[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
Yes have restarted multiple times but just get a blank screen on 381. And that was the only info I saw in kodi.log.
I rolled back to 380 but will try again and post full log. Unfortunately I cannot get into the Kodi interface to enable debug. So will enable it in 380 before I install 381
Ok this is the log just after the install of 381 before a reboot - https://paste.osmc.tv/cobiwetuxa
This is the log after the first reboot - https://paste.osmc.tv/zowevuqeze
Let me knows if you need any more
This is odd. Not sure why your db didn’t upgrade to 113.
I tested it on my rbp:
20:40:42.492 T:1799766768  NOTICE: Old database found - updating from version 112 to 113
20:40:42.492 T:1799766768   DEBUG: Copying from MyVideos112.db to MyVideos113 at /home/osmc/.kodi/userdata/Databa
20:40:42.685 T:1799766768  NOTICE: Attempting to update the database MyVideos113 from version 112 to 113
You could try copy MyVideos112.db to MyVideos113.db but there is no guarantees that this will work as there might be some db structure changes
Failing that, stop mediacenter make a backup of .kodi and rename to .kodi.bak then start mediacenter and see if it creates 113
(This resets Kodi so any addons/libraries etc will need to be resetup)
17.8-382, 29 Dec 2018: Based off OSMC commit (c946f89d5) and newclock5 (922b68c)
XBMC:
  • fix CID 1441972 (PR:15140, 1 commit, 2 files changed)
  • Do not list non-repo add-ons as ā€œunavailableā€ in info dialog (PR:15099, 1 commit, 1 file changed)
  • Fix unchecked reinterpret_cast of ID3v2 UFID frame (PR:15137, 1 commit, 1 file changed)
  • [joystick.xml] Add more buttons to bring up OSD in LiveTV/Radio and Menu in EPG (PR:15038, 2 commits, 1 file changed)
  • Workaround file copying bug decoding ā€œ+ā€ to space in file names in add-on installation (PR:15109, 1 commit, 1 file changed)
  • Scroll GUIListLabel on focus only when enabled (PR:15124, 1 commit, 2 files changed)
Includes latest addons:
inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv(83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070, +1), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (d35dfcd, +2), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (d3a5af2), pvr.nextpvr (450caeb, +1), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv(b60b971), pvr.stalker (2245b0d), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (c3d984b, +1), pvr.wmc (2697409, +1), pvr.zattoo(4688f45), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
I was having the same issue with 381, and discovered there was already a MyVideos113.db in my Database folder. Not sure how it got there, but deleting it allowed Kodi to convert the old database to the new schema and start without issue. Try deleting the following file in your .kodi folder if it’s there:
/home/osmc/.kodi/userdata/Database/MyVideos113.db
Thanks. Deleting 113 db worked. Also don’t know why it was there. Maybe emby add-on created it
17.8-383, 30 Dec 2018: Based off OSMC commit (2d8460c78) and newclock5 (dab918b5)
XBMC:
  • [keymaps] Specify that gamepad.xml is for EventServer ā€œgamepadsā€ (PR:15138, 1 commit, 1 file changed)
  • bump to v18.0 rc5 (PR:15152, 1 commit, 1 file changed)
Unfortunately, the issue is still present in version 17.8-383.
Why the LEIA version is not finalized yet ???
Ask the Kodi developers?
Cause its under development and it has over 200000+ lines of new code.
You might wanna read the blog at kodi.tv at some point to familiarize yourself with Kodi and learn how much it takes to actually make a new version cause its not like they just write the code on the fly just for you.
17.8-384, 2 Jan 2019: Based off OSMC commit (23ad399665b) and newclock5 (dab918b5)
pvr.hts:
  • Add support for recent tvheadend 4.3 image URL changes (HTSP v34) (PR:391, 2 commits, 5 files changed)
pvr.mythtv:
  • add the implicit marks for begin or end (b83fb4c)
  • bump version 5.10.3 (322f47d)
17.8-385, 3 Jan 2019: Based off OSMC commit (a128ec6a1) and newclock5 (dab918b5)
pvr.dvbviewer:
  • [lang] updated language files from Transifex (3e1eae0)
pvr.hts:
  • [lang] updated language files from Transifex (8a9d821)
pvr.nextpvr:
  • More incremental bugfixes for seeking, GetStreamTimes() changes (PR:78, 1 commit, 6 files changed)
pvr.vbox:
  • [lang] updated language files from Transifex (ea20464)
pvr.vuplus:
  • [lang] updated language files from Transifex (185b311)
17.8-386, 4 Jan 2019: Based off OSMC commit (14295041) and newclock5 (dab918b5)
XBMC:
  • Coverity fix to remove switch implicit fall through (PR:15190, 1 commit, 1 file changed)
  • [Estuary] display seekbar on showtime action (PR:15174, 1 commit, 1 file changed)
  • Replace CREATE TABLE AS SELECT (PR:15092, 1 commit, 2 files changed)
  • Resolution: Don’t add half refreshrates by default (PR:15016, 1 commit, 1 file changed)
  • [SmartPlaylists] Define DynPath for items retrieved from library (PR:15132, 3 commits, 2 files changed)
  • Add force flag to enable update file item in inactive window (PR:14998, 1 commit, 4 files changed)
  • [wayland] Request new frame cb only when previous one was signaled (PR:15193, 1 commit, 1 file changed)
pvr.vuplus:
  • Tuners and signal status (PR:156, 9 commits, 25 files changed)
I just asked the question because it’s been 2 years now he smnble me.
I’m guessing it should be within the next month or two, but only the Kodi devs would know the release date.
They will release it when they are happy with the stability and no major bugs.
17.8-387, 7 Jan 2019: Based off OSMC commit (66acdb218) and newclock5 (dab918b5)
XBMC:
  • [database] Make season_view and tvshow_view SQL ANSI92-compliant (PR:15185, 1 commit, 1 file changed)
pvr.vuplus:
  • Revert: move nlohmann-json to depends (PR:163, 1 commit, 10 files changed)
17.8-388, 8 Jan 2019: Based off OSMC commit (d7aeee9d) and newclock5 (dab918b5)
pvr.nextpvr:
  • More fixes for live tv tsb and seeks (PR:82, 1 commit, 13 files changed)
pvr.hts:
  • remove space so markdown link works in github preview (PR:392, 1 commit, 1 file changed)
Any updates on this? If it’s an FFmpeg issue, might it be worth raising this with the Kodi dev team?
I’m going to try this on the latest LE build with Leia, if it works then the problem is OSMC specific otherwise it’s a issue with Leia
