Sorry, first time. I think this should be right
====================== APT sources.list =================== ZZz2wrJ1
deb http://ftp.debian.org/debian jessie main contrib non-free
deb http://ftp.debian.org/debian/ jessie-updates main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://apt.osmc.tv jessie main
deb http://apt.osmc.tv krypton main
deb http://download.osmc.tv/dev/gmc ./
deb http://download.osmc.tv/dev/gmc-18 ./
Iām pretty sure you have to run one or the other gmc repos⦠Remove one.
This has been covered.
You canāt update via My OSMC if you use GMCās builds.
Weāll have to adjust the updater to account for this.
Sorry Sam my bad didnāt read everything
Just did the update via command line and itās unpacked -005 over -003 correctly
Ouch !!! The next morning turn on the TV I see my Automatic Update addon because I have my WMC recording 24/7 show me server not showing click yes to remove or leave it alone. So clicked leave it alone. Then I watched Kodi on the latest build reboot like 4 times then crash⦠Sorry can not get the log.
You really seem like you are more interested in having a stable system. Iām really not sure why you are trying to run these very early development builds where breakage is expected and may not have fixes immediately available.
HELL NO ! I have 4 piās running with all different buildsā¦Just want to keep updating whats going on. When Krypton and my logs didnāt work I was told to move on to 18 ⦠Sorry buddy its not me ⦠and ā¦
Iāve updated the description to make sure only one repo is used. Seems like a common issue.
17.8-005, 11 Dec 2016: Based off OSMC commit (b9120ae19e) and newclock5 (1523b6bdd)
Build Highlights:
minors
inputstream.adaptive:
use 64bit values for frameduration transformation (e93d9e9d)
Start livestreams 12 secs before now (29e25f31)
17.8-006, 12 Dec 2016: Based off OSMC commit (b9120ae19e) and newclock5 (1523b6bdd)
Build Highlights:
minors
XBMC:
Fix performace problem with CFileItem::IsGame unnecessarily accessing addon db for PVR content. (PR:11098, 1 commit, 1 file changed)
[gui] return āā instead of ā0ā for playlist.position in case nothing is playing (PR:11041, 1 commit, 1 file changed)
[addon] remove not needed header comment in CScreenSaver (PR:10972, 1 commit, 1 file changed)
[depends] libass 0.13.4 (PR:11104, 1 commit, 1 file changed)
[gui] add container.actualitems infolabel (PR:10888, 1 commit, 3 files changed)
peripheral.joystick:
Silence error in Kodi log (PR:71, 1 commit, 3 files changed)
pvr.mediaportal.tvserver:
Update to 3.0.1 (PR:54, 6 commits, 10 files changed)
pvr.mythtv:
5.0.2 (PR:84, 4 commits, 6 files changed)
Nothing broken but I still have Live TV studder on HD channels do my logs help ?
Seeing loads of these errors - no idea on the error though.
17:12:05.729 T:1198519280 ERROR: ffmpeg[476FF3F0]: [mpeg2video] Invalid frame dimensions 0x0.
Would a log from the working Krypton for comparison help ?
Sorry missed this post Yes the CNN HD channel is in 1080 I use the scrolling news marque as the test on the builds
Smooth on Latest Krypton
Smooth on the First build I think on 18 but not anymore little studder
When I get a chance I will read up on moving back to the original build of 18 to double check it
Ok did the following
remove the GMC repository from sources.list and then run
sudo apt-get update
sudo apt-get install rbp2-mediacenter-osmc=17.8-001
Did not work
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Dec 14 12:38:55 2016 from 10.0.0.3
osmc@osmc:~$ sudo apt-cache policy | grep team-xbmc
osmc@osmc:~$ sudo nano /etc/apt/sources.list
osmc@osmc:~$ sudo apt-get update
Get:1 http://security.debian.org jessie/updates InRelease [63.1 kB]
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://ftp.debian.org jessie Release.gpg
Get:2 http://security.debian.org jessie/updates/main armhf Packages [321 kB]
Get:3 http://security.debian.org jessie/updates/contrib armhf Packages [1138 B]
Get:4 http://security.debian.org jessie/updates/non-free armhf Packages [14 B]
Get:5 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [6916 B]
Get:6 http://security.debian.org jessie/updates/contrib Translation-en [1211 B]
Get:7 http://security.debian.org jessie/updates/main Translation-en [175 kB]
Hit http://apt.osmc.tv jessie InRelease
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Hit http://apt.osmc.tv krypton InRelease
Get:8 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Get:9 http://security.debian.org jessie/updates/non-free Translation-en [14 B]
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:10 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2704 B]
Get:11 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Get:12 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Get:13 http://apt.osmc.tv krypton/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Ign http://apt.osmc.tv jessie/main Translation-en
Ign http://apt.osmc.tv krypton/main Translation-en
Fetched 577 kB in 13s (44.1 kB/s)
Reading package lists... Done
osmc@osmc:~$ sudo apt-get install rbp2-mediacenter-osmc=17.8-001
Building dependency tree
E: Version '17.8-001' for 'rbp2-mediacenter-osmc' was not found
osmc@osmc:~$ The programs included with the Debian GNU/Linux system are free software;
-bash: The: command not found
osmc@osmc:~$ the exact distribution terms for each program are described in the
-bash: the: command not found
osmc@osmc:~$ individual files in /usr/share/doc/*/copyright.
-bash: individual: command not found
osmc@osmc:~$
osmc@osmc:~$ Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
-bash: Debian: command not found
osmc@osmc:~$ permitted by applicable law.
-bash: permitted: command not found
osmc@osmc:~$ Last login: Wed Dec 14 12:38:55 2016 from 10.0.0.3
-bash: Last: command not found
osmc@osmc:~$ osmc@osmc:~$ sudo apt-cache policy | grep team-xbmc
-bash: osmc@osmc:~$: command not found
osmc@osmc:~$ osmc@osmc:~$ sudo nano /etc/apt/sources.list
osmc@osmc:~$ osmc@osmc:~$ sudo apt-get update
osmc@osmc:~$ Get:1 http://security.debian.org jessie/updates InRelease [63.1 kB]-bash: Get:1: command not found
osmc@osmc:~$ Ign http://ftp.debian.org jessie InRelease
-bash: Ign: command not found
osmc@osmc:~$ Hit http://ftp.debian.org jessie-updates InRelease
-bash: Hit: command not found
osmc@osmc:~$ Hit http://ftp.debian.org jessie Release.gpg
osmc@osmc:~$ Get:2 http://security.debian.org jessie/updates/main armhf Packages [321 kB]
-bash: Get:2: command not found
osmc@osmc:~$ Get:3 http://security.debian.org jessie/updates/contrib armhf Packages [1138 B]
-bash: Get:3: command not found
osmc@osmc:~$ Get:4 http://security.debian.org jessie/updates/non-free armhf Packages [14 B]
-bash: Get:4: command not found
osmc@osmc:~$ Get:5 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [6916 B]
-bash: Get:5: command not found
osmc@osmc:~$ Get:6 http://security.debian.org jessie/updates/contrib Translation-en [1211 B]
-bash: Get:6: command not found
osmc@osmc:~$ Get:7 http://security.debian.org jessie/updates/main Translation-en [175 kB]
-bash: Get:7: command not found
osmc@osmc:~$ Hit http://apt.osmc.tv jessie InRelease
osmc@osmc:~$ Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
osmc@osmc:~$ Hit http://apt.osmc.tv krypton InRelease
osmc@osmc:~$ Get:8 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
-bash: Get:8: command not found
osmc@osmc:~$ Get:9 http://security.debian.org jessie/updates/non-free Translation-en [14 B]
-bash: Get:9: command not found
osmc@osmc:~$ Hit http://ftp.debian.org jessie-updates/contrib Translation-en
osmc@osmc:~$ Get:10 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2704 B]
-bash: Get:10: command not found
osmc@osmc:~$ Get:11 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
-bash: Get:11: command not found
osmc@osmc:~$ Get:12 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
-bash: Get:12: command not found
osmc@osmc:~$ Hit http://ftp.debian.org jessie/main armhf Packages
osmc@osmc:~$ Get:13 http://apt.osmc.tv krypton/main armhf Packages/DiffIndex [2023 B]
-bash: Get:13: command not found
osmc@osmc:~$ Hit http://ftp.debian.org jessie/contrib armhf Packages
osmc@osmc:~$ Hit http://ftp.debian.org jessie/non-free armhf Packages
osmc@osmc:~$ Hit http://ftp.debian.org jessie/contrib Translation-en
osmc@osmc:~$ Hit http://ftp.debian.org jessie/main Translation-en
osmc@osmc:~$ Hit http://ftp.debian.org jessie/non-free Translation-en
osmc@osmc:~$ Ign http://apt.osmc.tv jessie/main Translation-en
osmc@osmc:~$ Ign http://apt.osmc.tv krypton/main Translation-en
osmc@osmc:~$ Fetched 577 kB in 13s (44.1 kB/s)
-bash: syntax error near unexpected token `('
osmc@osmc:~$ Reading package lists... Done
-bash: Reading: command not found
osmc@osmc:~$ osmc@osmc:~$ sudo apt-get install rbp2-mediacenter-osmc=17.8-001
osmc@osmc:~$ Building dependency tree
-bash: Building: command not found
osmc@osmc:~$ Reading state information... Done
osmc@osmc:~$ E: Version '17.8-001' for 'rbp2-mediacenter-osmc' was not found
-bash: E:: command not found
osmc@osmc:~$
PLEASE if you arenāt going to use a pastebin for long runs of code, use the </> code tags when posting!
Sorryā¦Didnāt think I needed a log I thought one of the lines I entered was wrong
As soon as this is in, Iāll be testing with the wireless 360 controller again. Like with the custom kernel 4 months ago.
There has to be a way to use this widespread device as both remote control and game controller in OSMC without the need for a dual boot environment.
Thread is on watch list now. ![]()
Update on working on All builds from 17 up to 18 As you know I am testing the Hdhomerun Comcast Testing Channel is CNN HD 1080 switching around different buildsā¦GUESS what !! My Canakit USB 2.5 amp power supply is not sending full voltage !! Im ordering a USB voltage meter
All my hard work ! with Crappy supply !
Power supplies make a huge difference. Had one go flaky on me the other day.
