finally got it to work! thank u thank u!!!
updating to stretch took quite long, keep on seeing the “sad” face after updating (on 136), then i manually updated to 156 and finally got into osmc gui.
Is pvr.mythtv in the latest build? I decided to try out Leia in the latest nightly build (coming from the stable version) only to find pvr.mythtv missing. I did a bit of digging and it looks like it might have been removed back in Sep '17 and never re-added (based on this change in commit #da91b1d). Is this the case, or am I looking at the wrong thing.
Last build post seems to indicate it is. Did you enable it in the addon browser?
That’s the thing… it’s not listed in Add-ons --> PVR clients.
I’ve just checked the build script and it is indeed missing. I’ll re-add to the next nightly is its building successfully.
17.8-158, 10 Jan 2018: Based off OSMC commit (cb88c8a) and newclock5 (28fcdeca0)
OSMC:
XBMC:
pvr.hts[/url]:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), pvr.stalker (c91421d), pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), vfs.libarchive (568a2a1)[/b]
I have updated. Mine didn’t break it.
Also, it may be premature to tell. But since the build before Christmas day, when I first installed, this one seems to put less strain on the CPUs of my RPi3 while playing Netflix. I didn’t get a single temperature notification.
On a side note. I wonder, is there any possibility to someday use HW decoding instead of SW on the Kodi Netflix addon?
Getting this in update:
Err:5 http://ftp.fau.de/osmc/osmc/download/dev/gmc-18748 gmc-18 Release
404 Not Found
Ouch, copying the link from first post also copy the number of people who clicked the link…
Seems to be a common problem. I’ve changed the formatting
17.8-159, 12 Jan 2018: Based off OSMC commit (01a741) and newclock5 (d6e5222d5)
OSMC:
XBMC:
newclock5:
New commits in this build:
Includes latest addons: inputstream.adaptive (fb0ca21), inputstream.rtmp (482f5c1), peripheral.joystick (3a93486), pvr.argustv (a4d3ec7), pvr.demo (0224cbd, +1), pvr.dvblink (4ac2f2d), pvr.dvbviewer (c2275e1), pvr.filmon (e754b4b), pvr.hdhomerun (7379fbc), pvr.hts (e5e89b1, +5), pvr.iptvsimple (a768d0e), pvr.mediaportal.tvserver (dcf0512), pvr.nextpvr (11dfdbb), pvr.njoy (67b837d), pvr.octonet (c4af00a), pvr.pctv (c7a13d7), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ae0297), pvr.vbox (24126fd), pvr.vdr.vnsi (66050a9, +1), pvr.vuplus (020e1d2), pvr.wmc (920ade6), pvr.zattoo (4940bcc), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
17.8-160, 13 Jan 2018: Based off OSMC commit (9f91aa5e) and newclock5 (8fa588c)
OSMC:
XBMC:
pvr.vdr.vnsi:
newclock5:
Since upgrading to version 156 I can’t get any sound when watching movies or tv series. Currently running 159 and the debug log is from starting a movie, the movie starts playing but with no sound.
Running the same movie in Kodi v18 nightlies on a Mac works without any issues.
If I play music then I get sound and the sound from the interface is also coming thru.
Debug log https://paste.osmc.tv/iduhaqepob
Any suggestions as to what might be the cause?
Can you enable debug logging.
If you go back to 155 does it fix the problem?
I’ll give it a try. Wasn’t the log I provided debug?
Nope, it was a normal log file. You need to enable debug logging. See first post.
Hi!
I’ve exactly the same issue on my RP3 like @haegg78 .
I’ve enabled Debug-Logging and played a movie (“Die Chroniken von Narnia” → you can search the logfile for it to find the relevant part). Here is the log:
https://paste.ubuntu.com/26382936/
The on-screen player info displayed this information while playing the movie:
Video-Decoder: omx-h264 (HW)
Audio-Stream: FL, FR, FC, LFE, SL, SR, dca, 32 bits, 48,000 Hz
Downgrading to 155 (via sudo apt-get install rbp2-mediacenter-osmc=17.8-155) fixes the problem: Sound is back! The on-screen player info shows the same data as mentioned above.
Hopefully now this is a debug log, think the “debug” setting has changed since the last version. You now had to select all the components also and not just enable logging.
I played the movie Cobain: Montage of Heck and I’m on a RBP1 device.
Debug log with issue: https://paste.osmc.tv/wevuwoheco
Debug log with 155 (working): https://paste.osmc.tv/paqonebaxo
Thanks for the logs. Not seeing anything issues.
Looking through the changelog for 156 there was a change for ActiveAESink.
Are you using audio passthrough? What options do you have set?
@haegg78 Still no debugging I’m afraid. Would also help to check the passthrough settings.
08:29:59.460 T:2989419392 NOTICE: Disabled debug logging due to GUI setting. Level 0.
Even with no component logging enabled and just debug logging used your kodi.log file will include tons of DEBUG: lines
You could also try and force logging using the advancedsetting xml file:
http://kodi.wiki/view/Log_file/Advanced#Turn_on_debugging_using_a_file_.28advancedsettings.xml.29
Screenshot of my audio settings, no passthrough:
Debug log with version 160: https://paste.osmc.tv/uvofoficuj
Still no audio.
@sam_nazarko any idea on this one? I can’t replicate the issue but 2 users having the same problem so far.
