[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
I can confirm that this completely solves the missing loopback audio device issue.
The speed in which you guys resolve any issues is one of the many reasons that OSMC is by far the best kodi distro available.
So to @sam_nazarko, yourself, and everyone else involved… excellent work chaps.
My Hifiberry Digi+ is showing on Kodi 18.
Now, I can finally use Netflix on Kodi
17.8-155, 3 Jan 2018: Based off OSMC commit (775e072e) and newclock5 (b954106)
OSMC:
PulseAudio no longer runs as a system service; don’t check if it’s running when handling the PA sink in Kodi. (001630d210)
XBMC:
  • [Estuary][PVR] PVRInfoPanel: move channel logo to the right, remove default logo. (PR:13271, 2 commits, 2 files changed)
  • [PVR] Guide window: Go to date (PR:13282, 3 commits, 8 files changed)
  • add ftp with implicit SSL support (PR:13285, 1 commit, 2 files changed)
  • OpenGL: some fixes (PR:13287, 4 commits, 5 files changed)
  • [PVR] Fix timeshift gui info. Must be reset if nothing is playing anymore (PR:13281, 2 commits, 3 files changed)
  • windowing/gbm: use first overlay plane and fix vga refresh rate (PR:13286, 2 commits, 1 file changed)
  • changed: added setting for use of video tags (PR:13291, 1 commit, 5 files changed)
  • [depends][windows] Print the mirror redirected to for easier debugging of of mirror issues (PR:13293, 1 commit, 1 file changed)
  • [smartplaylist] add 2160p resolution filter (PR:13086, 1 commit, 1 file changed)
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (6284566), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (bf22a18), pvr.iptvsimple (a768d0e), [url=https://github.com/kodi-pvr/pvr.mediaportal.tvserver]pvr.mediaportal.tvserver/url, pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (3c76791), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)
Libretro looks to be present and working in the 155 release. I’ve got the QuickNES emulator enabled and it runs ROMs. One strange behavior, when looking at the Dependencies window after enabling an emulator it still says that game.libretro is unavailable.
Could just be a problem with the QuickNES build. Do any other libretro addons give the same issue?
forgotten how to check version for leia, how come the command deleted from the 1st post?
I’ve updated the first post. Must have dropped off when I edited it.
sudo dpkg -l | grep mediacenter-osmc
wonder what happened here?
Reading package lists… Done
Building dependency tree
Calculating upgrade… The following packages were automatically installed and are no longer required:
libass5 rbp2-image-4.4.27-5-osmc rbp2-image-4.4.27-7-osmc
rbp2-image-4.9.29-5-osmc
Use ‘apt-get autoremove’ to remove them.
Done
Info is in the output
Packages were auto installed due to some or other dependencies. These are no longer required and can be removed with the supplied command.
17.8-156, 6 Jan 2018: Based off OSMC commit (1287130) and newclock5 (fdf378e)
XBMC:
  • [win10] update dependencies packages and do not add pass-through formats for xaudio HDMI device (PR:13308, 3 commits, 4 files changed)
  • [xbmc][WindowsStore] Set store minimum version (PR:13284, 1 commit, 2 files changed)
  • [gui] always render splash window but hide splash image if configured in AS (PR:13305, 2 commits, 3 files changed)
  • [depends] bump expat to 2.2.5 (PR:13310, 1 commit, 2 files changed)
  • Wayland fixes (PR:13096, 17 commits, 22 files changed)
  • [videoplayer] CVideoPlayer::OpenVideoStream: Pass item’s dynpath to R (PR:13312, 1 commit, 1 file changed)
  • [win10] do not handle back request on non mobile systems. (PR:13313, 1 commit, 1 file changed)
  • fix and simplify PlayFile (PR:13301, 2 commits, 10 files changed)
  • ActiveAESink: We can only do PT if at least one PT format is supported (PR:13309, 1 commit, 1 file changed)
  • Fix usage of CompareNoCase (PR:13175, 7 commits, 6 files changed)
  • VideoPlayer: make m_pInputStream a smart pointer
    (PR:13295, 5 commits, 28 files changed)
pvr.demo:
  • Implement series/episode/eptitle for recordings (PR:58, 1 commit, 4 files changed)
pvr.vdr.vnsi:
  • fix gles rendering of VDR osd (66050a9)
newclock5:
New commits in this build:
  • fixup! libbluray: Bump to Nevcairie’s patches (17b9e2c4)
  • Revert “fixup! libbluray: Bump to Nevcairie’s patches” (bc53d8ab)
  • fixup after PR13295 (fdf378ed)
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (bf22a18), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
Think you need to update the list at the top for the newest releases. You’re still writing dec and not jan :grinning:
Thanks, still stuck in last year :slight_smile:
but i’m still stuck on version 136
Did you do the stretch upgrade?
i did with both, commenting out each to update… didnt work…
sudo apt-get update
Get:1 http://security.debian.org jessie/updates InRelease [63.1 kB]
Ign http://ftp.debian.org jessie InRelease
Get:2 http://ftp.debian.org jessie-updates InRelease [145 kB]
Get:3 http://security.debian.org jessie/updates/main armhf Packages [468 kB]
Hit https://dev2day.de jessie InRelease
Hit http://apt.osmc.tv jessie InRelease
Hit http://ftp.debian.org jessie Release.gpg
Ign http://download.osmc.tv ./ InRelease
Hit https://dev2day.de jessie/main armhf Packages
Hit http://apt.osmc.tv krypton InRelease
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Get:4 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [9868 B]
Get:5 https://dev2day.de jessie/main Translation-en [320 B]
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Get:6 https://dev2day.de jessie/main Translation-en [320 B]
Ign http://download.osmc.tv ./ Release.gpg
Get:7 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Get:8 https://dev2day.de jessie/main Translation-en [320 B]
Get:9 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:10 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Get:11 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Get:12 https://dev2day.de jessie/main Translation-en [320 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Get:13 http://apt.osmc.tv krypton/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Err http://download.osmc.tv ./ Packages
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Get:14 https://dev2day.de jessie/main Translation-en [320 B]
Ign https://dev2day.de jessie/main Translation-en
Ign http://apt.osmc.tv jessie/main Translation-en
Ign http://apt.osmc.tv krypton/main Translation-en
404 Not Found
Ign http://download.osmc.tv ./ Translation-en
Fetched 695 kB in 17s (40.3 kB/s)
W: Failed to fetch http://download.osmc.tv/dev/gmc-18/./Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
osmc@osmc:~$
Commenting out what?
Provide full logs via grab-logs -A
sorry new to this…
https://paste.osmc.tv/qupuyuroba
I don’t think you’ve updated to Stretch. Your source.list still points to jessie
deb http://ftp.debian.org/debian jessie main contrib non-free
deb http://ftp.debian.org/debian/ jessie-updates main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://apt.osmc.tv jessie main
deb http://apt.osmc.tv krypton main
deb http://download.osmc.tv/dev/gmc-18 ./
# deb http://download.osmc.tv/dev/gmc-18 gmc-18 main
This should also be removed as per the first post.
deb Index of /osmc/osmc/download/dev/gmc-18 ./
and the new repo used, and import gpg
As @gmc wrote read the instructions in detail and upgrade to Debian Stretch first.
Also remove this line as it isn’t used for long time
17.8-157, 8 Jan 2018: Based off OSMC commit (31ae9089) and newclock5 (fdf378e)
pvr.hts:
  • 4.2.10: Implement GetStreamTimes for recordings (PR:347, 4 commits, 6 files changed)
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (83ea2d5, +4), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.mythtv (cab8839), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
