Getting the same
I’ll look into it.
Same to me, even new wget of certificate did not help.
I think I’ve fixed this one now. The gpg key had expired so had to renew. Also means the public key has now changed. Can you please try this:
wget -qO - http://download.osmc.tv/dev/gmc-18/pubkey.asc | sudo apt-key add -
sudo apt-get update
Once confirmed working I’ll update the first post.
Works as expected, thank you.
Yes, it works. Thanks!
hey @gmc its been awhile
installed latest rev found an issue when adding more sources the menu when u add a manual source doesnt display mind checking on your installation if the same occur ?
ps are you compiling any of the retroplayer stuff ?
My IR “Hama MCE Remote Control” is not working correctly anymore, OK/ENTER button has no function.
I’m forced to use a USB keyboard but even with that the MyOSMC Remote menu can only be entered but there is no navigation possible.
Last changes which seems to be responsible for this behaviour are
Start-Date: 2018-12-04 15:29:54
Commandline: /usr/bin/apt-get-real dist-upgrade
Upgrade: rbp2-mediacenter-osmc:armhf (17.8-360, 17.8-362), armv7-eventlircd-osmc:armhf (1.3.0, 1.3.1), mediacenter-skin-osmc:armhf (17.9.3-19, 17.9.3-20)
End-Date: 2018-12-04 15:32:01
Start-Date: 2018-12-04 20:27:46
Upgrade: mediacenter-addon-osmc:armhf (3.0.665, 3.0.666)
End-Date: 2018-12-04 20:27:58
Tried to enter every item (from Movies down to Power) in the main menu using the IR remote
https://paste.osmc.tv/lesuqosama
Can’t seem to replicate that. Anything in the logs?
I compile in all the libretro stuff. Have a look here for what’s included:
https://github.com/StormTrooper/osmc/blob/gmc-18/package/mediacenter-next-osmc/build.sh#L343
Was it work on the build before that? On the current build only changes to pvr.vuplus were made.
Maybe its a issue with armv7-eventlircd-osmc.
I think I worked with the Pi3 this morning but I’m not sure, in the log (see in my previous post) you see
20:53:41.204 T:1907356400 DEBUG: LIRC: - NEW 6c 0 KEY_DOWN linux-input-layer (KEY_DOWN)
20:53:41.221 T:1917456384 DEBUG: HandleKey: 167 (0xa7, obc88) pressed, action is Down
20:53:41.412 T:1907356400 DEBUG: LIRC: - NEW 6c 0 KEY_DOWN_UP linux-input-layer (KEY_DOWN_UP)
20:53:41.422 T:1917456384 DEBUG: HandleKey: 0 (0x00, obc255) pressed, action is
20:53:41.988 T:1907356400 DEBUG: LIRC: - NEW 1c 0 KEY_ENTER linux-input-layer (KEY_ENTER)
20:53:42.002 T:1917456384 DEBUG: HandleKey: 22 (0x16, obc233) pressed, action is FullScreen
20:53:42.020 T:1907356400 DEBUG: LIRC: - NEW 1c 0 KEY_ENTER_UP linux-input-layer (KEY_ENTER_UP)
20:53:42.021 T:1917456384 DEBUG: HandleKey: 0 (0x00, obc255) pressed, action is
that is not a region I often touch but it looks like there is no action mapped
Sure this wasn’t caused by eventlircd which I pushed to staging?
will install debug tomorrow and get logs see if i can reproduce it tomorrow.
thnx for the retroplayer stuff
one request steam controller the package for that
Will see if its compiling again. Looked at steam controller a few weeks ago and build failed.
17.8-363, 4 Dec 2018: Based off OSMC commit (93752e54) and newclock5 (5880ccf21)
OSMC Leia Skin 17.9.3-21
vfs.rar
- Re-point repo to master
- added: flag that add-on uses url encoded host name
Includes latest addons: inputstream.adaptive (efd4b4f, +3), inputstream.rtmp (ce7f559), peripheral.joystick (5429dc4), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe, +1), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(6a12442), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (b17fdad), pvr.mythtv (d3a5af2, +3), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d, +1), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc(81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
@gmc jfyi: downgraded apt-get install --reinstall=armv7-eventlircd-osmc=1.3.0 … and the Hama remote works again
@gmc is off the hook.
17.8-364, 5 Dec 2018: Based off OSMC commit (93752e54) and newclock5 (5880ccf21)
xbmc
- bump to v18.0 rc3 (PR:14978, 1 commit, 1 file changed)
17.8-365, 6 Dec 2018: Based off OSMC commit (93752e54) and newclock5 (5880ccf21)
xbmc
- fixed: division by zero in addon installation (PR:14997, 1 commit, 1 file changed)
17.8-366, 8 Dec 2018: Based off OSMC commit (79dde32f1) and newclock5 (5880ccf21)
xbmc
- Default DVDInputStream::OpenStream to true (PR:15010, 1 commit, 1 file changed)
17.8-367, 10 Dec 2018: Based off OSMC commit (afc21371bc) and newclock5 (5880ccf21)
xbmc
- PR:15020 (perma): [DemuxClient] Call SetStreamProps only if OpenStream succeeds
