[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
Is there a problem with the My Osmc - App Store? I can’t navigate in this sub-menu. I tried with my remote (hdmi-cec) and also plugged in a usb-kexboard. I can navigate without problems in the rest of Kodi and also in the rest of MyOSMC (Network, pi config, etc.), except App Store and Services.
With the “back”-button on my remote or backspace on the usb-keyboard I can return to the MyOsmc overview.
I don’t know if this helps but I activated debug logging and go to the App Store and tried navigating: https://paste.osmc.tv/menoticofu
@vanMacG the problem with Services, App store and Remotes in MyOSMC on Leia are known and are being worked on. If you have a mouse connected you can move the cursor over one selection and after that the arrow keys navigation will work.
Ok, I searched this thread and didn’t find something… sry.
The trick with the mouse worked. Thanks!
Something related to Win 7 then if there are multiple devices missing.
Check what recent patches have been installed.
17.8-330, 20 Sept 2018: Based off OSMC commit (5c7028cb4) and newclock5 (da7f31994)
inputstream.adaptive:
  • [DASH] initialize encryptionscheme for tree updates / without representations will be skipped and therefore not updated (8d49b9d)
Includes latest addons:
Includes latest addons: inputstream.adaptive (8d49b9d, +2), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer(dd9c518, +13), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (8b66ec3), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (b17d5ad), pvr.mythtv (22aa23b), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (07ec214, +9), pvr.wmc (0aea001, +4), pvr.zattoo (8de69a1), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9), pvr.sledovanitv.cz
All working.
But noticed an higher cpu usage from kodi 18 when in main menu (around 30%).
When in sub-menus dropping to around 10%.
This is similar to the issues reported in kodi 17 some months ago (meanwhile corrected).
17.8-331, 22 Sept 2018: Based off OSMC commit (bf7d7715c7) and newclock5 (6688a64)
OSMC:
  • Update to libbluray 1.2.0
XBMC:
  • [bluray] Revert handling still event with pause. (PR:14459, 2 commits, 2 files changed)
  • [darwin] allow macOS SDK 10.14 & iOS SDK 12 (Xcode10) (PR:14457, 2 commits, 3 files changed)
pvr.hts:
  • PVR Addon API 5.10.2: Implemented support for PVR_ADDON_CAPABILITIES. (PR:376, 1 commit, 4 files changed)
newclock5:
New commits in this build:
  • Revert “Merge pull request #14459 from ace20022/bd_revert_menu_still” (33794003)
  • ffmpeg: hevc: Revisit inter pred qasm and revert intra_filter scheduling (6688a649)
17.8-332, 24 Sept 2018: Based off OSMC commit (bad77199) and newclock5 (6688a64)
OSMC Skin Alpha 17.9.3-11
  • DSD label hotfix (43ef362)
  • Add DSD music labels (37a5e50)
XBMC:
  • RendererDRMPRIME: set color drm properties (PR:14452, 6 commits, 10 files changed)
pvr.vuplus:
  • Fixes (PR:94, 3 commits, 6 files changed)
17.8-333, 26 Sept 2018: Based off OSMC commit (fe8098635) and newclock5 (c546253)
XBMC:
  • Revert “VideoPlayer: WinRenderer - add smooth motion” (PR:14472, 1 commit, 2 files changed)
  • DVDDemuxFFmpeg: correctly set probeBuffer size matching avioread chunk (PR:14465, 1 commit, 1 file changed)
  • [videoplayer] Fix usage of external vob subtitles. (PR:14471, 1 commit, 2 files changed)
  • [JSON]Fix Player.GetItem during track change seg fault (PR:14454, 1 commit, 2 files changed)
  • [docs/python] Fix docs for xbmcgui Python module (PR:14476, 1 commit, 1 file changed)
  • RPI: Be sure to register Alsa and Pulseaudio. (PR:14453, 1 commit, 2 files changed)
pvr.vuplus:
  • Turned icon fix into an option (PR:95, 1 commit, 7 files changed)
newclock5
  • Tell ffmpeg to compile with raspberry pi support thus making the patches available (c546253d)
Hi! What performance did you get with the emulators? I also have a RPi2 and the performance is abyssmal at best…
Snes9x doesnt work and all gba emulators are either really slow or working on very awkward speeds.
One core is running at 100%, the others aren’t doing anything :frowning:
@ChessSpider about the same on my pi2, on vero4k it’s better tho. No 100% core use on vero4k, but i dont think it’s spread evenly among cores and fluid in GBA and SNES. But that is with Vero4k, the pi2 is playable but you notice it’s emulation. Right now i got issues with getting the bluetooth controller to be accepted in emulator, works in kodi, on the pi2.
17.8-334, 28 Sept 2018: Based off OSMC commit (f62e80801) and newclock5 (c546253)
XBMC:
  • [docs] Fixed a typo. (PR:14477, 1 commit, 1 file changed)
  • [linux] allow overriding the userdata dir (PR:14460, 2 commits, 2 files changed)
  • Armv7 build neon (PR:14250, 1 commit, 4 files changed)
  • Update game.controller.default to v1.0.7 (PR:14482, 1 commit, 1 file changed)
newclock5:
Commits no longer in build:
  • Revert “Merge pull request #14459 from ace20022/bd_revert_menu_still” (4f5dec10)
  • Revert “Merge pull request #14429 from ace20022/bd_mouse_select” (a106bbcb)
  • ffmpeg: hevc: Revisit inter pred qasm and revert intra_filter scheduling (3000cb97)
It seems the latest build did not get pushed, thus not avaible via apt-get.
Should be up within the hour.
I got sidetracked and forgot to enter the aptly password when publishing :frowning:
Is it already known that channel up/down keys in live tv no more work, since several builds?
17.8-335, 30 Sept 2018: Based off OSMC commit (8760fdfc54) and newclock5 (d46ff3d4)
OSMC Skin v18 Alpha 17.9.3-12
  • Hotfix Opacity Dim Factor variable (0e699b20)
  • PVR group manager hide option hotfix (0f2e2062)
XBMC:
  • [python] bump for leia (PR:14493, 1 commit, 2 files changed)
  • [docs] Add initializer list whitespace convention in Code Guidelines (PR:14492, 1 commit, 2 files changed)
newclock5:
  • Tell ffmpeg to compile with raspberry pi support thus making the patches available (d46ff3d4)
  • Revert “[bluray] Directly store the current BLURAY_CLIP_INFO pointer instead of it’s id.” (9adfc949)
So, is the My OSMC --> Pi Config menuitem broken for anyone else using the latest kodi?
One of the latest nightlies broke my hifiberrysetup, so i wanted to check the settings there and noticed that it too was broken.
There are problems with MyOSMC on Leia.
17.8-336, 2 Oct 2018: Based off OSMC commit (b67f73015a) and newclock5 (f878f84d)
XBMC:
  • gbm/windowing: fix compile when using older EGL headers + assert mess (PR:14294, 1 commit, 1 file changed)
  • Update default and SNES controller images (PR:14495, 1 commit, 6 files changed)
Inacludes latest addons:
Controllers were not working for a while, but last version fixed it, though you had to install every available controller for that emulator. But this version I lost controller funtionallity again in all emulatiors i tried, there is a new option in “Esc”-menu:
Missing: {0:s}
When i click it, it goes to controller setup, tried to set it up but no change.
