Thanks gmc! Ok I will try the patched file… and I’ll keep you informed
Weird. Can you post some debug logs.
I just installed 17.8-198, and osmc has gone sad face.
‘journalctl -xe’ reveals, that something is referencing libbluray.so.2, which is nowhere to be found.
It seems, that soft-linking it to libbluray.so.1.10.0 temporarily fixes this:
commandline:
sudo ln -s /usr/osmc/lib/libbluray.so.1.10.0 /usr/osmc/lib/libbluray.so.2
I did a ‘grab-logs -A’ to https://paste.osmc.tv/hahunisuti
When using a testing build I suggest to check the thread a bit more
Yea, I just found that to my own embarrassment.
Thanks anyways, works as described!
I have problem my osmc runing only sed face ![]()
Somebody help me ?
my logs:
https://paste.osmc.tv/eyuputokuk
Are you kidding me?
Have you read at least the last 4 posts here before posting your report?
Just a reminder, this is a [TESTING] thread which expect some testing and checking and not expecting everything spoon feed.
sorry I read from the top (after your post I read from below). Thanks. A simple solution is usually the hardest to find
17.8-199, 25 March 2018: Based off OSMC commit (4afa88b5) and newclock5 (338464a)
OSMC:
- Add support to mix LFE channels in to L/R (965a8791a)
- Add libbluray 1.0.1 to nightly repo so you no longer have to point to stretch-devel for libbluray update
XBMC:
- [cmake] fix Ninja generator after #13673 (PR:13678, 1 commit, 1 file changed)
- Fix disappointing lack of games after entering cheat code (PR:13603, 1 commit, 1 file changed)
inputstream.adaptive:
- [HLS] select proper extension position (first . before ?) (b2965bd)
vfs.libarchive:
- travis: build on xenial and use xcode9 (e7d149e)
newclock5:
New commits in this build:
- ffmpeg: hevc: Rework deblock control (338464a4)
Includes latest addons: inputstream.adaptive (b2965bd, +18), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (8374cb4, +2), pvr.argustv (3556049), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (594e062), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (345f9a7, +2), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (3ccd06f, +1), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive(e7d149e, +2)
Ok after upgrade to 17.8.199 not better…
the log : https://paste.osmc.tv/icopiyevum
You are still running an older version of libbluray. I’ve add the latest version to my repo so try
sudo apt-get update && sudo apt-get dist-upgrade
It’s Run ! Very thx
17.8-200, 26 March 2018: Based off OSMC commit (703a5f8) and newclock5 (b75819a)
OSMC:
- Update all-113 for Leia. Add support to mix LFE channels in to L/R (703a5f8e)
XBMC:
- [python] add setType() method for edit controls (PR:11486, 1 commit, 5 files changed)
- VideoPlayer: do not discard unknown streams before video stream is ready (PR:13687, 1 commit, 1 file changed)
- VideoPlayer: only display settings for vaapi and vdpau if they are ac (PR:13686, 1 commit, 7 files changed)
pvr.teleboy:
- Log notice if t.teleboy.ch is used (a7176f3)
Includes latest addons: inputstream.adaptive (c759106, +19), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (80224e1, +4), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (594e062), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (345f9a7, +2), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (a7176f3, +2), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (e7d149e, +2)
17.8-201, 28 March 2018: Based off OSMC commit (da8cb03fc) and newclock5 (b75819a)
pvr.dvblink:
- pvr.dvblink addon v4.5.0 (PR:99, 2 commits, 11 files changed)
pvr.mythtv:
inputstream.adaptive (c759106, +19), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (80224e1, +4), pvr.argustv (3556049), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (d48fc19, +2), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (ec7daca, +4), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (a7176f3, +2), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (e7d149e, +2)
17.8-202, 30 March 2018: Based off OSMC commit (3baf0fbc) and newclock5 (3aa8576)
XBMC:
- load videoInfoTag before player is started (PR:13703, 3 commits, 7 files changed)
- AudioEngine: XAudio - small fixes. (PR:13704, 2 commits, 1 file changed)
- [xbmc] URL: handle win-lib:// path as a local resource. (PR:13705, 1 commit, 1 file changed)
- AESinkALSA: only use S24NE4MSB with S32 alsa format (PR:13701, 3 commits, 1 file changed)
inputstream.adaptive (c759106, +19), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (80224e1, +4), pvr.argustv (3556049), pvr.demo (8f62053), pvr.dvblink (d48fc19, +2), pvr.dvbviewer (f1746c5, +1), [url=https://github.com/kodi-pvr/pvr.filmon]pvr.filmon/url, pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98, +5), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), pvr.stalker (77eec69), pvr.teleboy (a7176f3, +2), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive (e7d149e, +2)
17.8-203, 31 March 2018: Based off OSMC commit (f8d5adf0) and newclock5 (6f261235)
XBMC:
- VideoPlayer: vtb - fix potential segfault on reopen (PR:13712, 1 commit, 1 file changed)
- Expose OnAVChange and OnAVStarted to python api (PR:13696, 1 commit, 5 files changed)
- Process physical interface only. (PR:7320, 0 commits, 0 files changed)
pvr.dvblink:
- pvr.dvblink v4.5.1 (PR:100, 1 commit, 4 files changed)
Includes latest addons: inputstream.adaptive (c759106, +19), inputstream.rtmp (7fe7dde, +2), peripheral.joystick (80224e1, +4), pvr.argustv (3556049), [url=https://github.com/kodi-pvr/pvr.demo]pvr.demo/url, pvr.dvblink (51dbe21, +3), pvr.dvbviewer (f1746c5, +1), pvr.filmon (c7243fb), pvr.hdhomerun (f3e0177), pvr.hts (095784b), pvr.iptvsimple (933a5c4), pvr.mediaportal.tvserver (74e2bea), pvr.mythtv (9931f98, +5), pvr.nextpvr (aa1c8d2), pvr.njoy (67b837d), pvr.octonet (689afbf), pvr.pctv (5b47d9f), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (a7176f3, +2), pvr.vbox (57f3198), pvr.vdr.vnsi (4db947c), pvr.vuplus (dc230dd), pvr.wmc (e0a9190), pvr.zattoo (3c46173), vfs.libarchive(e7d149e, +2)
i have the same issue
wifi works and usb ethernet adapter works
You must provide diagnostic logs if you wish to receive any meaningful assistance to find resolution to your issue!
here you get it
https://paste.osmc.tv/udanohojow
Those are apt logs. Useless in troubleshooting your problem.
