[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
#1
OSMC Test Builds for Kodi 18 for Vero 2 & 4K - Stretch
Based on the Kodi master Leia (v18)
If you are having issues with updating this is due to the aptly certificate expiring. You will need to download and install the new public cert:
wget -qO - http://download.osmc.tv/dev/gmc-18/pubkey.asc | sudo apt-key add -
Warning
Kodi 18 is currently in RC2 and there is likely to be a lot of activity in the coming weeks/months. As these are beta builds expect some issues.
If you are looking for a stable system then these builds are not for you!
Before proceeding make sure you have a backup of your Vero. As these are test builds there could well be some unexpected problems.
Database upgrades could also be an issue. Please make a backup of the Kodi database before installing, especially if you are running a remote MySQL database.
Installing
You need a working system in order to install these test builds. If you do not have OSMC already installed then go to https://osmc.tv/download/ to install the latest stable version.
As the nightlies are now built on Debian Stretch you will first need to upgrade your OS to Stretch.
The latest OSMC stable release (Jan 2018) is now on Stretch so best would be to upgrade to this and then you are ready to install the nightly.
Update apt source list to get the latest nightly:
Edit
sudo nano /etc/apt/sources.list
Make sure the following is commented out and not used (If you were coming from old nightly)
# deb http://download.osmc.tv/dev/gmc-18 ./
Then add
deb http://download.osmc.tv/dev/gmc-18 gmc-18 main
Save and exit file.
Import gpg certificate:
Finally run update and dist-upgrade to install latest nightly.
sudo apt-get update
sudo apt-get dist-upgrade
When new updates are released you can either update using MyOSMC or manually with the following commands:
sudo apt-get update
To confirm which version you are running:
dpkg -l | grep mediacenter-osmc | awk '{ print $3 }'
Check which versions are available should you wish to install a previous version:
apt-cache madison vero3-mediacenter-osmc
Install previous versions:
 sudo apt-get install vero3-mediacenter-osmc=17.8-138
After upgrading to each new nightly chances are good that it will crash once (sad face). Kodi will auto restart and resume again as normal. This is a known issue
Support
Since we are in alpha there could be a lot of incompatibilities with skins and addons. To resolve these its best taking the issue up with the addon developer.
If you have any issues with OSMC please provide debug logs. Most problems are almost impossible to fix if we don’t have the debug logs.
How to submit a useful support request
Archive:
http://kodi.gjmccarthy.co.uk
Known Issues
  • Hostname not syncing between Kodi and device
  • Some features in MyOSMC not working (Remotes, Store etc)
Current Build
17.8-395, 17 Jan 2019
Previous Builds
17.8-394, 16 Jan 2019
17.8-393, 15 Jan 2019
17.8-392, 14 Jan 2019
17.8-391, 13 Jan 2019
17.8-390, 13 Jan 2019
17.8-389, 11 Jan 2019
17.8-388, 8 Jan 2019
17.8-387, 7 Jan 2019
17.8-386, 4 Jan 2019
17.8-385, 3 Jan 2019
17.8-384, 2 Jan 2019
17.8-383, 29 Dec 2018
17.8-382, 29 Dec 2018
17.8-381, 28 Dec 2018
17.8-380, 23 Dec 2018
17.8-379, 21 Dec 2018
17.8-378, 21 Dec 2018
17.8-377 Skipped
17.8-376, 19 Dec 2018
17.8-375, 18 Dec 2018
17.8-374, 16 Dec 2018
17.8-373, 15 Dec 2018
17.8-372, 15 Dec 2018
17.8-371, 14 Dec 2018
17.8-370, 12 Dec 2018
17.8-369, 10 Dec 2018
17.8-368 Skipped. Hash errors
17.8-367, 10 Dec 2018
17.8-366, 8 Dec 2018
17.8-365, 6 Dec 2018
17.8-364, 5 Dec 2018
17.8-363, 4 Dec 2018
17.8-362, 3 Dec 2018
17.8-361, 1 Dec 2018
Netflix or Amazon with Vero4K
[HowTo] RetroPie and OSMC: Retrosmc - Retrogaming on OSMC
Vero 4K General Discussion
Installed Kodi Version / Update to a new build
Testing RetrOSMC 0.009 Beta
Vero4K Latest update Hard Crashes when media source selected
Widevine problems
Vero 4K Netflix and Streaming general
How to install self compiled image?
OSMC's December update is here with Debian Stretch and Kodi 17.6 - OSMC
Widevine DRM content not playing after december update
[Testing] X11(simple desktop) + Chromium(web browser) in a simple installer for Stretch
[TESTING] Debian Stretch upgrade for OSMC
[TESTING] Vero 4K / 4K + video improvements
CEC volume control for AVR not working after upgrade to latest kodi version
New user... 2 questions
Latest beta update has Kodi constantly crashing
Netflix - is there any way to use a genuine netflix account on osmc?
Issues Playing back high bit rate 4k video
[TESTING] OSMC skin updates for v17 and v18
Rewind on file via smb causes playback to stop/hang
Netflix on Vero 4K
Vero 2 Leia alpha testing build?
Ff-h264 dropping and skipping frames
Questions Before Purchasing
VERO 4k with Leia?
Kodi 18
Possible to install Kodi dev binary build to test?
#2
Excellent, good work @gmc
#3
Just checking; If I install the test builds on my 4k, will it affect my 1 year international hardware warranty?
#4
No.
#5
So getting a sad face after splash screen as noted but the system doesn’t seem to resume as normal. Only thing I can think of is I was using the KODI skin and I installed and uninstalled a single addon before upgrading.
http://paste.osmc.io/osiwunasam
Issue persists after following this advice
#6
Thanks. I’m looking into this. Can replicate the issue so a fix should be coming soon.
#7
Did you follow the advice correctly?
Kodi is having problems (not necessarily the cause of the sad face) with the keymap editor add-on which appears to be in your local Kodi directory.
#8
Found the issue. Vero builds were being built with xlibs. I’ve now included
https://github.com/osmc/osmc/blob/master/package/mediacenter-osmc/patches/vero3-005-do-not-build-with-x-libs.patch
and adapted it for cmake. New build should be up shortly.
#9
Great! You’ll want to use this for Pi as well.
#10
17.8-032, 1 March 2017: Based off OSMC commit (73807f1d) and xbmc (f1ce0390)
Build Details:
First build of Kodi Leia for Vero 4K
#12
@gmc Remember that path issue we had before and the PR Garbear suggested? I wonder if this is relevant again.
#13
Just rebooted to grab logs, now the message is
Add-on couldn’t be loaded.
An unknown error has occurred
http://paste.osmc.io/iyuwofiwan
#14
@gmc
/usr/share/kodi/addons/game.libretro.snes9x/game.libretro.snes9x.so
Paths need adjusting as recommended on Pi.
@r34ch Will be fixed shortly.
#15
Thanks. I’ll check on this.
Found it - Its this patch that fixed it.
Need to apply to be Vero :slight_smile:
#16
Awesome thanks.
Just curious if you guys know why the emulators are packaged with Kodi but not the game controller profiles? I just noticed in my logs that I need them to use the emulators.
#17
Sad face when trying to play HEVC 265 from external HDD
http://paste.osmc.io/iwinedaxot
#18
Rebooted and got stuck in a bootloop until I removed my external HD and pulled the plug.
Not sure if logs grabbed anything http://paste.osmc.io/situxiganu
#19
Not a debug log so can’t tell what the issue is.
Also keep in mind these builds are alpha, so experimental.
#20
Yea I understand it’s early alpha, do you guys still want logs or will I hold off for a few months?
#21
Without a debug log we can’t help. So it’s worth uploading one.
If you want a stable system, stick with OSMC as is on Vero 4K.
