Confirmed, downgrade to Krypton makes hifiberry appear
I think that the issue is caused by AudioEngine changes in Kodi v18. It looks like the sound implementation is now coupled with the windowing system. On Pi, itâs clear that PISink is brought up, but ALSASink doesnât appear to be.
If that is the issue, then this should probably do the trick:
From da5569f1171172f61ac5274bbde26dd43c636039 Mon Sep 17 00:00:00 2001
Date: Sun, 31 Dec 2017 17:08:42 +0000
Subject: [PATCH] CWinSystemRpi: ensure that we register the ALSA sink as well
as PiSink. This is needed for external DACs
Signed-off-by: Sam Nazarko <email@samnazarko.co.uk>
xbmc/windowing/rpi/WinSystemRpi.cpp | 2 ++
1 file changed, 2 insertions(+)
diff --git a/xbmc/windowing/rpi/WinSystemRpi.cpp b/xbmc/windowing/rpi/WinSystemRpi.cpp
index 9e7f8bd..ac1618c 100644
--- a/xbmc/windowing/rpi/WinSystemRpi.cpp
+++ b/xbmc/windowing/rpi/WinSystemRpi.cpp
@@ -35,6 +35,7 @@
#include "../WinEventsLinux.h"
#include "cores/AudioEngine/AESinkFactory.h"
#include "cores/AudioEngine/Sinks/AESinkPi.h"
+#include "cores/AudioEngine/Sinks/AESinkALSA.h"
#include <EGL/egl.h>
#include <EGL/eglplatform.h>
@@ -55,6 +56,7 @@ CWinSystemRpi::CWinSystemRpi()
m_winEvents.reset(new CWinEventsLinux());
AE::CAESinkFactory::ClearSinks();
CAESinkPi::Register();
+ CAESinkALSA::Register();
CWinSystemRpi::~CWinSystemRpi()
2.7.4
Thanks will add this into the next build.
Im glad it sounds like youâve got to the bottom of the issue chapsâŚHappy New Year to all of the OSMC devs, and many thanks for the hard work you guys/girls? put in.
Ripper Rita!
Installed latest update 154
DACâs working again
Happy New Year
Thanks for confirming.
FYI loopback audio device is still missing in this version.
Iâll stick with 17.8.143 for the time being.
Is the loopback audio device enumerated if you run aplay -l (need alsa-utils installed)?
Im pretty sure it is Sam, Iâll update again and report back.
Indeed it does Sam:
Blockquote
osmc@osmc:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 8/8
card 1: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
card 1: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
Just no way to select it in the System/Audio settings.
Ive tested the device via aplay and can successfully send audio to it and its working fine.
This may be related to a change that drops ânull sinksâ in Kodi.
So I take it thats out of your hands then?
Not the end of the world, iâll just have to stick with 17.8.143 then, that version has all the functionality I need working just fine.
Interesting. Must be from:
PiSink: Treat default as HDMI (fbff01f31)
The latest patch from @sam_nazarko is not included yet.
[PATCH] CWinSystemRpi: ensure that we register the ALSA sink as well as PiSink.
Nightly build which includes this just finished so will upload it shortly.
Oh⌠I grabbed the deb file from
http://ftp.fau.de/osmc/osmc/download/dev/gmc-18/
rbp2-mediacenter-osmc.deb 1/1/18
seemed to do the trick
Ah ok. That explains it. That file does contain the patch. Its finished building but I havenât moved it into aptly yet or posted the build notes. You are too fast
The original is not that easy to follow
To try this:
1.Login via the command line94
2.Edit the file /etc/apt/sources.list
3.Add the following line: deb http://apt.osmc.tv jessie-devel main
4.Check for updates via My OSMC â Updater.
edit the file sudo nano /etc/apt/sources.list because /etc/apt/sources.list errors out
Check for updates via My Osmc On the Raspberry Pi go into OSMC the updates error out.
What is the error?
You still havenât updated to Debian Stretch.
Iâm not sure how we can make it clearer but if you donât do this, you wonât be able to update
