On the system setting we have a cpu meter/ temp Does Raspberry have the capability to have a voltage/amp show up ?
There are power supply warnings, yes. See the OSMC FAQ for Pi on the Wiki for further information.
We also manufacture and sell a good, reliable PSU
Best
I have the current build 17.8-006 running on my raspberry pi 3.
Was working great, until today. When I start the rpi it says Addon Migration and shortly after that
Bluescreen and it starts over again.
Yesterday the ZDF ARD Mediathek addon updated itself. Might this be the problem? How can I fix it without starting all over again?
Is there a way to disable addons while booting? I have ssh access to the raspberry even while the Bluescreen.
No log? No problemā¦
Try renaming the kodi directory.
sudo mv /home/osmc/.kodi /home/osmc/.kodi.bak
Anyone else getting this message after kodi boot:
āMounted removable storage deviceā
I have nothing plugged in USB ports, and the RPI3 and microSD card is brand new.
Installed OSMC 11.1 first then installed the latest 18.0 version.
Logs: http://paste.osmc.io/jexayowewa
Thanks! That helps to be able to boot again.
Now for debug, which logs could be usefull to see what the problem is? where can I find the corresponding log?
Strange thing I just saw is: Booting Raspberry at home with wifi logged in --> bluescreen
Booting the same wifi at a friends home without wifi setup --> no bluescreen --> setting up wifi --> bluescreen
So the problems occurs when something while āaddon migrationā does something in the internet.
This may mean your SD card is getting mounted/unmounted. This can happen when the device is not receiving sufficient power.
I have the same message on Kodi 17 version.
I have 5 genuine Raspberry PI 2.5A PSU to test with plus 3 ābigā 5V PSU 20-25A.
I will let you know.
EDIT : I canāt test for now the different PSUs but something maybe affect (or not) this mounting/unmounting thing and I would nned to disable them before testing :
- OC of my SD card using
dtparam=sd_overclock=100 - maybe some compatibility with this particular SD card model witch is relatively new : SanDisk Extreme PLUS 32 GB U3 V30
EDIT: I did forget to post my result without OC on the SDcard. Without any oc, the result is the same : popup box.
Yeah I have two Pi3 and two different brand of microSD. Kingston and Sandisk. My kingston card is giving this message on both pi:s but not the sandisk. Using same PSU on both. So it must be the SD card somehow.
Kingston card has a brand new fresh install.
Any progress on the Keyspan driver ?
Trying to update one of my Raspberryās from 17.8-001 to 17.8-004 using this command
sudo apt-get install rbp2-mediacenter-osmc=17.8-004
Is this the correct way to jump to a certain version ?
Yes
Thank You ! Was having trouble jumping up to certain builds ā¦After I update it would crash then I figured it out ! After I removed some addons then it had no problem !
17.8-006, 12 Dec 2016: Based off OSMC commit (b9120ae19e) and newclock5 (1e24e3be8)
Build Highlights:
minors
XBMC:
[addon] use another way for__declspec and __cdecl on kodi_inputstream_types.h (PR:10894, 1 commit, 1 file changed)
[depends] libpng 1.6.26 (PR:11102, 1 commit, 2 files changed)
[depends] taglib 1.11.1 (PR:11101, 1 commit, 1 file changed)
[depends] curl 7.51.0 (PR:11105, 1 commit, 1 file changed)
VideoPlayer: fix cc after https://github.com/xbmc/xbmc/commit/03aa244⦠(PR:11118, 1 commit, 1 file changed)
[cmake] fix building when fribidi was built with glib (PR:11116, 1 commit, 1 file changed)
[estuary] sync (PR:11121, 1 commit, 32 files changed)
[pvr] bye, bye libXBMC_pvr.cpp (PR:11109, 3 commits, 46 files changed)
[dependencies] remove remaining references to libmodplug (PR:11111, 1 commit, 4 files changed)
Remove reference to libxinerama-dev (PR:11112, 1 commit, 1 file changed)
Remove remaining reference to libmad (PR:11113, 1 commit, 2 files changed)
[gui] fix coverity issue for playlist.position (PR:11127, 1 commit, 1 file changed)
[addons] remove dead code on CAddonDll (PR:11134, 1 commit, 1 file changed)
Fix coverty defects (PR:11066, 4 commits, 8 files changed)
[cec] missed change in cmake file after cc3ae0339faf2b669bee20cb360c5⦠(PR:11140, 1 commit, 1 file changed)
Remove remaining references to glew (PR:11128, 1 commit, 2 files changed)
[inputstream] bye, bye libKODI_inputstream.cpp (PR:11129, 2 commits, 12 files changed)
[lang][skin.estuary] automatic syntax corrections for the en_GB language file (9528ba96)
[lang][skin.estuary] updated language files from Transifex (5c430be3)
[lang][skin.estouchy] updated language files from Transifex (fdb7a0b7)
17.8-008, 12 Jan 2017: Based off OSMC commit (b9120ae19e) and newclock5 (a1d171ff76)
Build Highlights:
We are back again after a month. There have been lots of fixes - way too many to mention.
Reason for the long delay is Kodi is now build using cmake which caused a few issues with OSMC. Hopefully these should be resolved now and we can get back to the nightly builds.
No sweat ! It was the holidays you guys needed a brake
17.8-009, 13 Jan 2017: Based off OSMC commit (b9120ae19e) and newclock5 (cb07837f3)
Build Highlights:
MMALCodec: Add extra prime to avoid stalled video
libbluray 0.9.3-1
libcec 4.0.0-2
XBMC:
Revert ā[cmake/win32] Donāt use system wide installed dependenciesā (PR:11423, 1 commit, 1 file changed)
XML nodes - cleanup (PR:11415, 1 commit, 74 files changed)
follow up to Commit:4cf4253 (PR:11422, 1 commit, 1 file changed)
[CEC] fix 4.0.1 package name (PR:11426, 1 commit, 1 file changed)
Revert ā[CEC] fix 4.0.1 package nameā (PR:11428, 1 commit, 1 file changed)
newclock5:
New commits in this build:
MMALCodec: Add extra prime to avoid stalled video (cb07837f)
Commits no longer in build:
MMALCodec: Need an extra referenced buffer with new ffmpeg scheme (e617fec6)
breaks on addon migration⦠and crashes
Logs available at http://paste.osmc.io/eqefetobil
DB issues?
11:15:33.160 T:1937765360 ERROR: Unable to open database: MyVideos78 [2003](Can't connect to MySQL server on '10.0.0.10' (111)) 11:15:33.161 T:1937765360 ERROR: Unable to open database: MyVideos77 [2003](Can't connect to MySQL server on '10.0.0.10' (111)) 11:15:33.162 T:1937765360 ERROR: Unable to open database: MyVideos76 [2003](Can't connect to MySQL server on '10.0.0.10' (111)) 11:15:33.163 T:1937765360 ERROR: Unable to open database: MyVideos75 [2003](Can't connect to MySQL server on '10.0.0.10' (111)) 11:15:33.164 T:1937765360 ERROR: Unable to open database: MyVideos108 [2003](Can't connect to MySQL server on '10.0.0.10' (111)) 11:15:33.164 T:1937765360 ERROR: Unable to create new database
