[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
17.8-217, 23 April 2018: Based off OSMC commit (c96614f61) and xbmc (35c9f368)
OSMC:
  • Set osmc addon mirror to use sha256 hashes (367bce16)
Includes latest addons:
inputstream.adaptive (aedfa50, +3), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), [url=https://github.com/kodi-pvr/pvr.stalker]pvr.stalker/url, pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (5e5493b), vfs.libarchive (e7d149e)
17.8-218, 27 April 2018: Based off OSMC commit (6d8b175) and xbmc (650b5f2)
Known issues:
  • Hostname not syncing between Kodi and device
OSMC:
  • Add libxkbcommon-dev dependency (ed4f77c)
  • Add libinput-dev dependency (d664e033)
  • Vero 4K: re-add support for displaying serial number and temperature (a7e5085)
  • Vero 4K: add temperature display (43a1be6)
  • Vero 4K: set CPU governor on standby. Needs permission adjustments (749025)
  • Vero4k: Add rw permissions to owner instead of setting (8fe9e04d)
XBMC:
  • [Linux] add libinput backend for non window system platforms (PR:13176, 14 commits, 30 files changed)
inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
Update: Found a problem with the dependency which will be fixed in the next version.
You can manually install the package or wait for the next build.
sudo apt-get install libinput10 libxkbcommon0
sudo systemctl restart mediacenter
After an update this morning, my Vero is stuck in a sad face loop. Here is the logging:
https://paste.osmc.tv/etuzoxeqif
Any ideas?
Regards, Arie
Can you provide full debug logs.
Do you mean grab-logs -A: Paste.ee
Thanks. Looking into the problem.
gmc, installing libinput10 wasn’t enough. I also needed to install libxkbcommon0 to solve the issue. Kodi is up and running again. Thanks for the work!
Thanks. Forgot about that one too! Will add it to the build.
17.8-219, 28 April 2018: Based off OSMC commit (b728f926) and XBMC (650b5f2cc)
OSMC:
  • Add libinput and libxkbcommon as dependencies
Includes latest addons: inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (3799782, +4), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
Went from stable March update to 17.8-219 testing. At boot a black init screen pops up, right after HDMI signal goes away. To make sure it the HDR workaround wasn’t the issue I cleared “/sys/class/amhdmitx/amhdmitx0/attr” and rebooted but it doesn’t make a difference.
https://paste.osmc.tv/xeretikefo
Try move your Kodi directory away. You may have a problematic add-on or incompatible skin.
17.8-220, 29 April 2018: Based off OSMC commit (96e52b) and xbmc (650b5f2)
OSMC:
  • Make osmc skin default (fa1da78)
  • Support loading of fonts from add-ons (f0ff064)
  • Remove service.xbmc.versioncheck (9ee0551)
  • Vero 4k: Add support for HDR autoswitching (96e52b9)
Update: 17.8-220 removed due to segfault
Thanks. I did this and got it working again.
Next issue: can’t switch to 2160p and make it stick. Changing the setting through the Kodi UI: it blanks out and then returns to 1080p. Did not have this issue on Krypton.
17.8-221, 30 April 2018: Based off OSMC commit (10904e) and xbmc (650b5f2)
OSMC:
  • Enable skin.osmc.v18alpha and make it the default (78aa67c)
  • OSMC Skin Alpha. Clear current music playlist bugfix (1e16d86)
XBMC:
  • lirc: work around buggy client lib (PR:13823, 1 commit, 2 files changed)
  • [fix] save resume points on exit (PR:13822, 1 commit, 1 file changed)
Should the lirc be fixed? It’s not working for me.
It should be, unless there are other issues. Can you post a debug log?
Sorry, I already reverted back to working version. I’ll post a log next time if the upgrade doesn’t work.
I only recently joined the Leia testing builds with 17.8-219. Long press using Harmony Hub (via BT Kodi profile) wasn’t working and now with 17.8-221 it is! Thanks.
test of 17.8-221 on v4k
A couple of my main screen GUI customization labels disappeared - however navigation still worked. Manually re-adding the labels under customize/appearance worked fine.
It took ahwile to figure out how to remove the Random Movies that shows on the right side of the screen when my cursor is on Movies
Eventually under Appearance/Customize I was able to download the Skin Helper and Default Widgets, restarted OSMC, disabled, enabled, and re-disabled the widget did the trick
DVD.ISO with menus - the menu support appears to be darn close to RPI (sweet!) and the menus open almost instantly. Sadly the video playback stutters every few frames for these titles.
Overall - nice work!
17.8-222, 3 May 2018: Based off OSMC commit (10904e) and xbmc (3a989eee7)
OSMC:
  • OSMC Skin (v18 alpha) - Fix addon.xml (9d8940)
XBMC:
  • libinput: sleep 10ms to reduce cpu usage (PR:13834, 1 commit, 1 file changed)
  • typo: missing vec4 in shader (PR:13835, 1 commit, 1 file changed)
  • there can only be one busy dialog (PR:13833, 1 commit, 1 file changed)
  • LibInputHandler: Use CThread’s Sleep (PR:13838, 1 commit, 1 file changed)
  • windowing: cleanup g_windowing globals (PR:13836, 1 commit, 4 files changed)
  • force closing busy dialog, there can only be one (PR:13839, 2 commits, 2 files changed)
  • [fix] throw exception if addDirectoryItem or setResolvedUrl called with nullptr (PR:13825, 1 commit, 1 file changed)
  • [PVR] CPVRSettings: All settings instances must be re-inited on profile switch (PR:13830, 1 commit, 4 files changed)
  • [aml]Register lirc in AML after #13761 (PR:13798, 1 commit, 2 files changed)
pvr.dvbviewer:
  • If EDL is disabled make sure to zero number of entries (4ea67c5)
  • Bump version to 3.4.5 (098d23c)
inputstream.adaptive (0f0ced4, +5), inputstream.rtmp (3b5058d), peripheral.joystick (80224e1), pvr.argustv (377f796), pvr.demo (d5e5cd1), pvr.dvblink (c61ea73), pvr.dvbviewer (098d23c, +6), pvr.filmon (0ca1665), pvr.hdhomerun (484b91d), pvr.hts (9533cce), pvr.iptvsimple (77156cb), pvr.mediaportal.tvserver (9702684), pvr.mythtv (9d15025), pvr.nextpvr (de30ff2), pvr.njoy (bd6581f), pvr.octonet (54680a3), pvr.pctv (5e95300), pvr.stalker (da6f0f8), pvr.teleboy (a84e5ef), pvr.vbox (3cf15ad), pvr.vdr.vnsi (d6fe796), pvr.vuplus (00a963f), pvr.wmc (2acca13), pvr.zattoo (1244e14, +2), vfs.libarchive (e7d149e)
