17.8-052, 4 April 2017: Based off OSMC commit (73a8688) and xbmc (f536790)
XBMC
[Clean up] Removing white space, unused variables and methods
Merge pull request #11923 from nsenica/strip_rbpi_leia
XBMC
17.8-053, 5 April 2017: Based off OSMC commit (8d8c5f2) and xbmc (cd5f68235)
XBMC
fix-watched estuary fix watched status for videos
[filesystem][dialogs] Add context menus for favourites home screen widget
Input improvements
17.8-054, 6 April 2017: Based off OSMC commit (fb308fd) and xbmc (656f12cef)
XBMC
[depends] use ccache for binary add-ons
[pvr] no need to run a job to announce channel switch
[depends] use ccache determined from configure in Toolchain.cmake
Moved party mode, set default and clear default to new contextmenu
17.8-055, 7 April 2017: Based off OSMC commit (f9104f8) and xbmc (5c3e9d9)
XBMC
[PVR] Fix timers map after
[MediaCodec] Fix videoBuffer video dimensions
AMLCodec: fix 720p → 1080p switching
17.8-056, 11 April 2017: Based off OSMC commit (3ae58b41) and xbmc (984fe69cd)
XBMC
[PVR] Fix timers map after f47956f
[cmake] fix package names that find_package is equal to find_package_handle_standard_args
Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (0baf85af, +3), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
17.8-057, 13 April 2017: Based off OSMC commit (b720dfe) and xbmc (7392884f11)
XBMC
[cmake] Spring cleanup aka OCD
[cmake][TexturePacker] Cosmetics: keep it alphabetized
[cmake/addons] Bindings spring cleanup
[fix] minor keymap fix
cleanup internal rar vfs in favour of vfs.rar
Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (3c7ea594, +4), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
17.8-058, 16 April 2017: Based off OSMC commit (b720dfe) and xbmc (7392884f11)
XBMC
Fix for UI not showing both extractflags and extractthumb
17.8-059, 18 April 2017: Based off OSMC commit (463be769) and xbmc (bcbbc14d1)
XBMC
paplayer: restore option for replaygain reduction as clipping protection
logging: always log skin name and version when loading
FIX: [droid;leanback] Various fixes
[EPG] Fix gap tag update handling.
17.8-060, 19 April 2017: Based off OSMC commit (8fe2a11) and xbmc (bcbbc14d1)
XBMC
[PVR] Fix ‘Switch to channel’ context menu action after #11747#
[addons] make versioncheck optional
Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (3c7ea594, +4), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (d61c5013, +1), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
For latest build see first post.
17.8-061, 22 April 2017: Based off OSMC commit (4e1860) and xbmc (113cdf6)
XBMC
FIXUP: select first unwatched broken after select by url
Revert “Moved party mode, set default and clear default to new contextmenu”
[PVR][EPG] Make EPG a subcomponent of PVR
[PVR] Make pvr manager’s epg container member an object, not a pointer.
[PVR] Move files from xbmc/epg to xbmc/pvr/(epg|windows).
[PVR] Move type definitions from epg/EpgTypes.h to pvr/PVRTypes.h
[PVR] Rename all CEpg* types to CPVREpg*.
[PVR] Move epg types to namespace PVR.
[PVR] Get rid of epg container static global instance. Make it a subcomponent of PVR manager instead.
17.8-062, 23 April 2017: Based off OSMC commit (b105ef5) and xbmc (09e730d5)
XBMC
[PVR] CPVREpgContainer now uses CPVRSettings.
[addon] remove all windows.h includes
Hi there,
Is anyone else missing libamcodec.so? I can’t play any videofiles after the upgrade to the Leia build.
Thanks, L
Details:
11:48:28.271 T:3694015472 ERROR: Unable to load libamcodec.so, reason: libamadec.so: cannot open shared object file: No such file or directory
11:48:28.271 T:3694015472 WARNING: CAMLCodec::CAMLCodec libamcodec.so not found
Can you check if you have libamcodec installed.
sudo dpkg -l | grep libamcodec
If its not found try installing with:
sudo apt-get install vero3-libamcodec-osmc
17.8-063, 26 April 2017: Based off OSMC commit (01495ffcf) and xbmc (c5eb84873)
XBMC
Create slovenian.xml
Increase CHUNK_SIZE to 128 KB
NFSFile: Return max chunksize possible
[PVR] Search window: Fix very first search after kodi start not working.
yep:
ii vero3-libamcodec-osmc 1.1.0-3 armhf libamcodec
also a
osmc@osmc:/usr/lib$ find .|grep libam
gives no results.
I was dist-upgrading from a completely naked installation and only installed one video addon too see if it is working there.
EDIT:
I found the solution (and possibly the error/bug)
The files are there (e.g. libamcodec.so) in /usr/osmc/lib
But there’s no path set to this destination in /etc/ld.so.conf.d/*.conf
I simply added /usr/osmc/lib to the vero3.conf:
root@osmc:/etc/ld.so.conf.d# cat vero3.conf
/opt/vero3/lib
/usr/osmc/lib
Thanks. I’ll have a look into this.
17.8-064, 27 April 2017: Based off OSMC commit (a71906e) and xbmc (749c61)
XBMC
[PVR] Search window improvements and fixes
[PVR] Search window: Fix ‘Find similar’
AE: improve tempo filter
AESinkPULSE: Return to PA’s delay infrastructure
[PVR] Search window ux improvement: Replace modal searching dialog with busy dialog.
Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (6c1af46a), peripheral.joystick (3c7ea594), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (d61c5013), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea), pvr.wmc (5aa3b1ca), vfs.rar (c3e051dd), vfs.sacd (bdfc8938), vfs.sftp (add60314)
Hello, I was wondering if this test build is capable of using that Netflix add-on that’s being developed? I have an Android Kodi apk installed on my phone that it works on, but would much much prefer to use it on osmc
Haven’t looked at it yet but I’ll add it to my todo list.
Oh okay. Thank you gmc. Hopefully this is able to get added in the future
