[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
368 failing to install due to mismatch hash. Busy redoing the build
17.8-369, 10 Dec 2018: Based off OSMC commit (b1a1e92f1f) and newclock5 (5880ccf21)
OSMC Skin Leia
  • Change watched status and collection icon backgrounds + behaviour (409671)
xbmc
  • [DemuxClient] Call SetStreamProps only if OpenStream succeeds (PR:15020, 1 commit, 2 files changed)
  • [systeminfo] use timestamp for application build date from BUILDATE (PR:15004, 1 commit, 6 files changed)
  • cmake: add freetype2 PATH_SUFFIX to FindFreeType.cmake (PR:15007, 1 commit, 1 file changed)
  • [docs] fixes for xbmcvfs.Stat (PR:15021, 1 commit, 2 files changed)
Includes latest addons: inputstream.adaptive (efd4b4f, +3), inputstream.rtmp (ce7f559), peripheral.joystick (5429dc4), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe, +1), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(6a12442), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (b17fdad), pvr.mythtv (d3a5af2, +3), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d, +1), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc(81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
17.8-370, 12 Dec 2018: Based off OSMC commit (e03ec256d) and newclock5 (27fc1109a)
XBMC:
  • [ResetRenderSystem] exit early if RenderSystem hasn’t been initialized (PR:15019, 1 commit, 1 file changed)
newclock5:
New commits in this build:
  • MMALRenderer: Destroy pool before component (670519c3)
  • VideoPlayerVideo: Hack to allow dvd menus to work when no decoded picture (edbecaca)
  • ffmpeg: hevc: Fix for green artefacts (27fc1109)
just a quick heads-up to see if I am alone with that problem - for me, 17.8-365 was the last version where I was able to watch live TV via tvheadend (using pvr.hts).
Now - no picture/audio will appear, but instead the lyrics plugin will pop up informing me that it didn’t find a matching lyric (no wonder for the daily news show…). I downgraded and everything was back to normal.
had a simular problem seems that this revision kinda messed with the addon database for some reason had to reenable all my addons after installing this revision.
Hi, also just want to confirm that the upgrade to 17.8-370 broke the Live Tv completely, no a/v at all.
But downgrading to 17.8-369 brought it back for me.
17.8-371, 14 Dec 2018: Based off OSMC commit (f91ac6b4d6) and newclock5 (4918913)
XBMC:
  • [settings] Fix regression (setting reuse) (PR:15015, 1 commit, 2 files changed)
  • [cmake] Fix ninja (fixes: #15008) (PR:15011, 1 commit, 3 files changed)
  • [cmake] make sure APP_BUILD_DATE is always set (PR:15028, 1 commit, 1 file changed)
newclock5:
  • MMALCodec: Keep videBuffer valid until next decode picture (4918913a)
Commits no longer in build:
I can confirm, -370 & -371 have broken live TV, -369 is working. Using pvr.hts.
17.8-372, 15 Dec 2018: Based off OSMC commit (8f3f3286a) and newclock5 (fef525b7)
XBMC:
  • [omxplayer] Make functions const correct (PR:15017, 1 commit, 6 files changed)
  • [settings] Hide episode thumb if unseen (core wise) (PR:14971, 1 commit, 8 files changed)
17.8-373, 15 Dec 2018: Based off OSMC commit (8f3f3286a) and newclock5 (fef525b7)
XBMC:
17.8-374, 16 Dec 2018: Based off OSMC commit (f7dc71a58a) and newclock5 (fef525b7)
pvr.mediaportal.tvserver:
  • Update the plugin to v3.5.14 (Fixes for v18) (PR:99, 12 commits, 20 files changed)
Leia OSMC Skin 17.9.3-24
  • Complete color rework & highlighting fixes PR #55
Updated to 371 but seems to be running very slowly. As I was trying to get a movie on for the kids I thought I would roll back a couple of versions but can’t seem to.
mc@osmckitchen:~$ sudo apt-get install rpb2-mediacenter-osmc=17.8-370
Reading package lists… Done
Building dependency tree
E: Unable to locate package rpb2-mediacenter-osmc
osmc@osmckitchen:~$
Not sure what im doing wrong?
On rpi3
Edit:
Cut and paste the command and it worked! I was typing it in my phone over ssh. Can’t see my mistake but it’s working
Leia OSMC Skin 17.9.3-25
Up to -374 live TV still not working (all guide info seems to be ok, just no a/v)
Is this a known issue? Maybe someone can guide me where to report or follow the bug.
Thx, jtl
livetv works just fine here, has been in each rev so far running on 374
logs always help when trying to find an issue search the forums for how to provide logs loads of references around on that
about 20+ tv addons for kodi so logs in all honesty is better in any situation
Logs: https://paste.osmc.tv/sotajevovu
:slight_smile:
Dont see anything odd on the logs. Also don’t see any issues raised on pvr.hts tracker so could be something specific to OSMC.
I’ll see if I can create a test version and roll back some of the patches from 370, though I don’t think any related to pvr.hts
Thanks. Just to be clear, it’s working on Vero, but with an annoying 25Hz/50Hz rate change. I just came here to see if it was the same on Pi.
HEVC files that played fine under the stable version of OSMC are now causing trouble for me under 17.8-374, see screenshot. Loads of green/pink blocks, apart from that the playback appears to be normal. I’m using an RP3. Any suggestions?
kodi.log: https://pastebin.com/B2qBFkZV
