[TESTING] Kodi 18 (Leia) builds for Raspberry Pi
Every add-on causes any footprint, at least size wise. And storage size is important on a Pi. And it makes the list of installed add-ons unnecessary long.
Besides, I don’t really understand your position on internalization without an internet connection to be honest. To get OSMC in the first place you’ll need an active internet connection. And since I’m also running one RPi with OSMC without internet (with an USB-harddisk for storage) I know Kodi doesn’t really likes it in the first place when there’s no internet (it requires internet for setting the correct time and date to name one thing, since the RPi doesn’t have a realtime clock).
I use OSMC because of the freedom it provides over Libreelec and I wouldn’t change much about how OSMC works (if I didn’t like it, I could just as easily grep Raspbian and configure it myself for example), but this is one of the things that have bugged me since the beginning.
OSMC when it began, did not bundle binary add-ons separately as the concept did not yet exist in Kodi / XBMC.
A large number of users are using OSMC in LAN only environments or offline; to the point where we have developed an offline updater.
The add-ons take very little space on the SD card; but you could always remove these add-ons yourself if you wish to do so.
18.8-6, 20 March 2019: Based off OSMC commit (b8c1662) and newclock5 (f931efd78f7)
OSMC Skin
17.9.3-58
  • Skinshortcuts improvements
17.9.3-59
  • Pre-installed script dialogs fix
XBMC:
  • use angle-bracket include form for FFmpeg headers (PR:15647, 1 commit, 77 files changed)
  • Reword roadmap item template to make its intent clearer (PR:15728, 1 commit, 1 file changed)
  • [Docs] Use docs.kodi.tv instead of the codedocs url (PR:15769, 1 commit, 1 file changed)
  • [windows] remove pragma lib (PR:15712, 4 commits, 9 files changed)
  • Decoderfilter implementation (PR:15744, 1 commit, 23 files changed)
Includes latest addons:
inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (f09a0e7), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (b636726, +2), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(bd64b9e, +1), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (a445bf3, +13), pvr.wmc(7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (ecc9cfd, +4), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts(8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (edc0741, +10), pvr.njoy (4467cac), pvr.octonet(203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (97c67ae, +23), pvr.wmc(7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
exactly the same problem I had and could only solve it that way
I can not update it raspberry goes out does not matter in the osmc menu or with ssh sudo apt-get update
sudo apt-get dist-upgrade
It will be solved :wink:
okay that’s good :crazy_face:
Probably hasn’t sync’d to the mirrors yet. Give it an hour.
he downloads it packages are fully loaded Problem arises only during installation but I’m still waiting a bit :stuck_out_tongue:
18.8-7, 21 March 2019: Based off OSMC commit (f4abb324e) and newclock5 (f931efd78)
OSMC Skin:
17.9.3-60
  • Skin settings bug fix
17.9.3-61
  • Bug fix
OSMC:
  • Remove enabling of script.skin.helper.service, script.skin.helper.skinbackup, script.skin.helper.widgets in startup
  • Disable libinput grabbing patch
XBMC:
can not install it also not if I sit down without or install Manuel always breaks off :thinking:
Edit: think the problem is mine
Disabling the addon now sticks after a reboot, @Schninemaus :+1:t2: Disabling the Skin Helper Widgets script makes the script disappear under Videos/Video add-ons. This should now be resolved for you. :slightly_smiling_face:
Nope, mine does that too. I ssh to the rasphberry, run sudo apt-get dist-upgrade and suddenly the ssh connection breaks and the raspberry simply seems to turn off. Weeeird.
(edit) Ok, it’s because now stopping the mediacenter service turns the raspberry off. Updating either the skin or the mediacenter package stops the service, so…
I had to disable the mediacenter service, reboot, update and restart again.
Stopping the mediacenter service should not power the device off.
exactly the same problem I have
sudo systemctl disable mediacenter
Reboot
sudo apt-get update
sudo systemctl enable mediacenter
yes thank you :smiley:
Can you try again with the next nightly (probably tomorrow) and let me know if this happens again?
yes I can do it
18.8-8, 22 March 2019: Based off OSMC commit (0d56bc8) and newclock5 (f931efd78)
XBMC:
  • [depends] binary-addons: fix libGL.so location
  • [wayland] fix compilation with C++17
  • [cmake] fix set of APP_RENDER_SYSTEM on KodiConfig.cmake
  • [Music]Show artist disambiguation text when picking which one to scrape
  • [pydocs] Add warning to ControlList().reset() regarding ListItem destruction
  • [posix] Quit instead of shutdown on signals
pvr.nextpvr
  • Delete recording trigger change, cleanup initialization code
pvr.vuplus
  • Reload channels and tune async connection ([PR:198]
Yep, 18.8-8 fixes the shutdown issue.
