https://paste.osmc.tv/cazaxocese
hope this will help
hope this will help
Are you trying to use ethernet and the usb adapter simultaneously?
no this is only to make it work.
i tried without the usb adapter
i tried without wifi
Might be worth attempting a re-install. As you can see, there are only 3 complaints (of which 1 seems to be a 10 day old driveby.) There are certainly many more Pi3B+ users who haven’t reported any such issue.
First of all i need to sorry for dublicate this problem but i think this problem also effects to wired ehternet connection. I’m using a Can-Bus adapter with my PI3B an when i try to get message from canbus system freezes. it happens after kernel update 4.14.26-2. my “dmesg -w” report has these lines when i try to connect.
[ 24.058216] can: controller area network core (rev 20170425 abi 9)
[ 24.058349] NET: Registered protocol family 29
[ 24.066710] can: raw protocol (rev 20170425)
[ 24.358243] ------------[ cut here ]------------
[ 24.358275] kernel BUG at net/netlink/af_netlink.c:1326!
[ 24.358287] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[ 24.358302] Modules linked in: can_raw can bnep hci_uart bluetooth ecdh_generic ipt_MASQUERADE nf_nat_masquerade_ipv4 8021q garp bridge stp llc iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack uinput iptable_mangle iptable_filter brcmfmac brcmutil cfg80211 rfkill joydev mcp251x evdev snd_bcm2835© can_dev snd_pcm snd_timer snd bcm2835_thermal bcm2835_gpiomem spi_bcm2835 uio_pdrv_genirq fixed uio ip_tables x_tables ipv6
[ 24.358474] CPU: 3 PID: 515 Comm: ntpd Tainted: G C 4.14.26-2-osmc #1
[ 24.358487] Hardware name: BCM2835
[ 24.358497] task: aae50000 task.stack: a50f6000
[ 24.358518] PC is at netlink_has_listeners+0x98/0x9c
[ 24.358537] LR is at __sk_free+0xb4/0xe4
[ 24.358548] pc : [<8086363c>] lr : [<807f9ab0>] psr: 60070013
[ 24.358561] sp : a50f7e98 ip : a50f7eb0 fp : a50f7eac
[ 24.358572] r10: a75ec720 r9 : 00000008 r8 : 00000000
[ 24.358584] r7 : a75ec720 r6 : 00000000 r5 : 00000002 r4 : add8cb80
[ 24.358597] r3 : 8037bbe8 r2 : 00000000 r1 : 00000002 r0 : add8cb80
[ 24.358612] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 24.358625] Control: 10c5383d Table: 250fc06a DAC: 00000055
[ 24.358637] Process ntpd (pid: 515, stack limit = 0xa50f6210)
[ 24.358649] Stack: (0xa50f7e98 to 0xa50f8000)
[ 24.358661] 7e80: adfb49c0 adfb4b40
[ 24.358679] 7ea0: a50f7ec4 a50f7eb0 807f9ab0 808635b0 adfb49c0 adfb4b40 a50f7ee4 a50f7ec8
[ 24.358697] 7ec0: 807fabb0 807f9a08 adfb49c0 a75ec700 ae9f4110 a75ec720 a50f7ef4 a50f7ee8
[ 24.358719] 7ee0: 808af7a8 807faad4 a50f7f0c a50f7ef8 808c0dcc 808af7a4 a75ec720 00000000
[ 24.358739] 7f00: a50f7f24 a50f7f10 807f3b80 808c0d84 aada59c0 a762ebb0 a50f7f64 a50f7f28
[ 24.358760] 7f20: 80315f14 807f3b58 00000000 00000000 aada59c0 aada59c8 aae50000 00000000
[ 24.358780] 7f40: aae50550 aae50000 aae5056c 80f8abc0 aada59c0 00000000 a50f7f8c a50f7f68
[ 24.358801] 7f60: 80151b50 80315e80 00000004 a50f6000 a50f7fb0 8010c7a8 8010c7a8 a50f6000
[ 24.358821] 7f80: a50f7fac a50f7f90 80110554 80151abc 00000005 7eadde80 00000080 00000006
[ 24.358841] 7fa0: 00000000 a50f7fb0 8010c5f4 8011048c 00000000 7eadde4c 76f71c64 00000002
[ 24.358862] 7fc0: 00000005 7eadde80 00000080 00000006 005265bc 00000000 0052aad8 005265bc
[ 24.358882] 7fe0: 00000000 7eadde68 00000000 76cf64f2 00070030 00000005 2f7fa861 2f7fac61
[ 24.358918] [<8086363c>] (netlink_has_listeners) from [<807f9ab0>] (__sk_free+0xb4/0xe4)
[ 24.358943] [<807f9ab0>] (__sk_free) from [<807fabb0>] (sk_common_release+0xe8/0x118)
[ 24.358969] [<807fabb0>] (sk_common_release) from [<808af7a8>] (udp_lib_close+0x10/0x14)
[ 24.358996] [<808af7a8>] (udp_lib_close) from [<808c0dcc>] (inet_release+0x54/0x80)
[ 24.359018] [<808c0dcc>] (inet_release) from [<807f3b80>] (sock_close+0x34/0xc8)
[ 24.359042] [<807f3b80>] (sock_close) from [<80315f14>] (____fput+0xa0/0x1f0)
[ 24.359065] [<80315f14>] (____fput) from [<80151b50>] (task_work_run+0xa0/0xc0)
[ 24.359090] [<80151b50>] (task_work_run) from [<80110554>] (do_work_pending+0xd4/0xd8)
[ 24.359113] [<80110554>] (do_work_pending) from [<8010c5f4>] (slow_work_pending+0xc/0x20)
[ 24.359136] Code: e1a00004 e89da830 e3a04000 eafffffa (e7f001f2)
[ 24.359153] —[ end trace 725de02c9123599c ]—
[ 24.934384] ------------[ cut here ]------------
[ 24.934418] kernel BUG at net/netlink/af_netlink.c:1326!
[ 24.934432] Internal error: Oops - BUG: 0 [#2] PREEMPT SMP ARM
[ 24.934448] Modules linked in: can_raw can bnep hci_uart bluetooth ecdh_generic ipt_MASQUERADE nf_nat_masquerade_ipv4 8021q garp bridge stp llc iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack uinput iptable_mangle iptable_filter brcmfmac brcmutil cfg80211 rfkill joydev mcp251x evdev snd_bcm2835© can_dev snd_pcm snd_timer snd bcm2835_thermal bcm2835_gpiomem spi_bcm2835 uio_pdrv_genirq fixed uio ip_tables x_tables ipv6
[ 24.934628] CPU: 1 PID: 609 Comm: sudo Tainted: G D C 4.14.26-2-osmc #1
[ 24.934645] Hardware name: BCM2835
[ 24.934658] task: a50edb80 task.stack: a5246000
[ 24.934681] PC is at netlink_has_listeners+0x98/0x9c
[ 24.934696] LR is at __sk_free+0xb4/0xe4
[ 24.934709] pc : [<8086363c>] lr : [<807f9ab0>] psr: 60070013
[ 24.934723] sp : a5247e98 ip : a5247eb0 fp : a5247eac
[ 24.934736] r10: ad8528e0 r9 : 00000008 r8 : 00000000
[ 24.934751] r7 : ad8528e0 r6 : 00000000 r5 : 00000002 r4 : add8cb80
[ 24.934765] r3 : 8037bbe8 r2 : 00000000 r1 : 00000002 r0 : add8cb80
[ 24.934783] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 24.934800] Control: 10c5383d Table: 2532406a DAC: 00000055
[ 24.934814] Process sudo (pid: 609, stack limit = 0xa5246210)
[ 24.934828] Stack: (0xa5247e98 to 0xa5248000)
[ 24.934843] 7e80: ade34d00 ade34e80
[ 24.934865] 7ea0: a5247ec4 a5247eb0 807f9ab0 808635b0 ade34d00 ade34e80 a5247ee4 a5247ec8
[ 24.934887] 7ec0: 807fabb0 807f9a08 ade34d00 ad8528c0 ae9f4110 ad8528e0 a5247ef4 a5247ee8
[ 24.934907] 7ee0: 808af7a8 807faad4 a5247f0c a5247ef8 808c0dcc 808af7a4 ad8528e0 00000000
[ 24.934930] 7f00: a5247f24 a5247f10 807f3b80 808c0d84 a51936c0 a7755088 a5247f64 a5247f28
[ 24.934950] 7f20: 80315f14 807f3b58 00000000 00000000 a51936c0 a51936c8 a50edb80 00000000
[ 24.934972] 7f40: a50ee0d0 a50edb80 a50ee0ec 80f8abc0 a51936c0 00000000 a5247f8c a5247f68
[ 24.934994] 7f60: 80151b50 80315e80 00000004 a5246000 a5247fb0 8010c7a8 8010c7a8 a5246000
[ 24.935015] 7f80: a5247fac a5247f90 80110554 80151abc 7e954200 0070cff8 7e9543d8 00000006
[ 24.935036] 7fa0: 00000000 a5247fb0 8010c5f4 8011048c 00000000 0000001c ffffffff 0000000a
[ 24.935056] 7fc0: 7e954200 0070cff8 7e9543d8 00000006 00000003 7e954400 0000000f 00000006
[ 24.935078] 7fe0: 00000006 7e954110 76dbe9bf 76d4f6f6 60070030 0000000f 00000000 00000000
[ 24.935108] [<8086363c>] (netlink_has_listeners) from [<807f9ab0>] (__sk_free+0xb4/0xe4)
[ 24.935134] [<807f9ab0>] (__sk_free) from [<807fabb0>] (sk_common_release+0xe8/0x118)
[ 24.935160] [<807fabb0>] (sk_common_release) from [<808af7a8>] (udp_lib_close+0x10/0x14)
[ 24.935185] [<808af7a8>] (udp_lib_close) from [<808c0dcc>] (inet_release+0x54/0x80)
[ 24.935210] [<808c0dcc>] (inet_release) from [<807f3b80>] (sock_close+0x34/0xc8)
[ 24.935235] [<807f3b80>] (sock_close) from [<80315f14>] (____fput+0xa0/0x1f0)
[ 24.935257] [<80315f14>] (____fput) from [<80151b50>] (task_work_run+0xa0/0xc0)
[ 24.935282] [<80151b50>] (task_work_run) from [<80110554>] (do_work_pending+0xd4/0xd8)
[ 24.935306] [<80110554>] (do_work_pending) from [<8010c5f4>] (slow_work_pending+0xc/0x20)
[ 24.935328] Code: e1a00004 e89da830 e3a04000 eafffffa (e7f001f2)
[ 24.935344] —[ end trace 725de02c9123599d ]—
17.8-204, 4 April 2018: Based off OSMC commit (eb8eef53) and newclock5 (88d0637)
XBMC:
inputstream.adaptive:
newclock5:
New commits in this build:
Includes latest addons:
inputstream.adaptive (554a84b, +2), inputstream.rtmp (7fe7dde), peripheral.joystick (80224e1), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (51dbe21), pvr.dvbviewer (f1746c5), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (a7176f3), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (ac0da38), vfs.libarchive (e7d149e)
hi @gmc
i have a problem with the latest nightly builds. I use a Raspberry Pi 2 and the last working build ist the 17.8-200. All versions above crash on startup. I have grab a log and hope you can tell me what the issue is. https://paste.osmc.tv/ivijubeqoy
I have also a Raspberry Pi 3 and theres no issue with the latest builds.
Thanks for your help
hedeon
Not seeing any specific errors but looks like its crashing right after the loading the amazon plugin so maybe this is the issue.
Try rename .kodi to .kodi.old and see if it starts up without any plugins loaded.
Thanks for your help.
With rename .kodi my pi starts normaly.
After further investigation i found out that the problem was my advancedsettings.xml.
Now all running fine
17.8-205, 5 April 2018: Based off OSMC commit (eb8eef53) and newclock5 (5417acd)
OSMC:
XBMC:
inputstream.rtmp:
newclock5:
Commits no longer in build:
Includes latest addons: inputstream.adaptive (d129e4b, +4), inputstream.rtmp (7fe7dde), peripheral.joystick (80224e1), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (51dbe21), pvr.dvbviewer (f1746c5), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (a7176f3), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (ac0da38), vfs.libarchive (e7d149e)
17.8-206, 6 April 2018: Based off OSMC commit (eb8eef568faafcbc3) and newclock5 (5417acd)
OSMC:
inputstream.adaptive (d129e4b, +4), inputstream.rtmp (3b5058d, +1), peripheral.joystick (80224e1), pvr.argustv (3556049), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (51dbe21), pvr.dvbviewer (f1746c5), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (a7176f3), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (ac0da38), vfs.libarchive (e7d149e)
I also have a Pi3B+ and the problem that the ethernet connection was not working. I just put the SD card from the Pi3B into the Pi3B+. Everything else worked perfectly.
I tried a lot oft things, but nothing helped.
At the end I did a complete reinstall and it’s working now.
I have been watching this topic for a few weeks now as the 18.? release lets me watch my netflix subscription. This addon is not functioning after the 205 release and I am/have reverted back to 204… I will be combing the thread trying to learn what to do to get logs that I can provide you with in the event that the kodi is broken or the addon is broken… I guess in any case I will need to participate in the resolve - very exciting to help out, I hope my skillset stands the challenge. Cheers let me know if there is anything else I can help with/do.
17.8-204 logs with kodi using netflix addon https://paste.osmc.tv/aravivaqer no crash
17.8-206 logs with kodi using netflix addon https://paste.osmc.tv/ewimuwecit not crashing
17.8-205 logs with kodi using netflix addon https://paste.osmc.tv/bupiwagage one crash then works…
the more I think about it the more I wonder if this is the time and place for this - I guess it is a place holder for the details on my OSMC/KODI adventure. Thanks for all the hard work I appreciate it.
With release 205, inputstream.adaptive was bumped to 2.2.10. I’m guessing there might need to be some updates to the Netflix addon.
17.8-207, 7 April 2018: Based off OSMC commit (a54e5e9) and newclock5 (5417acd)
XBMC:
inputstream.adaptive (2f631c1, +6), inputstream.rtmp (3b5058d, +1), peripheral.joystick (80224e1), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (51dbe21), pvr.dvbviewer (f1746c5), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (a7176f3), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (ac0da38), vfs.libarchive (e7d149e)
Since a few days I can no longer update OSMC.
Otherwise the system is running fine.
I made a few changes:
Any ideas why I can no longer update?
Steps to recreate the issue:
Due to pi-hole logs are a bit messy… sorry.
Pi-hole messes with the the dns settings. Easiest will be to re-install.
Otherwise you can try fixup resolve.conf.
Apr 07 22:40:28 osmc dnsmasq[367]: DNS service limited to local subnets
Apr 07 22:40:28 osmc dnsmasq[367]: no servers found in /etc/resolv.conf, will retry
17.8-208, 8 April 2018: Based off OSMC commit (1ab259) and newclock5 (f86dd87)
XBMC:
pvr.teleboy:
newclock5:
Upated commits in this build:
inputstream.adaptive (f66e2de, +11), inputstream.rtmp (3b5058d, +1), peripheral.joystick (80224e1), pvr.argustv (3556049), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (51dbe21), pvr.dvbviewer (f1746c5), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (683bfa1, +1), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (ac0da38), [url=https://github.com/notspiff/vfs.libarchive]vfs.libarchive/url
17.8-209, 10 April 2018: Based off OSMC commit (a38621e) and newclock5 (b2dfd70)
XBMC:
pvr.demo:
pvr.dvblink:
pvr.dvbviewer:
pvr.filmon:
pvr.hdhomerun:
pvr.hts:
pvr.iptvsimple:
pvr.mediaportal.tvserver:
pvr.mythtv:
pvr.nextpvr:
pvr.njoy:
pvr.pctv:
pvr.stalker:
pvr.vbox:
pvr.vdr.vnsi:
pvr.vuplus:
pvr.wmc:
pvr.zattoo:
inputstream.adaptive (a7eca16, +13), inputstream.rtmp (3b5058d, +1), peripheral.joystick (80224e1), pvr.argustv (3556049), pvr.demo(d5e5cd1, +1), pvr.dvblink (c61ea73, +1), pvr.dvbviewer (1ef88c6, +10), pvr.filmon (0ca1665, +1), pvr.hdhomerun (484b91d, +1), pvr.hts (9533cce, +1), pvr.iptvsimple(77156cb, +1), pvr.mediaportal.tvserver (9702684, +1), pvr.mythtv (9d15025, +1), pvr.nextpvr (de30ff2, +1), pvr.njoy (bd6581f, +1), pvr.octonet (689afbf), pvr.pctv(5e95300, +1), pvr.stalker (da6f0f8, +1), pvr.teleboy (683bfa1, +1), pvr.vbox (3cf15ad, +1), pvr.vdr.vnsi (d6fe796, +1), pvr.vuplus (00a963f, +1), pvr.wmc (2acca13, +1), pvr.zattoo (7b22f4e, +1), vfs.libarchive (e7d149e)
