[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
@erchisus the problem with appstore is known, you can connect a mouse and navigate the pointer over an option in appstore then you can use the arrows to navigate between apps.
17.8-350, 15 Nov 2018: Based off OSMC commit (11ee72f55) and newclock5 (86854b6)
XBMC:
  • [DetectDVDType]: fix Crash due to non-checked error state (PR:14842, 1 commit, 1 file changed)
  • VideoInfoTag: fix missing field overview for sets (PR:14868, 1 commit, 1 file changed)
    [*][docs] Adding FrameAdvance documentation (PR:14874, 1 commit, 1 file changed)
pvr.mythtv:
  • update tag for radio channel to ‘’ (a43060c)
Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy(4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
17.8-351, 16 Nov 2018: Based off OSMC commit (11ee72f55) and newclock5 (86854b6)
OSMC
  • Build with latest vfs.sftp commit
XBMC:
  • Extend IsRemote check to some vfs paths (closes #14817) (PR:14860, 1 commit, 2 files changed)
  • [docs] Trivial fixes to xbmc.Monitor docs (PR:14879, 1 commit, 1 file changed)
inputstream.adaptive:
  • [WVD] service certificate detection / share identical psshsets (1a374be)
  • Version bump 2.3.9 (62980b9)
pvr.dvbviewer:
  • fix ubuntu packaging (PR:76, 1 commit, 3 files changed)
pvr.wmc:
  • fix ubuntu packaging (PR:64, 1 commit, 3 files changed)
17.8-352, 17 Nov 2018: Based off OSMC commit (d08a6ce64) and newclock5 (86854b6)
OSMC
[list]
[*]Revert PR 14755 (d9b5863)
[/list]
OSMC Leia Skin
[list]
[]Improve media tags + bug fix
]Add “Please wait…” heading during busy dialog
[*]Add 8K resolution label
[/list]
[list]
[*]Include codecId in decoder display name (3e6b8e6)
[/list]
pvr.mythtv:
[list]
[*]add eit categories supplied by telerama (e88cd2f)
[/list]
uhmm trying to update to the latest:
Calculating upgrade... Done
  mediacenter-skin-osmc
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 11.2 MB of archives.
After this operation, 11.3 kB of additional disk space will be used.
Get:1 http://ftp.fau.de/osmc/osmc/download/dev/gmc-18 gmc-18/main armhf mediacenter-skin-osmc all 17.9.3-15 [11.2 MB]
Err:1 http://ftp.fau.de/osmc/osmc/download/dev/gmc-18 gmc-18/main armhf mediacenter-skin-osmc all 17.9.3-15
  Hash Sum mismatch
  Hashes of expected file:
   - SHA512:1937623d09d515da812e6dc8453f03231ad45b6ee32e63d61c5c496a6a68f031ce9b1693b9b0a568a578388e0bae2a01a8f089c234d8c1e23a6d5dc4dbb068ec
   - SHA256:d8be043076c71d58c4b5cba4f14f678a281fd1a610ea5bc0a81370666e33d7d8
   - SHA1:755f442745992933a3b3558614a9ea95acf38797 [weak]
   - MD5Sum:7011ffa654fed241c12cb3bdb5c31fac [weak]
   - Filesize:11157962 [weak]
  Hashes of received file:
   - SHA512:5b022658c80d130302fbffaaf1321178a07c67ebd33904bef709d13af6a26c8eb86d1cc5c83a0bac131bcb75f065f49e3e63490f9f350d152823713c5d6c6a22
   - SHA256:ae27e5f3deba39c71bd3cb088aae9cf9c9c503fd3ee3d01093c87d3bb0e2ea30
   - SHA1:a85f7e9c7ca385d6ac7c5091b7d87755571d67c6 [weak]
   - MD5Sum:e9e72abe737a7b35f90b3cbac5fe2812 [weak]
   - Filesize:11154544 [weak]
  Last modification reported: Tue, 13 Nov 2018 14:40:22 +0000
Fetched 11.2 MB in 9s (1156 kB/s)
E: Failed to fetch http://ftp.fau.de/osmc/osmc/download/dev/gmc-18/pool/main/m/mediacenter-skin-osmc/mediacenter-skin-osmc-17.9.3-14.deb  Hash Sum mismatch
root@pi3:~#
I found a issue with the build and have pushed a new version of the skin (17.9.3-16)
Give it a hour or so to sync to the mirrors
17.8-353, 18 Nov 2018: Based off OSMC commit (4536612) and newclock5 (86854b6)
XBMC:
  • fixed: Low read rate detection logic when VideoPlayer uses filecache (PR:14869, 1 commit, 4 files changed)
  • [storage] MediaManager::Onstorage*: Do not show toasts if fullscreen (PR:14881, 1 commit, 1 file changed)
  • [fix] redact paths in edl logging (PR:14844, 1 commit, 1 file changed)
  • [JSON] Bump version to 10.0.0 (PR:14790, 1 commit, 1 file changed)
  • [addons] Sort logged list of installed add-ons (PR:14888, 1 commit, 1 file changed)
  • Version bump 2.3.10 (df0dbd3)
pvr.mythtv:
  • sync upstream cppmyth (2.11.0) (80396dd)
  • disable file caching by default (1a0a9cb)
  • add advanced settings to re-enable builtin files cache (19dc3d0)
  • review visibility fo recording flags (6aa74d1)
  • bump version 5.9.0 (d53d4b8)
17.8-354, 21 Nov 2018: Based off OSMC commit (2626a7aa2) and newclock5 (86854b6)
XBMC:
  • [games] Show installed game clients first (PR:14902, 1 commit, 1 file changed)
  • [addons] remove never set value on CAddonInfo (PR:14895, 1 commit, 1 file changed)
  • [Estuary] Movie listing and overview fixes for sets (PR:14909, 1 commit, 2 files changed)
  • [music]Fix album source constraint violations during library update (PR:14906, 1 commit, 2 files changed)
  • VAAPI: add error and info callbacks (PR:14831, 1 commit, 2 files changed)
  • Implement NXFrameRate UUID atom (7a66f1e)
peripheral.joystick:
  • [ci][travis] use xcode9 (5429dc4)
pvr.mythtv:
  • fix display for video flags (672dee6)
  • sync upstream cppmyth (2.11.2) (67854e9)
  • announce as frontend (e2aad6c)
  • this is a hack to work around the PVR startup flow issue (a1e5399)
  • bump version 5.9.1 (aa5241b)
17.8-355, 24 Nov 2018: Based off OSMC commit (07fcf80609) and newclock5 (2ef402b6)
OSMC Leia Skin:
  • Bump required skin API version
  • Consmetic improvements
  • Bug Fix
XBMC:
  • bump to v18.0 RC1
  • [Docs] Improve the documentation for boolean conditions and infolabels. (PR:14910, 1 commit, 5 files changed)
  • VideoPlayer: fix state of a/v players after switching refresh rate (PR:14921, 1 commit, 1 file changed)
  • [Estuary] Adjust eventlog entry height so that it can display two full lines of text. (PR:14923, 1 commit, 1 file changed)
  • [lang][kodi.core] automatic syntax corrections for the en_GB language file (98ad65e)
  • [lang][skin.estuary] updated language files from Transifex (3f5a4c6)
  • [lang][skin.estouchy] updated language files from Transifex (8dfbf79)
pvr.argustv:
  • [lang] updated language files from Transifex (83aa1e9)
pvr.dvblink:
  • [lang] updated language files from Transifex (c2c799d)
pvr.dvbviewer:
  • [lang] updated language files from Transifex (cda813e)
pvr.teleboy:
  • Fix check for plus and comfort member (50689bd)
pvr.vuplus:
  • Unique channels and radio groups (PR:132, 12 commits, 37 files changed)
pvr.zattoo:
  • Fix uuid handling (4688f45)
pvr.filmon:
  • [lang] updated language files from Transifex (e850633)
pvr.hts:
  • [lang] updated language files from Transifex (6a12442)
pvr.mediaportal.tvserver:
  • [lang] updated language files from Transifex (b17fdad)
pvr.nextpvr:
  • [lang] updated language files from Transifex (ccdfd63)
pvr.pctv:
  • [lang] updated language files from Transifex (b60b971)
pvr.vuplus:
  • No startup fix (PR:135, 0 commits, 0 files changed)
  • [lang] updated language files from Transifex (f7f92af)
pvr.wmc:
  • [lang] updated language files from Transifex (81e2090)
newclock5:
Commits no longer in build:
  • FIX: Only handle 3D bitmap subs in TAB (3cdfa302)
  • Revert “FIX: Only handle 3D bitmap subs in TAB” (86854b6d)
17.8-356, 25 Nov 2018: Based off OSMC commit (607ff204) and newclock5 (2ef402b)
XBMC:
*][fix] check add-on version for nullptr before constructing a std:tring (PR:14930, 1 commit, 1 file changed)
*][skin.estuary] Add Hebrew and Armenian typefaces to the fonts (PR:14904, 1 commit, 5 files changed)
*][PVR] Fix CPVRGUITimerInfo::TimerInfoToggle(). (PR:14927, 1 commit, 1 file changed)
pvr.mythtv:
*]remove useless feature fileops (57f79b8)
*]bump version 5.10.0 (dfdff58)
*]fix memory leak in destructor (0068fcf)
17.8-357, 26 Nov 2018: Based off OSMC commit (30dc8295) and newclock5 (2ef402b)
XBMC:
  • added: play next context menu and action (PR:14912, 1 commit, 10 files changed)
  • [guiinfo] Fix support for ListItem.NextDuration (PR:14929, 2 commits, 1 file changed)
pvr.mythtv:
  • don’t try any more to purge old cache: api fails (eec5154)
  • bump version 5.10.1 (f4a0f59)
17.8-358, 27 Nov 2018: Based off OSMC commit (2ac38a889) and newclock5 (2ef402b)
XBMC:
  • [estuary] add default addon image fallback in addon browser (PR:14935, 1 commit, 2 files changed)
  • VideoLayerBridgeDRMPRIME: unmap previous buffer when current buffer is reused (PR:14940, 1 commit, 1 file changed)
  • [skin.estuary] fix visualization visibility (PR:14941, 1 commit, 1 file changed)
  • [cleanup] remove code for VS lower than 14.0 (2015) (PR:14948, 1 commit, 2 files changed)
  • [fix] remove network available checks in C(Directory|File)Factory (PR:14918, 1 commit, 2 files changed)
  • Sort forced subs before main subs (e86e995)
pvr.mythtv:
  • sync upstream cppmythlib (2.12.0) (0a3a50b)
  • add option to set default recording group as root for recordings (44e8ac8)
Starting from problems of release 345 I was not able to automatically update the OSMC. Whenever I choose to update from GUI dialog or try to initiate with manual controls I always get
Error installing (unknown package).
I can overcome this by following sequence of commands but maybe there’s a way to fix this?
    osmc@osmc:~$ dpkg -l | grep mediacenter-osmc | awk '{ print $3 }'
17.8-354
osmc@osmc:~$ apt-cache madison rbp2-mediacenter-osmc
rbp2-mediacenter-osmc |   17.8-356 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-355 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-354 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-353 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-352 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-351 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-350 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-349 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-348 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-347 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-346 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-345 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-344 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-343 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-342 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-341 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-340 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-339 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-338 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-337 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-336 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-335 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-334 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-333 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-332 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-331 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-330 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-329 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-328 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-327 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-326 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-325 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-324 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-322 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-321 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-320 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-319 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-318 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-315 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |   17.8-314 | http://download.osmc.tv/dev/gmc-18 gmc-18/main armhf Packages
rbp2-mediacenter-osmc |  17.6.0-49 | http://apt.osmc.tv stretch/main armhf Packages
osmc@osmc:~$ sudo apt-get update
Get:1 http://security.debian.org stretch/updates InRelease [94.3 kB]
Ign:2 http://ftp.debian.org/debian stretch InRelease
Get:4 http://ftp.debian.org/debian stretch-updates InRelease [91.0 kB]
Hit:6 http://ftp.debian.org/debian stretch Release
Get:3 http://ftp.fau.de/osmc/osmc/download/dev/gmc-18 gmc-18 InRelease [6010 B]
Hit:5 http://ftp.fau.de/osmc/osmc/apt stretch InRelease
Get:7 http://security.debian.org stretch/updates/main armhf Packages [445 kB]
Get:9 http://ftp.fau.de/osmc/osmc/download/dev/gmc-18 gmc-18/main armhf Packages [75.8 kB]
Fetched 712 kB in 4s (166 kB/s)
Reading package lists... Done
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
osmc@osmc:~$ sudo dpkg --configure -a
Setting up mediacenter-skin-osmc (17.9.3-18) ...
Building dependency tree
  libsmbclient libwbclient0 rbp2-mediacenter-osmc samba-common samba-libs
5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 77.6 MB of archives.
After this operation, 24.6 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://security.debian.org stretch/updates/main armhf libwbclient0 armhf 2:4.5.12+dfsg-2+deb9u4 [121 kB]
Get:2 http://ftp.fau.de/osmc/osmc/download/dev/gmc-18 gmc-18/main armhf rbp2-mediacenter-osmc armhf 17.8-357 [72.7 MB]
Get:3 http://security.debian.org stretch/updates/main armhf libsmbclient armhf 2:4.5.12+dfsg-2+deb9u4 [145 kB]
Get:4 http://security.debian.org stretch/updates/main armhf samba-libs armhf 2:4.5.12+dfsg-2+deb9u4 [4504 kB]
Get:5 http://security.debian.org stretch/updates/main armhf samba-common all 2:4.5.12+dfsg-2+deb9u4 [172 kB]
Fetched 77.6 MB in 17s (4398 kB/s)
Preconfiguring packages ...
(Reading database ... 30621 files and directories currently installed.)
Preparing to unpack .../libwbclient0_2%3a4.5.12+dfsg-2+deb9u4_armhf.deb ...
Unpacking libwbclient0:armhf (2:4.5.12+dfsg-2+deb9u4) over (2:4.5.12+dfsg-2+deb9u3) ...
Preparing to unpack .../libsmbclient_2%3a4.5.12+dfsg-2+deb9u4_armhf.deb ...
Unpacking libsmbclient:armhf (2:4.5.12+dfsg-2+deb9u4) over (2:4.5.12+dfsg-2+deb9u3) ...
Preparing to unpack .../samba-libs_2%3a4.5.12+dfsg-2+deb9u4_armhf.deb ...
Unpacking samba-libs:armhf (2:4.5.12+dfsg-2+deb9u4) over (2:4.5.12+dfsg-2+deb9u3) ...
Preparing to unpack .../rbp2-mediacenter-osmc_17.8-357_armhf.deb ...
Unpacking rbp2-mediacenter-osmc (17.8-357) over (17.8-354) ...
Preparing to unpack .../samba-common_2%3a4.5.12+dfsg-2+deb9u4_all.deb ...
Unpacking samba-common (2:4.5.12+dfsg-2+deb9u4) over (2:4.5.12+dfsg-2+deb9u3) ...
Setting up libwbclient0:armhf (2:4.5.12+dfsg-2+deb9u4) ...
Setting up samba-libs:armhf (2:4.5.12+dfsg-2+deb9u4) ...
Processing triggers for mime-support (3.60) ...
Setting up samba-common (2:4.5.12+dfsg-2+deb9u4) ...
Setting up libsmbclient:armhf (2:4.5.12+dfsg-2+deb9u4) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Setting up rbp2-mediacenter-osmc (17.8-357) ...
osmc@osmc:~$
Logs attached https://paste.osmc.tv/zuputasuyi
Just updated my Pi3B from v17 to Leia: I’m missing the “Skin Helper Service Widgets” addon?
Here is the a repository for among others skin helper service, widgets from the devolper:
https://marcelveldt.github.io/repository.marcelveldt/repository.marcelveldt/repository.marcelveldt-1.0.1.zip
17.8-359, 28 Nov 2018: Based off OSMC commit (7a6e79fca) and newclock5 (2ef402b)
OSMC Leia Skin
  • Better highlighting of cover art + improvements/fixes
pvr.mythtv:
17.8-360, 29 Nov 2018: Based off OSMC commit (7a6e79fca) and newclock5 (2ef402b6)
XBMC:
  • Games: Assign joysticks in order of MRU (last activation) (PR:14944, 1 commit, 8 files changed)
  • [addons] fix addon install process percent indication (PR:14884, 2 commits, 4 files changed)
  • [pvr] CPVRRecording::GetResumePoint(): Performance: Update resume poi (PR:14961, 1 commit, 2 files changed)
  • [cleanup] remove code for glibc 2.0 and lower (PR:14951, 1 commit, 1 file changed)
  • [DASH] Tag main subs as default (6fb462e)
  • Version bump 2.3.12 (efd4b4f)
Includes latest addons: inputstream.adaptive (efd4b4f, +3), inputstream.rtmp (ce7f559), peripheral.joystick (5429dc4), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe, +1), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(6a12442), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (b17fdad), pvr.mythtv (d3a5af2, +3), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d, +1), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc(81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
17.8-361, 1 Dec 2018: Based off OSMC commit (e33a4e70) and newclock5 (5880ccf21)
OSMC
OSMC Skin 18
  • Add no dimming of cover art option
  • Bug fix
  • Update selected color + change wide widgets size
  • Version 17.9.3-20
17.8-362, 3 Dec 2018: Based off OSMC commit (97e675b953) and newclock5 (5880ccf21)
pvr.vuplus
  • PR #137. Load config if enabled
Hi gmc, any issues with the gpg.key?
This is what i get if i try to update today to the latest build:
Failed to fetch http://download.osmc.tv/dev/gmc-18/dists/gmc-18/InRelease The following signatures were invalid: EXPKEYSIG 326674E68C015D46 Greg McCarthy greg@gjmccarthy.co.uk
Thanks in advance.
