[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
17.8-378, 21 Dec 2018: Based off OSMC commit (c26b84e10) and newclock5 (922b68c)
OSMC Skin Leia 17.9.3-28
  • Remove hide preview art of TV show episodes option
OSMC
  • Fixup PR15010/15020 patch
Includes latest addons: inputstream.adaptive (efd4b4f,
+3), inputstream.rtmp (ce7f559), peripheral.joystick (5429dc4), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe, +1), pvr.dvbviewer (cda813e), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(6a12442), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (b17fdad), pvr.mythtv (d3a5af2, +3), pvr.nextpvr (ccdfd63), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (2245b0d, +1), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (1207082), pvr.wmc(81e2090), pvr.zattoo (4688f45), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
I can replicate the issue on Leia on the rbp. Works fine on Krypton. Will recheck my patches to see if they are in sync.
Just tried to upgrade but version -377 not showing up.
There is no 377, see first post. Mirrors have sync’d now so 378 is available.
It took about 1h until it was synced. I will keep that in mind for next time.
I can confirm that the issue with Live TV got fixed.
Thx
Lovely, thanks for confirming.
Mirrors take up to an hour to sync. I think they sync on the hour.
Most take an hour; some take a bit longer and have an offset to avoid all of the mirrors syncing from our box at once.
17.8-379, 21 Dec 2018: Based off OSMC commit (dd6bdb79b) and newclock5 (922b68c)
pvr.dvbviewer:
  • [lang] updated language files from Transifex (0aa6070)
pvr.hts:
  • [lang] updated language files from Transifex (d35dfcd)
pvr.nextpvr:
  • [lang] updated language files from Transifex (450caeb)
pvr.vuplus:
  • [lang] updated language files from Transifex (c3d984b)
pvr.wmc:
  • [lang] updated language files from Transifex (2697409)
inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv(83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070, +1), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (d35dfcd, +2), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (d3a5af2), pvr.nextpvr (450caeb, +1), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv(b60b971), pvr.stalker (2245b0d), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (c3d984b, +1), pvr.wmc (2697409, +1), pvr.zattoo(4688f45), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
quick (noobish) question:
how do you return from these test builds to the official builds? (preferably without wiping everything)
could somebody run me through the necessary commands? pretty please?
Short and simple answer, Reinstall
17.8-380, 23 Dec 2018: Based off OSMC commit (ab0dd932b7) and newclock5 (922b68c)
OSMC Skin Leia 17.9.3-29
  • Fix syntax errors
pvr.nextpvr:
  • Bug fixes in seeking and fix for uninitialized usec in struct timeval (PR:76, 2 commits, 8 files changed)
pvr.vuplus:
  • Get stream times recordings (PR:149, 4 commits, 20 files changed)
  • In 3.15.2 WebIf that is not OpenWebIf does not support auto timer API - Addon won’t load Newnigma2 image (PR:153, 1 commit, 4 files changed)
I upgrade my OSMC installation on 3 of my devices (rbp2, vero4k and Win10) to the same build 17.8-380 / 23.12.2018.
The rbp2 build use the SQL database schema video112, but the vero4k und Win10 build is upgrading the database to video113.
Is it possible to take the schema upgrade also in the rbp2 build ?
wodix
I’ll include the commit in the next rbp build.
17.8-381, 28 Dec 2018: Based off OSMC commit (90764f7d1d) and newclock5 (922b68c)
xbmc:
  • Fix watched items in plugins after updating Kodi (c686b9ea)
pvr.zattoo:
  • Update build steps (d44651f)
Did any of the latest updates fix the HEVC problems?
WIth 17.8.381 now all devices in sync again, thank you for the quick integration !
I am using emby for Kodi and the latest add-on requires Kodi db version 113. I see the pi OSMC beta is still on 112.
Do we know when it will be on the 113 version?
17.8-381 bumped the db version to 113
Thanks but might not have been that easy. Got a blank screen after update and following error in kodi.log.
11:51:41.202 T:1801450224 ERROR: SQL: [MyVideos113.db] SQL error or missing database
Query: SELECT idVersion FROM version
11:51:41.205 T:1801450224 ERROR: Process error processing job
Don’t know if it’s related to the blank screen
Have you tried to restart Kodi. Can you post debug logs.
