Thanks for the quick reply. I will take another look at the sources list and get back to you.
Thanks,
Ben
Thanks very much! Solved my problem. I feel like an idiot now ![]()
Thanks,
Ben
Has anyone noticed that the latest nightlies cause their Raspberry Pi 3 to run warm/hot?
What process is running high? Can you show the output of top?
My wife is using the TV today for another thing so I cannot run it right now, but it is when I am streaming video from a NAS drive on my local network that the temp icon appears in the top right and occasionally the video stutters due to the heat. Blowing a fan at it helps it to cool down enough to make the temp icon go away and behavior return to normal. I will try and get the output of the top command when able.
17.8-136, 25 Nov 2017: Based off OSMC commit (f381b5f46) and newclock5 (434079b)
XBMC:
added: flag whether vfs add-ons can handle write operations (PR:13071, 1 commit, 3 files changed)
added: add browsable vfs protocols to CMediaManager::GetNetworkLocations (PR:13070, 1 commit, 1 file changed)
add archive:// to list of url types with encoded hostname (PR:13054, 1 commit, 1 file changed)
[PVR][keymaps][guiinfo] Fix / improve subchannel numbers support (PR:13069, 10 commits, 38 files changed)
changed: drop unused OutputToAllSpeakers setting from database (PR:13074, 1 commit, 3 files changed)
Remove artist_genre table bumping musicdb to 69 (#13042) (8193496)
pvr.hts:
4.2.7: Fixed predictive tuning. (PR:344, 2 commits, 6 files changed)
newclock5:
New commits in this build:
ffmpeg: hevc: Split gpu codec into separate hw accelerated codec (434079b0)
Includes latest addons: inputstream.adaptive (d2081b2, +5), inputstream.rtmp (0702f7e), peripheral.joystick (33b43ce, +11), pvr.argustv (5b9bdad, +2), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (6129441, +1), pvr.filmon (2dee2ca, +2), pvr.hdhomerun (3af3e91, +11), pvr.hts (67fe2df, +11), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88, +1), pvr.mythtv (ffaa1b5, +5), pvr.nextpvr (938bb48, +2), pvr.njoy (4a5efef, +1), pvr.octonet (c4af00a, +1), pvr.pctv (6484615, +4), pvr.stalker (44025a1, +3), pvr.teleboy (2d092c4), pvr.vbox (619c32b, +2), pvr.vdr.vnsi (0ec3e77, +3), pvr.vuplus (7ea6b21, +2), pvr.wmc (55e701b, +1), pvr.zattoo (23d9993, +5)
Sorry to bother you again gmc,
but would it possible (for the next build of course) to include the latest commit from the pvr.teleboy-addon? (e43112625ee624abcf59cdb5983d0909432aac3c)
https://github.com/rbuehlma/pvr.teleboy/commits/master
At the moment it throws some 403-errors, visible in the log.
Much appreciated and thanks in advance! BR
Updating from 134 to 136 and got this error
Err Index of /osmc/osmc/download/dev/gmc-18 ./ rbp2-mediacenter-osmc 17.8-136
Could not connect to ftp.fau.de:80 (131.188.12.211), connection timed out
Fetched 4910 kB in 2min 0s (40.8 kB/s)
E: Failed to fetch http://download.osmc.tv/dev/gmc-18/./rbp2-mediacenter-osmc-25 112017.deb Could not connect to ftp.fau.de:80 (131.188.12.211), connection time d out
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mis sing?
osmc@osmc:~$
Might be a temp issue with the mirror.
Its working here.
Will update in the next build. Busy trying to get it compiled under stretch now so might be a few days.
Its working now
Released 4 days ago a New PVR for HDhomerun if you have more than one the other PVR showing dupe channels with the stock PVR included with KODI this one doesn’t do that !
Use Linux-armhf confirmed working on Leia !
Fair enough, thanks mate!
Nothing should be rebooting itself. If the system is crashing and restarting, you should be investigating the problem.
I updated to the latest nightly and the problem no longer occurs so I cannot post the output of top, sry.
Could well have been a issue that was fixed upstream.
There have been quite a few changes in the last week or two. The main change is that the nightlies are now being built on Debian stretch. In order to run the nightlies you will first need to upgrade the OS to stretch.
Make sure you have a backup. Once the upgrade starts there is no going back.
Once the upgrade has been completed you will need to also complete the following:
Edit
sudo nano /etc/apt/sources.list
The Stretch upgrade should have already commented out (Make sure this is the case)
Then add
deb Index of /osmc/osmc/download/dev/gmc-18 gmc-18 main
Save and exit file.
Import gpg certificate:
wget -qO - http://download.osmc.tv/dev/gmc-18/gpg.key | sudo apt-key add -
Finally run update and dist-upgrade to install latest nightly.
sudo apt-get update
sudo apt-get dist-upgrade
To confirm which version you are running:
dpkg -l | grep mediacenter-osmc | awk ‘{ print $3 }’
Check which versions are available should you wish to install a previous version:
apt-cache madison rbp2-mediacenter-osmc
Install previous versions:
sudo apt-get install rbp2-mediacenter-osmc=17.8-138
Current Version:
17.8-138, 4 Dec 2017: Based off OSMC commit (c8faceb4) and newclock5 (9c5e52)
XBMC:
[Music]Fix cancelling of music library export (PR:13105, 2 commits, 5 files changed)
[PVR] CPVRClient(s): Some more improvements (PR:13113, 3 commits, 4 files changed)
remove accidential left-over prototype (PR:13108, 1 commit, 1 file changed)
[MediaManager/gui] Cache disc label (PR:13107, 2 commits, 2 files changed)
VideoPlayer: drop some outdated and unsafe(threading) code (PR:13110, 1 commit, 9 files changed)
[videoplayer] Show stream flags in the gui and some fixes/improvements. (PR:13058, 10 commits, 34 files changed)
[PVR] Cleanup: No more GUI stuff in class CPVRTimerInfoTag (PR:13098, 2 commits, 9 files changed)
newclock5:
fixup! Apply ffmpeg patches automatically after downloading and extracting the ffmpeg tar ball (9c5e521f)
Apply ffmpeg patches automatically after downloading and extracting the ffmpeg tar ball (789be7c6)
Updated commits in this build:
[ffmpeg] Add GPU acceleration to hevc (8aa5bd3b => 2ad9bca9)
ffmpeg: use upstream mvc patches (ed2ada79 => a0f0d0eb)
Commits no longer in build:
ffmpeg: Allow neon to be enabled in unified builds (3023efbb)
ffmpeg: Add some upstream HEVC optimisations (f9c28636)
ffmpeg: Add cabac opimisations for hevc (e1ff2910)
ffmpeg: mvc: fix for pixelation from packets with no pts/dts (dcb265dd)
ffmpeg: hacky fix for files with GMC (2e518149)
ffmpeg: Update hevc optimisation to use the gpu service (ef0f3835)
core, fixed video playback from GoPro cameras (28f55cc9)
core, add back lost realtime tag for m3u8 (2609e931)
ffmpeg: hevc: Update to latest version (8411eae6)
fixup! omxplayer: Avoid hang when skipping to next video (a50ecdca)
ffmpeg: hevc: Update to latest (d8862749)
ffmpeg: hevc: Rebase on 3.3.4 (231d8cd1)
ffmpeg: hevc: update to latest version (3a9537a4)
ffmpeg: hevc: Reduce memory a little (fb4f7406)
fixup! ffmpeg: hevc: Reduce memory a little (e2c82978)
Revert “fixup! ffmpeg: hevc: Reduce memory a little” (eeb01975)
ffmpeg: hevc: Rebase to 3.4 and reduce memory usage (f49d68f5)
ffmpeg: hevc: Split gpu codec into separate hw accelerated codec (d9081ae1)
fixup! [Stereo3D] Added block_lr and block_rl to supported modes. (2e388e61)
pvr.argustv:
add account info for smb shares (PR:76, 1 commit, 7 files changed)
jsoncpp1.8.3 deprecated function update (PR:77, 1 commit, 4 files changed)
Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497, +1), peripheral.joystick (33b43ce), pvr.argustv (1a48789, +2), pvr.demo (94c4817, +1), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (ffaa1b5), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993)
17.8-139, 4 Dec 2017: Based off OSMC commit (b8b767d) and newclock5 (00f4c69)
XBMC:
DVDVideoCodecAmlogic: Add VP9 HW decoding support (PR:13081, 2 commits, 4 files changed)
drop OSX specific keyboard hack (PR:13104, 1 commit, 8 files changed)
Android: Drop Shield workarounds (not needed anymore) (PR:13111, 1 commit, 2 files changed)
[PVR] Completely reworked playing flags. Moved almost all logic to PVR Manager (PR:13127, 4 commits, 18 files changed)
VideoPlayer: add support for programs (PR:13112, 6 commits, 21 files changed)
pvr.mythtv:
Update MythChannel.cpp (6890230)
bump version 5.5.0 (8f214cd)
Includes latest addons: inputstream.adaptive (d2081b2), inputstream.rtmp (c772497), peripheral.joystick (33b43ce), pvr.argustv (1a48789), pvr.demo (94c4817), pvr.dvblink (816f90c), pvr.dvbviewer (6129441), pvr.filmon (2dee2ca), pvr.hdhomerun (3af3e91), pvr.hts (67fe2df), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88), pvr.mythtv (8f214cd, +2), pvr.nextpvr (938bb48), pvr.njoy (4a5efef), pvr.octonet (c4af00a), pvr.pctv (6484615), pvr.stalker (44025a1), pvr.teleboy (e431126), pvr.vbox (619c32b), pvr.vdr.vnsi (0ec3e77), pvr.vuplus (7ea6b21), pvr.wmc (55e701b), pvr.zattoo (23d9993)
I get this set of unmet dependencies when I try this upgrade from the last nightly before the stretch changeover.
rbp2-mediacenter-osmc : Depends: libtinyxml2.6.2v5 but it is not installable
Depends: libmicrohttpd12 but it is not installable
Depends: libmariadbclient18 but it is not installable
Depends: libpng16-16 but it is not installable
Depends: libtag1v5-vanilla but it is not installable
Depends: libgif7 but it is not installable
Depends: libpcrecpp0v5 but it is not installable
Depends: libssl1.0.2 but it is not installable
Depends: libplist3 but it is not installable
Depends: libcrossguid0 but it is not installable
E: Unable to correct problems, you have held broken packages.
Did you update to Stretch?
It looks like you haven’t done this.
