gab den Fehlerwert 1 zurück
Fehler traten auf beim Bearbeiten von:
 rbp2-device-osmc
W: No sandbox user '_apt' on the system, can not drop privileges
osmc@osmc:~$ dpkg -l | grep mediacenter-osmc | awk '{print$3}'
17.8-140
Any ideas how to fix the system?
Can you show the output from
sudo cat /etc/passwd | grep apt
Also try:
osmc@osmc:~$ sudo cat /etc/passwd | grep apt
_apt:x:109:65534::/nonexistent:/bin/false
osmc@osmc:~$ sudo apt-get -f install
  libavformat56 libavresample2 libavutil54 libbasicusageenvironment0
  libboost-locale1.55.0 libboost-serialization1.55.0 libboost-system1.55.0
  libboost-thread1.55.0 libchromaprint0 libdbus-1-dev libdns100 libdvbpsi9
  liblivemedia23 liblwres90 libmicrohttpd10 libmodplug1 libmysqlclient18
  rbp2-device-osmc
0 aktualisiert, 0 neu installiert, 1 zu entfernen und 155 nicht aktualisiert.
386 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 506 kB Plattenplatz freigegeben.
 rbp2-device-osmc
Not sure why it’s trying to remove rbp2-device-osmc
@sam_nazarko any ideas?
Could it be that I messed up the sources.list?
deb http://ftp.debian.org/debian stretch main contrib non-free
deb http://ftp.debian.org/debian/ stretch-updates main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
# deb http://apt.osmc.tv stretch main
deb http://download.osmc.tv/dev/gmc-18 gmc-18 main
Yes, until final release you have to stay on stretch-devel
You need to reinstall if an upgrade on stretch-devel doesn’t solve things
Your system might be hosed
Thanks a lot guys. Added -devel back in, --fix-broken install, update and dist-upgrade and all is working perfectly.
At what point in time do I remove -devel? Now?
After updating, you may wish to edit /etc/apt/sources.list again. Change stretch-devel to stretch to revert back to OSMC’s stable update channel
As soon as the next month update with official Stretch release has been announced
Ok. Once more thanks for your help.
I have a problem with hvec video files. I have a few movies in x265 which work correctly in osmc whit kodi 17. In beta the video is played like a slow temp. In libreelec whit kodi 18 this video it plays correctly.
details of the video file:
17.8-141, 7 Dec 2017: Based off OSMC commit (4b90ca4dc) and newclock5 (00f4c69)
OSMC:
Add depends on libcap2-bin
Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1a48789), pvr.demo (94c4817), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (8f214cd, +2), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993), vfs.libarchive(a54fb5b, +3)
17.8-142, 8 Dec 2017: Based off OSMC commit (4b90ca4dc) and newclock5 (00f4c69)
vfs.libarchive:
changed: disable rar support (8fa085e)
